The ( EttCM ) Energy Technology - Learning and Teaching tools
  • The ( EttCM ) Energy Technology - Learning and Teaching tools
    The EttCM Energy Technology is based on Normal Physics and Science of converting Permanent Magnetic and / or Gravity power as a means of developing
    Kinetic energy of motion; that conforms to the main laws of Thermodynamics;
    This technology uses 2 input energy forces to produce usable energy output of 100 percent unity; for 1 output system or device that allows the
    Single machine to produce output energy enough to runs itself and whatever the system is designed to produce in energy power output;
    The - Learning and teaching tools are designed to inform anyone interested in knowing how it is possible to produce a energy output device or machine;
    That runs without using input energy; as a self-contained power output system; That works without using Energy to produce usable energy output / power;
    Because Permanent magnetic and Gravity is not energy itself; the force can produce attraction to atoms causing kinetic energy of motion; producing
    Energy from the force alone; The Energy produces a means of decreasing and increasing a power of attraction to conform to the laws of thermodynamics;
    A new concept in Physics has been offered as a new form of the ( Creation of new Energy ) Called - Cooldynamics - that is the energy created that did not exist
    before the energy became energy of motion from the Force of Gravity or Magnetic powers of force;
    Energy is mass or weight in motion or E = MC>2 saying Energy = Mass or Weight * Time, Speed, distance ( the square is optional )
    If energy that is mass in motion gives its energy to another mass or weight the first mass or weight loses it motion; meaning it is now Dead Weight of non-movement
    ( mass or weight without movement ;; Is NOT energy )
    Gravity is NOT energy but the NON-energy makes kinetic energy of motion ( this is a new Creation of energy from non-moving mass or weight; )
    This new energy is now a form that falls into the usable energy used in Thermodynamics energy that is only changed from one form to another;
    EttCM energy technology uses the Cooldynamics - new Created energy as the power source energy used to produce the output energy used in this form
    of a new type of idea in using Created energy in place of using Thermodynamics energy; that can not be used as a power source in a self contained system;
    Because this topic is a learning and Teaching tool; The format will be in the line of presented information only;
    Note; asking question; may or may not be answered; ( This topic may require a basic knowledge of Engineering and Physics
    Note; This technology is deemed ( impossible by many scientific groups ) But if understood what is being said; proves it is a simple proof of concepts
    But is a believe it or not only - As said; never believe in something you personally do not see for yourself in person; That produces no questions of being real;
    The information shown is all Free - open source and public domain; and can be built and tested to anyone that wishes to do so; ( free for the world's use )
    Everyone has the free will to believe as they wish; This information does not change any laws of Physics; or Science all this technology conforms to all
    the laws of Science / thermodynamics and physics; ( Conforming makes it work - it would not work if it did not conform )
    Hopefully; this will but useful; All systems presented have been tested and proven to work as said and shown; nothing is faked - testing can prove that in itself;
    Dr. Thomas Wlazlak - Energy to torque Conversion Motor - systems - Washington state - USA
    Looking forward to the information presented
      On 12 / 7 / 2022 A finished Prototype testing motor was tested for the first time
      This is a Testing prototype motor used to test a new type of design for an Electromagnetic Coil that converts Permanent Magnetic power into
      usable Kinetic energy of motion;
      Using 2 coils on this design that is all that is need to test the input to output ratios developed from the use of the Permanent Magnetic materials use
      Because Permanent Magnets can produce attraction to iron or ferrous metal that also produce kinetic energy of motion that conforms to the laws of
      thermodynamics; But ( does not use input energy to produce the output energy it produces )
      The electrical input power used is not being used as a means of producing output power of motion;; on the EttCM energy technology all the output power is being developed from the use of Permanent Magnetic power That is being produced by ferromagnetic induction to the iron or ferrous metals used in the
      field of the motor design;
      On The test done; the input used was in constant DC current ; 70 watts input power produced a angler torque of about 230 watts;
      The motor device is the testing device; meaning; the bearing friction is the means of calculation the amount of power produced
      The total RPM's The motor can produce is equal to the output power produced
      Saying The maximum speed of a horse is about 30 miles an hour. That is the maximum 1 horsepower of speed is produce running at 30 miles an hour;
      by a horse; because the friction of movement only allows a maximum speed to the output power produced; equal to the power it can produce; to the speed;
      The prototype motor maximum speed to the friction of the bearing is the maximum output power produced;
      knowing the friction produced by testing; and knowing the RPMs produced it can be calculated to what the horsepower is being produce and then the calculation to
      watts can be produced;
      The input power is known from the power supply having the output shown in watts
      The coil design is shown below; if anyone wishes to build and test for themselves;
      The copper disk are only for holding the wire in place; nothing more;
      The next post will show a testing of 2 different coil
      First is a normal iron type electromagnetic coil and the second test is the EttCM coil design
      Thanks; All the technology is being shown - Free Open source and public domain; for everyone's use all around the World; anyway that's the plan; ?
