need help
  • need help
    i have made a bedini motor with one 6 inch computer fan and i have bank of 12 supercapacitor with 6000uF / 350V DC each.
    how can i charge the capacitors with my bedini motor?
    can anybody help me what type of circuit do i have to apply?
    Hi,
    What circuit did you use to convert the fan to a Bedini motor? You would just connect the caps in place of the battery you would normally be charging. A Bedini fan circuit should have a place for the charging battery to be connected to. If you post the circuit you used I'll try to help.
    Good luck, Carroll
      Bedini Circuits
      Lancerdoom,
      Check your private message box.
        i used this circuit to make bedini motor
          Hi again,
          Ok that is the same circuit most of us have used. Just connect your caps in place of the charge battery. It should charge your caps just fine. I guess you realize with caps that large it will take a while for them to charge all the way. Also if you are tuned for the sweet spot with a battery as the charge object you will need to retune for the sweet spot with the caps in there instead of the charge battery.
          Good luck, Carroll
