Peak Voltage, Limited Current
Magneto head,
Interesting experiment. The reason the lights are so bright is that the diode and capacitor combination makes the "peak voltage" from the inverter, namely 160 volts, available to your loads. Second, like a "Wiseman Capacitor Battery Charger", the 30uf capacitor limits the current to under 1.2 amps at 60 hz. If you add more lightbulbs, say up to 200 watts, you'll see the nature of the current limitation, as the bulbs will be too dim then.
Exactly while it seems that you cannot be shocked is not clear to me. Perhaps it is the current limitation, or maybe you have dry skin. Like the others, I would be careful with that aspect of the set-up. It still might be possible to be shocked, but you simply haven't found out how yet.
Peter
Magneto head,
Peter