        The Pull Test
        In October of 2022 the first EttCM coil was built and tested
        Two coil were tested using about the same 50 watts DC current using a baseline to a normal iron core copper wound electromagnetic coil and
        A new type of coil design that is part electromagnetic and Permanent Magnetic as a dual energy output system
        The first test done is using a normal iron core coil
        This is the power supply used in both tests notice the watts showing 51.3 watts this is the input power used on the first test
        This is a normal iron core coil on a pull testing device built to test how much force the maximum pull to the watts applied;
        Notice the scale reads just over 1/4 lbs. pull or about 120 grams this is the maximum pull that this coil can produce at the 51.3 watts applied;
        The Second test shown below is the EttCM coil design
        notice the watts used is 50.8
        This is the first EttCM coil ever built notice it is just a little smaller than the normal coil used above on the first test;
        Again; Both test are done in the same way no difference between the 2 test;
        The scale reads 1 and 1 / 4 Lbs using about the same 50 watts input power but the EttCM coil that is the same type of coil in both test is about 5 times more pulling force
        to the ferrous metal plate; again this is the maximum pull that can be produced at the input watts applied
        Both test are true; and can be reproduced by anyone that uses the same type of testing systems;
        There is no limits to the type of designs that can be developed using this type of technology; and the system are about the same power output to the size of normal electrical motor system
        and the EttCM energy technology designs ( Again; There is no limits to the output power in designs that can be produced in this form of technology )
        On the prototype motor the real time test shows the same ratio in power factors ( The EttCM test motor used 300 percent Less energy input to produce the same as a
        normal unity type motor if the unity motor produced a 230 watts output power the EttCM motor only uses 70 watts input to do the same output power affects;
        Because the Permanent Magnetic materials do not use input energy to produce output energy in kinetic energy of motion;
        The next post will show how to produce a decreasing and increasing on a permanent magnets power
        Again; all the tests are real; nothing is faked; anyone can build and test everything shown; all is Free - open source and public domain; Thanks - Tom - EttCM energy technology
          What if Permanent Magnetic Power can be Changed and the power is not Changed
          The Permanent Magnetic power as it is manufactured can not be altered in its power of force ( remains constant though it live for many years; )
          But it is possible to Decrease it power of attraction to ferrous metals when 2 magnets of the same poles
          are mover together; each pole being the same make the magnets power ( less attraction in power )
          Note; A Magnets power from the manufacture does not change by ferromagnetic material coming it contact with the Permanent magnetic force;
          Iron metals in contact or close to a permanent magnet;
          does not decrease or increase its power or attraction made from the manufacture process;
          So; in using ferromagnetic materials the Permanent magnet does not change its built in power
          But using 2 magnets that are moved together having the same poles pushed together does decrease
          the magnetic attraction to the iron type ferrous metals;
          example #1
          In this drawing; on the top there are 2 magnets in a set ( first magnet ) North / South ( second magnet ) N / S
          The bottom is a single magnet pushing South against South -- 2 magnets pushing against 1 magnet
          The force of pull on the iron plate is about 1/4 Lbs. because the force of attraction has been reduced;
          A testing device was built to test this affect;
          notice; the set of 2 magnets pushing against the 1 magnet using a bolt and nuts to hold them in place
          A Scientific scale was used on this test and showed 120 grams of pull about 1/4 lbs.
          The second test was moving the sets apart;
ID:	517055 Click image for larger version
          shown above is the testing device; showing the same as the drawing above also;
          The pull is about 900 grams or 2 Lbs pull power; about 8 times difference
          between open and closed; The best part about this is; between the open and closed a device can be built
          that is balanced that uses NO energy to make the Decreasing and returning to normal power of attraction
          The attraction power is usable and what makes the power of motion does not use Energy to of the output to
          make the power it uses to Decrease and increase the power of attraction;
          in other words; The EttCM energy technology ( Does not use energy to make usable energy output power )
          ( This will be shown; it is part of the (( learning and teaching tools )) of the EttCM energy technology; systems
          This is the testing device shown from a top view down;
          The testing device uses the same type of ferromagnetic induction field as the Electric EttCM testing motor;
          how it works is the magnetic force is attracted into the field on ONE side power ON
          Going OUT the other side the attraction is OFF allowing it to move away freely
          ON going in and OFF going out; around and around it goes; ( without changing the power of attraction this technology could not work; ) and having the iron NOT affect the magnetic power allows no back magnetic EMF affects;
          to happen;
          The next post ; Will talk about why the ferromagnetic induction field is in the shape it is in; and how it works;
          Until then; fill free to tell others of what is being shown here; it's Free and open source - and so on;
          Tom ( it is all being shown for you the people of planet Earth )
          If it did not work; I would not show it here or anywhere;
            Tom, at this point, the best path forward is simple: bring your system to the Energy Science & Technology Conference at the end of June and demonstrate it livehttps://www.energeticforum.com/forum...nology-systems?
