3 Battery System up and running
  • 3 Battery System up and running
    Merry Christmas all
    I got the 3 battery system fired up on this cold snowy morning.
    Using 2n3055 transistors and starter batteries 550 CCA's
    diode is a 1n5400
    load is a ge 194 bulb
    all batteries had a rest voltage of about 12.6
    first run lasted half an hour and bat 3 was over 14v
    switched batteries.
    second run about 20 min bat 3 over 14v
    voltage on load is 8volts
    bat 1 & 2 only lost a 2~3 tenths of a volt I believe
    not positive its COLD in the garage today............
    So I wasn't really keeping any records just seeing if it worked.
    that was all the time I have this morning will run more tonight
    At this rate all batteries will be charged in a couple more rotations.
    Will start increasing load to use up power in the batteries
    till I find a load that keeps everything in balance.
    Bill
    @ wwdotme - are you pulsing the circuit, or is it always on? If you are getting a gain, I wonder if you would get more this way?
    Conditioned electrolytic capacitor Electret effect test - Vox
      no not pulsing
      just on till charge battery is over 14v
      then rotating.
      on 3rd rotation tonight bat 1 & 2 dropped a couple tenths then held steady
      while bat 3 climbed
      and load volts was at 9 volts this time.
      not sure if first reading was poor connection or not.
      But voltage on bat 1 & 2 is higher each time I rotate them.
      So things are looking good so far.
      still no solid data as my garage ink pen refuses to write in the
      freezing cold garage. heat in the garage is down at the moment till
      I can get my babington heater put together and running.
      Bill
        well got a chance to run a data test
        rest
        b1= 12.79
        b2= 13.31
        b3= 12.94
        total= 39.04
        started test load voltage was 8 volts with 2 ge 194 bulbs
        ran the test for 3 hours till battery 3 was up to 14.87 volts
        let the batteries rest for 1 hour
        b1= 12.74
        b2= 13.05
        b3= 13.28
        total= 39.07
        load voltage dropped the hole test ending up at 6.14 volts
        at the end of the test.
        a gain of .03 volts + an average load of 7.16 volts
        hooked up a headlight off a car for a bit but transistors started to get hot.
        Load voltage was only 3 volts and b3 started charging fast
        b1 and b2 voltage dropped below 12 volts
        So I cancelled that test before I burned up a transistor. Too much of
        a current draw.
        Bill
            more of the energy passed by the load can be absorbed
            I get it now the energy used by the load is what we are charging the 3rd battery with.
            And the load drops because the potentional difference changes as b3 gains charge
            Is this correct?
            Thank for the explanation
              after a 12 hour rest the voltage on the batteries has risen.
              b1= 13.23v
              b2= 13.65v
              b3= 13.69v
              total= 40.57v
              thats a .5v gain just from resting over night.
              well headed to chicago today won't get to do anything else
              till thur.
              Bill
                I hooked up a small dc motor out of a printer for the load replacing
                the 194 bulb and b1 and b2 starting gaining in voltage and b3 started
                dropping. B1 went to 14.68 volts in just a few min. b3 dropped close
                to what it started at.
                whitch b3 was a dead battery only showing 8.5 volts
                the load was measuring 11-12 volts.
                b2 rose to 13.24 volts.
                I then hookeed the light back up and b1 ,b2 voltage dropped back
                done to where they started b1-12.86 and b2- 13.01
                b3 slowly charging again 9.15
                  I have also noticed that when I shut the system down with batteries still
                  connected that the batteries gain voltage. This morning b1 was over 14 volts
                  b2 was 13.26 b3 was back to 8.5 dead.
                  Yet when I hooked up the motor and turned it on b1 and b2 started gaining
                  voltage and b3 held steady.
                  b1 went to over 15 volts.
