Ground Based Energy Systems
  • #31
    great thread
    Hi everyone
    look like you chaps are having fun
    If you get a balloon full of water and tap it you get waves in the water.
    if you tap it at the point the wave is at its highest at your point of force your re-enforce the wave.
    I did this with a aromaz setup with two round caps i made out of aluminum foil and cling film on spheres with about 4 lairs.
    How do i now this happened?
    I left it running one night maybe a hour or so,
    in the morning family life as normal but around 12 i had the afternoon free, so off i go down the celler switch it on and Bang.....
    The hole room was charged the sound was incredible....I feared for my life....I ran upstairs to get the camera,
    really load like a big tesla coil YouTube - Tesla Coil
    I get my camera got down stair made a video about the fact i have poo in my pants(not really im a big boy now)
    and the sound drops down and by to normal life again.
    I will post a picture of the set up but it a long time ago now I cant remember how the ground is connected;maybe the ground is on the two sphere different phyical grounds, yes that was it!
    side note; I think the hard electron is missing a girlfriend the soft electron
    peace and blessings
    Bodx
    • #32
      Interesting .
      Have you use concentric cylinder cap? Just like mentioned by Harold Aspden?
      Practical Guide to Free-Energy Devices - Chapter 11
      • #33
        No but it was based on Harold Aspden work so it should work all the same!
        also look at he bedini sg with two ground connections it the same thing, a pump.
        YouTube - Magnet Motor Switch Secondary Coil Test
        with two ground and your off.
        • #34
          Originally posted by Bodkins View Post
          Hi everyone
          peace and blessings
          Bodx
          What exctactly are you talking about?
          • #35
            Ok, thanks .
            • #36
              Its clear in my mind but words for me are troublesome, I sorry.
              this may help, if not
              quote from Practical Guide to Free-Energy Devices - Chapter 11
              The lesson is that it is not sufficient to build and demonstrate something that works, if you do not fully understand why what you have devised actually does work. This is especially the case here where one is claiming a source of energy hitherto unknown. The invention to be described below will, in its broadest sense, appear to be quite similar to what T. Henry Moray is said to have demonstrated in showing that substantial electrical power could seemingly be drawn from the aether using a simple wire antenna strung between two poles.
              However, as will be seen, the antenna is not needed and the reason is that the energy source is not the radiant emission by some process involving radio wave propagation through the anther, but rather what can best be described as a phase-lock that couples the apparatus with the quantised motion of electric aether charge. There is a technique, to be described below, by which it is possible to exploit this phase-lock condition by setting up an energy oscillation involving an apparatus component and its enveloping aether, the result being that energy in an immediately useful electrical form is imported into the apparatus from that aether.
              Brief Description of the Invention
              According; to one aspect of the invention, an electric power delivery circuit comprises two capacitors, each having a pair of electrodes formed by a pair of metal cylinders having concentric axes, each capacitor having an associated inductor series-connected to it to form a capacitor-inductor unit, DC voltage excitation means connected to a parallel combination of the two capacitor-inductor units, whereby to apply between corresponding electrodes of the capacitors a DC bias voltage which primes them with electric charge, and power output terminals, one at each point of connection between a capacitor and its associated inductor, whereby to provide for an AC power output owing to oscillations of electric charge between the two capacitors at the resonant frequency of the capacitor-inductor units.
              According to another aspect of the invention, an electric power-delivery circuit comprises two capacitors, each having a pair of electrodes formed by a pair of metal cylinders having concentric axes, each capacitor having an associated inductor series-connected to it to form a capacitor-inductor unit, DC voltage excitation means connected to a parallel combination of the two capacitor-inductor units, whereby to apply between corresponding electrodes of the capacitors, a DC bias voltage which primes them with electric charge, each inductor being the primary winding of an electrical transformer, the secondary winding of which serves to provide an AC power output owing to oscillations of electric charge between the two capacitors at the resonant frequency of the capacitor-inductor units.
              According to a feature of the invention the capacitors have no intervening solid or liquid dielectric medium separating their concentric electrodes.
              I did have cling film as a dielectric.
              this video is the setup without the spheres its a old video but you can see the basics here.YouTube - Kickback research
              now put two sphere on the two hotrails like the tesla short-circuit light thing.(the two grounds)
              The two halves of the split primary are turned in opposite directions. This creates a bucking field in the secondary until applied current is released....Splitting the positive
              If you dont understand it now Im sorry, but its abit fluffy how it works, just does!
              • #37
                this shows the middle(as in the middle of the layers) of the sphere connected to the load,
                Remember "I HAD NO LOAD" the first time I did it.
                In the kickback video I have a load on BOTH the Hotrails this slows down the oscillations as the pressure builds up in the Bid Green Cap.
                What if i have no pressure build up on the Hotrails using the sphere.
                meditate on it, its all there.
                • #38
                  Originally posted by Sputins View Post
                  Ground hogs:
                  Recently the American Marconi Foundation (Eric Dollard & Co) has made some updates to the website. Home :: AMERICAN MARCONI FOUNDATION Checkout the Download section, includes a PDF document written by Eric: (EPDPaper) - System for the Reception and Transmission of Telluric Waves. -Interesting reading!
                  Hye i read in a hurry the EPDpaper. Actually that's the main idea! Not for communication but for energy reception from natural tellucric current causes.
                  Ok, being said that, the paper is too technical for me, but in some respects i do not quite agree as the longitudinal wave and EM wave inside the ground that propagate in 90* etc.
                  No EM wave as far i know can propagate via ground except cosmic radiation.
                  Tesla has made a fairly simple points. The earth is a big wire that we stand upon it. Any trasmition is being done via a EMF wave and oscillating electrons. How enery is propagated in conductors?? that way!
                  I will study further for concluding in making a makeshift approach in order to have a hands-on experience.
                  • #39
                    water well
                    I have a 570 foot deep water well with a steel casing. Sounds like a good antenna for one side of a energy capture circuit. I think I'll try it.