              Hello, Aaron: Thank you for the formal invite to your conference; I may be interested;
              We should talk about it;
              I would be interested in showing the concepts to People that may have the ability to grasp the concepts
              ( having some reservations ) Not all can understand what is being said; its common Physics and Science that is involved;
              We leave it at that; Well; somewhat?
              If you can; email me with the information and details on what you would like to have as a demo; we would not want it to be
              unprofessional would we;?
              I am not sure about the live; transparent testing conditions; its not a magic trick it only common engineering and physics;
              moving from Debate? ( That's a blank to me ) and demonstration; ( That has to do with the ability of the viewers )
              It just only happens to be a technology that no one else on the planet has or can understand how it is possible to work;
              that's all; The most impossible part about is not that it works; its the part about people understand how it can work;
              Thanks; Dr. Thomas Wlazlak Retired Scientist / Engineer / Artist - something form the past that keep on giving; don't ask me?
              When your retired; you really don't have to prove anything; People can either believe it or not; And that is what I tell people
              This -) My technology can be used if wish to do so; But no one on the planet need to believe or use it, if they simply do not want to; doing a live; Transparent test; and showing; people that will not allow themselves to believe what they are seeing is true;
              Again; the viewer concept of the knowledge; There has been a great effort to program people to simply say ( impossible in light of knowledge on this subject its a total up hill battle reteaching people new thinking on real concepts in Physics;
              Falls; back on the statement; Do it, or don't do it, but do it because you want too; simple free-will of choice;
              If one want to believe in something they don't understand; it is the same as not wanting to believe in something they do understand; all ending up with the same conclusions ( WHAT the hell is that )
              In the end it is a flip of a coin; is it worth doing; or does it really matter ? I'm retired - I'm only doing this as a hobby;
              and all out of pocket on my end; ( As it should be ) I never ask for anything from anyone for doing my hobbies;
              remember long ago I said we will Seed; and you said; did you mean See or Seed; I'm retired; does it matter?
                It is now time to continue ( The EttCM energy technology Learning and Teaching tool )
                The main Energy sources is made by Potential energy is ( Gravity or magnetic ) The Potential energy is converted into kinetic energy of motion
                This form of energy is called ( Cooldynamics ) energy; The potential energy of Gravity and magnetic attraction to Atoms;
                The EttCM energy technology uses 2 Potential energy sources for 1 output system of usable power that conforms to the laws of thermodynamics; this is also 100 percent Unity The EttCM energy technology is not; perpetual motion or overunity or free energy;
                All conforming to the laws of Physics and a Science based technology;
                How the Technology works using the 2 forms of Potential energy the first potential energy is in a balanced state that does not use any energy itself; It function is to ( Decrease and Increase the magnetic power of attraction to produce a kinetic energy of motion;
                The kinetic energy of motion conforms to the laws of thermodynamics;
                The first potential energy is like a balance wheel that takes very little energy to move and rotate;
                The Second potential energy is used to convert magnetic force into power used for the output energy;
                The Second energy - The power output is used to move the balanced wheel and produce usable energy and power output
                It takes both Potential energies to make the system workable; Using only 1 form of potential energy only produces a balance and will not produce extra power of use; note; this is what the people that say is impossible use as their impossible designs; shown;
                Using 2 potential energy inputs makes it possible to make a 100 percent unity output system work
                Using only 1 potential energy input makes it impossible to make more that a balance system; NO power output is possible;
                Note; Electrical power is already a 1 potential energy itself; using any form of electrical power on its own is the same as a having a balanced system of output; only the amount of input to output is possible; saying if 1 watt goes in only the max. of 1 watt goes out; No electronics changes that effect; no motor to generator changes that effect; one in is one out; only
                The EttCM energy technology using 2 form of energy for one output system makes it possible to have a workable technology;
                This information and the drawings and data that show how it works is being sent by emails to many Science and development groups worldwide; in order to make this energy technology common knowledge; open source and a little disclosure;
                This information has been presented so a person with a 6th. grade education has the knowledge to understand how this is possible and how it can work;
                Not everyone will receive a personal invitation to have the knowledge; but in time - The information will be common knowledge;
