Donald L Smith
  • please reply
    Originally posted by pranav2010 View Post
    is this working coil ?????
    can i do like this ?????
    can any one answer me ?????
    • working coil?
      Anything will work if it's set to the resonant frequency of the system it will be used with. Where did you find that one? I'm assuming it's going to be used as an output air core transformer....?
      ________
      • working coil
        hi dragon
        i found this on My Electric Engine - Main
        please tell me will it work
        • Originally posted by pranav2010 View Post
          hi dragon
          Looks like it would only take a few dollars investment and half hours work to make the coil up. Try it ...
          Will it work? That still depends on its intended use and careful calculations to match it with your system. It works for what he intended it for....
          ________
          • Comment
            • Good morning, gentlemen. To begin with, that collect and repeat this device is not able any builder, cemetery caretaker, an architect, designer ......... and so forth * and so forth * It needs certain skills, knowledge, experienced baggage, the concept of electro-and radio phenomena and processes. I want to in our Discussions attended as many of these people, and yet, in the first place, it is necessary that you be familiar with all the material Donald Smith (to the smallest detail), Melnichenko (slightly) and, of course, about the wave frequency what is happening there and how (I have a sore point). DIMA, lay out the scheme (you do we draw well) neonnika Smith, I sent you. Then I will use these phrases: (coil to), the presence of the core inside, and your favorite word "spark", replacing ions Ѝ conduction channel. While everything I write slowly like a turtle, and, In addition, even I am at work, so it will be intermittent.
              Well, let's begin, as always, left to right. The first is we Lattre. The delusion is that many people think that it adjusts AND TERMINATION NAPREZHENIE neonnika is wrong, well, I never met a high-frequency (HF) transmitters and PSU (power supply) or other devices to do that, they, on the contrary, the problem lies in the fact that they are in the input voltage changes are working stable and do not swim, so * is, if we take our network of 220 volts (110 in America), they tend to start between 150 and 300 volts, so that here no one should argue. When Smith's meth: "Have you changed the design neonnika?", He replied with a smile: "NO", and correctly, it is no need to change. Go ahead: we have socket - that's where he was cheated, but no one about it and did not ask. The question arises, why? My answer is simple: neonnik possible to consider a as a contour and no one stops us in it to enter another one frequency or more, and nothing it does not change, but in future it can change the course of events in a different direction and find it out, and for what it is to do so and not otherwise. Then we AMU NEONNIK, which brought us a lot of disputes and issues. Let's look at its structure in a big way, as he as carefully. At the plant in the entire household (and other) equipment connected by three wires, ie WORKING STAGE, WORKING ZERO and ground, zero and phase may change, because they can's turnover (in the U.S. and other countries is impossible because of the construction of the socket), and the land will remain underground. Further, Smith used batteries and converter for 110 (220) and installation is not tied to this stage to ground lead that he gave freedom of action to connect neonnika. I want to pay heed to connect the mid point of the output coil on Earth. (THIS IS when it is used the usual way), but here it gives us another entry frequency of 50 hertz per coil. In Dalny it will be very important, and, besides, we can adjust the amplitude Lathro 50 hertz. Well, now we come with 2 frequencies, and the way sharply to our primary organization of the alleged TESLA, but it is a continuation .....
              Quote: temptemp on April 9, 2010, 14:54:34
              algo, if I understood correctly, the point is that at the midpoint of the output transformer in neonnike served 50 Hz, whose amplitude can be adjusted. Do I understand?
              Furthermore, what gives us these 50Hz at the midpoint?
              Coil Smitty I have, but not just high-voltage transformer with a secondary point.
