Hi all, experimenting with something that is easier and low cost to build and experiment with.
This version of the joule thief is based upon the supercharged joule thief circuit i noticed recently.
This modification to the circuit, increases efficiency dramatically.
Similar to the supercharged circuit, when tweaked with the right components, i was able to get the input down to 52%, of a standard joule thief circuit and very similar output.
This resulted in almost no heat discernible anywhere, except the bifilar coil, since that uses 24 awg. magnet wire and probably needs to be slightly thicker wire or less wire used in coil.
The 56Kohm resistor can be temporarily placed in position or a 1 Kohm resistor and then removed, once the circuit is in stable oscillation and the circuit will find its own natural frequency, based upon the non-polarized capacitor value.
I Have a fleet type Lawrence Tseung toroid air coil that i just built and will be testing that soon also.
At the moment, im using a multi-layer air coil with bifilar 24awg. magnet wire.
The goal is to achieve a high Coefficient of Performance, when charging lead acid batteries.
peace love light
peace love light
