Originally posted by Aaron
Rigidity has lots of key factors including twist. Because you are pushing from the side on a milling operation, it is easy to spin the headstock. Therefore loosing the machines zero on precision apps. A round ram is ok if all you do is drill because there is no side pressure.
Once you put an end mill in it is a whole new ballgame
The square ram design is far superior. However if all you do is cut with very small tools, then it may not be much of a factor. It really depends on how you use it.
If you are doing allot machining on steel, those little mills will wear out really fast.. Especially the nut and screw. But they do offer a cheep solution for light duty work.
As long as you do not have to be real precision.
regards,
Murlin
