Newman coil circuit proposal
  • Newman coil circuit proposal
    hello i like propos a pulse circuits for low volt Newman coils
    its not 100% circuit but just idear pleas look at it and let me no how we
    can get this to work
    i workt a lot on newmans work but i never hat a good circuit that make
    a pulst AC or triggert AC circuit ( so not one pulse per cycle but 2 in a N*S way) and becous it is triggert ac or N&S u wil get spikes of radiant.
    that u dont get whit just a AC wave.
    user name mix up
    Originally posted by ray0.e View Post
    hello i like proposal pulse circuits for low volt Newman coils
    its not 100% circuit but just idea pleas look at it and let me no how we
    i work lot on newmans work but i never hat a good circuit that make
    a plus AC or trigger AC circuit ( so not one pulse per cycle but 2 in a N*S way) and because it is triggered ac or N&S u will get spikes of radiant.
    that u don't get whit just a AC wave.
    ok i hat a mix o whit my user name
    so to be clear Ray0.e {} Ray0energy is the same person
    The radiant energy is here!
    The energy revolution is now!
    Ray0energy
    http://www.youtube.com/profile?user=ray0energy
      Have you built and tested this circuit yet?
      I don't understand how this would be any different than a single pulse, other than to create more torque.
      Ted
        Ted
        no not yet its just idea but yes i want more torque on the Newman coil
        be because whit a normal pulse circuit u only have one pulse per cycle.
        and newman is using in his hi volt type motor pulsed Ac NSNSNS.
        i dit it befor but whit 2 batts and commutator's on the motor shaft.
        but i like to do this from just 1 batt and whit transistor's.
        so this circuit is a ida (my electonics is still no so super to no if this can work)
        i don't like to blow a way my transistors so if anyone can help me to get it work that will be supper cool
        Ray0energy
          here are the circuits i used till now on all my motors
          Ray0energy
            You may have some trouble switching the base of a 2n3055 to ground in the lower left two circuits. I would suggest a positive voltage source with respect to the emitter.
            What kind of recovery do you get from your bridge rectifiers across the coil?
            Ted
              Hi Ray
              My experiments and comments from Mr Lindemann have told me that the Newman Machines drawback is the low RPM, and the low RPM is because of the high back-emf voltage induced into the coil by the turning magnet, and this is because of the high inductance of the coil. If it is not too difficult for you, see if you can run the motor by using an Iron Bar instead of a Magnet.
              I have yet to build a Newman motor, because of other projects, but this is definitely something I'd like to experiment with.
              Elias
              http://blog.hexaheart.org
                If you want AC switching try Bedinis bipolar switch. Its not too far off from what you have drawn there.
                  this one u mean
                  i have to study this a bit but in one of the videos (Energy from the the vacuum) john was telling that the window motor don't have the spikes of radiant.
                  and that is just wat i don't want to get rit of. anyway this circuit is a good base to start of whit. i was close i see that i have 2 sets of NPN&PNP transistor to Handel the N and S gad.
                  can i use a different transistor for PNP NPS8599? let say for a more common one like the BC559?
                  Ray0energy
                    Hi Ray.
                    Its still there (the inductive discharge).
                    You can use any complimentary pair of transistors for the mains (Q1,2,3,4) Id suggest 2n3055 and MJ2955.
                    Depending upon how you intend to trigger it you may need to pick a different transistor for q5 and q6. If you use trigger coils, use NPN (mpsa06) if you use other like hall or reed you can use PNP.
                      Hi Ray.
                      ok trigger is a walk in the park i find a good pair transistors the PNP BU208A and BU508A TO3 8Amp
                      so now to make it very basic for any one i just go for the motor drive part. because that was my hole point. a Newman coil/motor can only be if its 2 pulses per cycles N/S like the window motor. and in all my time i was doing the Newman motor. i never get that far. only whit 2 battery's.
                      so it was a Newman coil whit a bedini drive
                      so ok here is that same circuit but a little different to make it super simple for any one to build J1 J2 u can put wat ever Reed or transistor.
                      BU208A BU508A http://www.datasheetcatalog.org/data...s/mXyzsyus.pdf
                      Ray0energy
                        trigger mode?
                        What used to trigger mode: Coil, Reed, Hall,,,,,, what good? What are the advantages? Shortcomings?
                        Xu Yuan
                          Fill it in your self
                          I left it open so u can fill it in your self
                          Sam people like reed and aders like hall,s
                          (ps I ceap it short becuas I use my ipod)
                          Ray0energy
                          • #14
                            Hi,
                            The BU208A or its variants was never manufactured as a PNP type, it is an NPN type.
                            Also, in your schematics, you may wish to check the collector-emmiter connections of the PNP transistors (where you use BU208A) with respect to the original Bedini schematics. I think you mixed them up.
                            EDIT again: I think you also mixed up the BC559 transistors collectors and emitters...
                            rgds, Gyula
                            • #15
                              Hi Ray0energy,
                              My intention was not to bang you but to help and make the mistakes clear so that other members should not fail in building your schematics, ok?
                              So please go ahead and correct your drawing and have fun.
                              Regards, Gyula
