My goal is not to see big streamers, but to light my house, instead.
And in the video you posted you can see that even while using the higher output, there is not that much light being produced by all those bulbs. Probably less than what I'm obtaining on 10v and about 1.4 watts, or less, while lighting a single 25w gutted Cfl.
His plasma bulb does look very cool though.
I'll upload a picture of my current circuit, when I can. But, my camera is not working properly, and I'm still working to improve this circuit.
The stronger transistor is of interest though, as that is the weak link in all of these devices, while still trying to economize as much as possible on the input draw.
Ideally I would like to have solar panels as my input source, which is the reason for my interest in a transistor that can handle 12v, and 30 to 100 watts, even if it is coming from batteries, for now.
Mounting the transistor on a big motherboard heat-sink and having the 12v heat-sink fan mounted on it also, is going to be the only way to go when using higher inputs. I will try this soon to see if I can keep the heat down, because when my "hydrid" circuit kicks in, to a higher output, the light brightness improves by quite a bit, but the transistor really heats up when that happens. About the same as what happens in computer processors, which would also cook if not cooled.
Good luck with your monster Exciter.
Toto: Good luck with your circuit, also.
Nick_Z
Nick_Z