                So; anyone can have the knowledge if they wish to have it; Everyone can just use what is offered if it is in their future; to do so;
                Din Ma - Tom; Tell Later -
                  This drawing is a power output system That works on Gravity and Permanent magnetic Potential energy alone
                  The wheel is made with Cylinders filled with Mercury for Weight; the Gravity uses NO energy to make the magnetic inside the
                  Cylinders move back and forth as the wheel rotates; Moving the magnets apart at the Top increase the magnetic attraction to a
                  normal power of attraction of the magnets power; At the bottom the magnets are pushed together by the force of Gravity;
                  pushing the magnets together REDUCES the reverse power of attraction; this allow the wheel to move and rotate;
                  Because the Gravity and Permanent Magnets is Potential energy only no energy is used to produce the output power being produced
                  This form of energy system does NOT use Energy to produce usable Energy of motion and power output;
                  On the Right side the White half round line is the ferromagnetic induction steel plate shown on the testing device shown above
                  The steel plate is fixed not to move the Wheel rotates because the magnets at the top have more pulling force than the bottom
                  also shown in the testing devices above in those post; The magnets in the cylinders are sealed but can move freely
                  How this system Works; The Gravity of weight of Mercury has a greater amount of force at the bottom pushing the magnets together
                  pushing the magnets together reduces the power of attraction to iron or ferrous metals;
                  Note; The attraction to the ferrous metals does not effect the power of the magnets energy; it stays the same power in this the wheel
                  Remains in Constant Balance; having the wheel balanced makes it possible to rotate very easy using very little power from the output
                  developed between the High pull at the top and almost zero at the bottom; going out;
                  Because the Gravity is pushing down and the magnets are pushing away; Equal of Potential energy only ( no energy is being used )
                  The ( Kinetic energy being produced from the potential energy only produces energy but does not lose energy in doing this )
                  The main and only energy source is non-Energy; converted into energy of motion conforming to the laws of Thermodynamics;
                  The balance system does not change no matter how powerful the permanent magnets are made to be allowing a high power output
                  system to be developed ( note; friction is not an issue; in the same way as an electric motor friction is not an issue; )
                  The best what or reproducing this is on a Solid-works or similar program run in real time; Showing correct results of data; used;
                  Simple logic and simple understanding in Physics proves this system works; This is only 1 example of hundreds of designs possible;
                  For more information emails are offered with details and data; but limited to the basic knowledge of how this form of energy technology works;
                  Energy to torque Conversion Motor - energy technology systems; Or EttCM energy technology; ( email --- ettcmcorp (at ) gmail.com
                  Note; The information is given on the basis of personal knowledge in Science and physics; not everyone has this skill set;
                  This is a self- understand of knowledge in Technology; The proof is in the viewer in the understanding of the Engineering and Physics involved; to the understanding of how Potential energy is converted to energy; and under its own power production system; produces Work; E = CM The formula to the conversion of energy to power;
                    Tom has been banned for being an arrogant blowhard that is disrespectful and condesending to literally everyone. He talks big, shows nothing and the Dunning-Kruger vibes aren't welcome here.
                    Energetic Forum Administrator
                    http://www.energeticforum.com
                      Hi Tom ,
                      Do you know that all websites are under the control of the WEF? Also, all sites are full of WEF trolls. These are supposed to attack free energy. This has to do with the biblical story. We are currently in an energy crisis (script). This must economically destroy the West to make the biblical story come true. After that, we will have a holy war. In 2037, all the sins of the WEF will be made public. Those who stand on the side of the WEF (devil) are seen as sinners and will be destroyed by divine judgment. I believe the Bible states that you will be burned alive.
                      May I perhaps know which side you are on?
                      You don't need to be afraid of divine judgment; most people die within 3 years.???
                        I don't agree with the banning.....Tom has taught me some good things. No I don't like arrogance nor his style. Please reconsider.
                        Norman
                          Sadly Norman, he has been banned in every other forum that he was on. Has a bad habit of directly attacking anyone who disagrees with him.
                          • #14
                            There's not much I can really add, but has he at least ever shown any demonstration of his device in action?
                            • #15
                              and to clarify I'm not posting this as a means to attack this person, just out of genuine curiosity