              Sorry, but a lot of work, the evening will finish, running in front, I would say that the coil will have to insert the core, and it will contain iron, and iron, and well ..... think about why someone in zagnuvshem matrix had a dream to get 8 kilovolts and at least 2.1 amp .... Well this is obtained, probably, somewhere may employ
              So, continuing the conversation about neonnikah, I want to say that when we zazhgli bulb Ilyich Meanwhile in the USA LAS VEGAS shone all in neonnikah and argue in their konstrukttsiyah no sense, acsortiment them exactly extensive. As regards the evaluation zazemleniya and its denouement (who is in the tank) razberite microwave and see what and how they (the tracker you tyknul) important belongs in komyutereom BP ...... regards SMITOVSKOGO, he just had a tuning frequency, it is necessary that the word resonance chastotu fepritovyh kolets, which will talk later. Weekend provoda rather likely, in neoonikah were with the resistance, ie, inside the threads were made of tungsten. And so we approach LC circuit that is the primary, if all connected by Cmitu as he suggests (and it is Our offer is true), then our system will not even start up, that is just iskrovik ionizes and no hesitation proishotit not because our roll, let them. Then we consciously or unconsciously thought Cmit wrong, and everything changed the design, and it is enough to throw one end of the capacitor in one another in the end iskrovika and our charm factory, and it turns a clean TESLA, but there is little joy, may lack the high, and Amp As always dumb (you can see in my video thread Cmita it-whether 1 or 2 page). Let's kondecator the place where he and the place, especially since Smith is very podpobno describes how to calculate the length of wire, how to calculate the resonant chastotu and a capacitor to pick up. Well, here again the blunder: He does not leave the calculations coil (the primary has an average of 3-5 turns) capacitors - 1 uF (2e their stuff) ie get 2 microfarads and all, if you count the resonant frequency, it turns out relatively small and does not tally with the frequency neonnika, which he recommends, but of course, all written off at the old man they say was wrong ...... No, gentlemen, all is well, calculations should be carried out with 50 cycles, they are the same we have already in the process We also let them have too on the same provodu! Further to our chain SPARK GAP, if the primary inclusion in TESLOVSKI, there are MRAC: strelyaet, the sound .... and that only we are not invented, cduvat, interrupt, magnitnom field effect ......... etc etc. Here to make NECHEGO not have to. His task in this place AT ALL OTHER. Namely: CREATE IONIZIRUSCHY conducting channel !!!!!!!!! Let us, gentlemen, put the capacitor back in place, and try to include everything from Cmitovski, looking anything but the position of the iskrovike is ionaya arc, twist Lattre from a designated place arc starts singing at 50 hertz ele-ele heard, and of course a little bit tanstsevat (rights that the forum who said that the installation of 100 square arc Tansu at 50 Hz) again, look what we have, but nothing as always zero, and why? the answer is simple: a COIL OUR EMPTY. Well dobralis to PLASTMASCOVOY PIPES ...... To be continued ....
              And so, ladies and gentlemen, finding that imeem, we have a transformer, the channel is open, the chain has run 2 frequencies: 50 Hz and frequency neonnika already something (I confess, gentlemen, to q At yet no one did, but honestly ). Yes, Grandpa Smith Our offer after neonnika hang diodes, then the frequency is multiplied, probably for 2 - You claimed in postranstve Internet. Well, it is necessary to check, but the grandfather says, and it is optional. His main words Consult. Before turning to the tube, let's talk about secondary housing. As stated by witnesses, the grandfather took the clippers and the custom (she commissioned cdelana, it is on sale now) and just wound off from the middle of it a few turns, and took a bite kusachkami because, allegedly, it was easier to calculate the resonance secondary housing, no, gentlemen, with them we budem shoot good and mean response goes, I will say straight out: it did for the third coil, so that none above it hung and did not interfere with resonance, yes the 3rd, we have not even seen (must be someone to resonate. the primary we have a hammer) and semochnye coil so were on the edges (as proposed by Melnichenko). Well, we nalichie main speaker power ...... trouble nashem consciousness - how we love the emptiness and the presence of something is the wrong word, Udaryaem the bells, the sound goes up to several kilometers, and all cry out: "There is a resonance ", and the bell let, but kogda get something heavier (power) does not understand I want to become, where it lived and in what direction moves
              ...... smoko
              And so PIPE (the one at Cator Cmita agile) where trouble is that nashi replicators all shakes under a thick layer (but not electrical tape, and then everyone was asleep, and will stink), I do not know in ruscki this material, we have it on another call, and grandfather all had steeper SMITH: paint everything under white color, and there you tube, pipe and have someone to a translator said that she was plastic, even given the size. Let's look at the photo carefully carefully: we see that there is a ring in the middle, where our inductor, and at the edges, it's awful that all the photo tube is shifted, and we are all told that because they say catches the resonance, and these rings are only the holders to Coil boltalas. In fact, it is not. That, gentlemen, ferrite ring, yes, they dedyshki klascnye, thin, and they are responsible for the intensifiers, their frequency should correspond to the frequency NEONNIKA, OR, if it hangs diode in the primary, as I had mentioned, it is supplied Get on the primary. Start the system and fail again, and again zero. If you put near the compass, then it will show that this magnetic field (magnetic field), no. Question: where is the much expected this response? and where at least poluchaetcya kakoe MP? But, gentlemen, have forgotten that our primary cell is 50 hertz, and the pipe we've never had no one to show his side, and that if it pihnut steel rod Transformer? Puts it, includes, as vsegda zero, cut it in pieces, ie the middle of the floor inducer, and at the edges through the gap under semochnye, start again zero, well, not quite. What is hvataet is suggestive, IS SEMOCHNYE, where RESONATOR ....... Smoke break
              Some words didn't translate using Google Translate but it's a start.
