Simple driver for harvesting radiant spikes from a coil's collapsing field.
  • Simple driver for harvesting radiant spikes from a coil's collapsing field.
    Hi all, didn't know where to post this but it would make a great battery / capacitor conditioner.
    3 parts; the basic unit
    Basic bedini coil voltage spike - Vox
    The transistor driver;
    Variable pulse width 555 - Vox
    And the scr capacitor discharger
    Pulse charge from cap by scr - Vox
    Enjoy
    Hi Ben,
    I like your circuits. You may want to try a Sidac in the gate circuit of you cap pulser. I used one that way and it worked great. If you don't know what they are, here's a general description:
    The sidac is a silicon bilateral voltage triggered switch with
    greater power-handling capabilities than standard diacs. Upon
    application of a voltage exceeding the sidac breakover voltage
    point, the sidac switches on through a negative resistance region
    to a low on-state voltage. Conduction continues until the current
    is interrupted or drops below the minimum holding current of the
    device.
    These are really handy little devices. They only cost about $.50 each and come in a variety of voltages. Much better than a zener in this type of application.
    Littlefuse makes them and you can find them at Mousers.
    Ted
      Originally posted by Ted Ewert View Post
      Hi Ben,
      device.
      Ted
      Can you compare it with transil ? Transient voltage suppression diode - Wikipedia, the free encyclopedia
      What is better ? How much power can SIDAC conduct ?
        These are two different devices. The transil apparently acts much like a zener diode, clamping a circuit to a set voltage and shunting any excess voltage.
        A sidac becomes a short circuit at it's threshold voltage and only resets when the current ceases. They are primarily designed for use in AC applications. They are relatively low current devices typically handling 1 amp of continuous current with a surge of around 20 A.
        I would recommend researching this whole family of devices. Lots of possibilities for the types of circuits we build.
        Cheers,
        Ted
          Cheers,
          Ted
          Please , can you explain what do you mean by selected statement ? I've used this device to protect mosfet but I really do not fully understand how it works ? Does it conduct above selected voltage for example when circuit has flyback spike of 300V or it closes when such voltage tries to flow across it ?
          Please , it is important for me to fully understand it.I've always thought that it works like a sparkgap passing currents related to voltage above selected level.
