Hi
Request all the experts to help me to convert this motor which is 220vac 1/2hp as alternator to produce 12v 3phase . I saw this motor on sale but could not get much information
About this motor
SAM.K
About this motor
SAM.K
to the forum. You will find many knowledgeable people on this forum. They cover a wide range of experience and areas of expertise. I was an industrial electrician, so maybe I can help with this. The motor in the picture appears to be a single phase multi-speed appliance motor such as is used on washing machines or dishwashers. It would be very difficult to convert that motor to produce 3 phase 12 volt power. As Adam advised you would be much better off just using a regular automotive alternator. If you want 3 phase ac from that you only have to take the alternator apart and remove the diode pack. Then take the 3 posts the diode pack was connected to and connect wires to them and feed them to the outside of the alternator and you now have 3 phase power at around 12 volts or so depending on how you regulate it and the speed it turns. Another advantage to using the alternator is it will probably be much more efficient than anything you could engineer yourself.