              Glen
              Open Source Experimentalist
              • Russian name] (slightly) and, of course, about the wave frequency, what is happening there and how (I have a sore point). DIMA [Russian surname], lay out the scheme (you draw well) of NST of Smith, I sent you. Then I will use these phrases: (empty coil), the presence of the core inside, and your favorite word "spark", replacing by ion conduction channel. While everything I write slowly like a turtle, and, in addition, I am at work, so it will be intermittent.
                Well, let's begin, as always, from left to right. The first is LATR [Russian abbreviation of linear autotransformerit's incomprehensible after] sharply to our primary organization of the alleged TESLA, but it is a continuation .....
                algo, if I understood correctly, the point is that at the midpoint of the output transformer in NST served 50 Hz, whose amplitude can be adjusted. Do I understand?
                I have a Smith's Coil, but I don't have just high-voltage transformer with a mid point.
                Sorry, but I have a lot of work, the evening will finish, running in front, I would say that we will have to insert the core in the coil, and it will contain ferrite, and iron, and think well about why.... Someone had a dream to get 8 kilovolts and at least 2.1 amp .... Well this is obtained, probably, somewhere may employ
                So, continuing the conversation about NST, I want to say that when we light the bulb of Ilyich [here he speaks about a first electric bulb in Russia named the bulb of Vladimir Ilyich Lenin? one word is absent and it's very difficult to understand]. Start the system and fail again, and again zero. If you put the compass near the coil, then it will not show any magnetic field. Question: where is this so expected resonance? and where is the magnetic field at least? But, gentlemen, we have forgotten that our primary cell is 50 hertz, and the pipe we've never had no one to show his side, and what will happen if we put a steel rod transformer in the coil? We put it, turn on, and as always we have zero, we cut it in [two?] pieces, i.e. the middle of the inducer, and at the edges through the gap under output coils, we start again and we have again zero, well, not quite. What we need once more, we have an INDUCTION COIL, the OUTPUT COILS, and WHERE IS A RESONATOR ....... Smoking break
                • Still unreadeble for me
                  I think hew is talking about NST working as normal but being fed by another pulsing circuit and it is by dimmer (or rather flasher) which do that second pulsing.That would be natural for ma because HV output would be now pulsed and allow for very fast charging capacitor.Correct me if I'm wrong.
                  • DonLSmith_Algo
                    Hi everyone,
                    I need to say that for a first time in my life I meet such kind of Russian and enormous quantity of errors, practically in every word ! I know Russian very well, but it was unreadable for me also. Perhaps this man knows well electronics, but not a basic grammar.
                    • Comment
                      • I was looking over the Correa Pulsed Abnormal Glow Discharge patents, and it reminded me of the Smith circuit....
                        What if you were to take the resonating center tapped secondary, and put a PAGD tube where the 3 terminal spark gap is....
                        Have the center electrode from the tube go to the - output, and the center tap is the + electrode.... The arcing back and forth from the 2 outer electrodes to the center provides free electrons, the plasma glow contributing to ionization and electron avalanche... A single diode should rectify it, no bridge needed.
                        I've been thinking lately about winding a magnetic diode for high voltage rectification, like Tesla's patent
                        see figure 6
                        • Hi everyone,
                          I found this interesting information from Russian site:
                          • Translation? (I can google it, but since you are a native speaker, perhaps you could clean it up a bit?)
                            • Not sure what this has to do with Don Smith rather than with Ed Gray, but it sounds as promising as it sounds vague. Needs some investigation.
                              • Basically this guy Valeri Dudishev has figured out how Tesla powered his electric car from the mysterious box with some vacuum tubes inside. He says that an ordinary vacuum tube can be used to produce great currents up to 10KW if anodes and cathodes of the triode are cooled. All you need to do is apply short impulses of positive high voltage to the grid of the triode and the HV ground goes to the anode. This way cathode emitted electrons are accelerated to the anode in a avalanche fashion and then this current goes through the load to the cathode and is again recycled and accelerated.
                                Hope this helps and hope I understood everything right.
