Donald L Smith
  • dragon
    Originally posted by h2ocommuter View Post
    Thanks Dragon,
    That Post does certainly have relationship significance in many ways to my application. Thanks for pointing it out.
    I seem to have tried everything I could think of to extract some potential and curent out of my plasma globe, as usual, but with this pic I see something labeled A and B directly next to the load. can anyone determine what this is? maybe inductors?
    That I am having trouble with about the transformer is, as you suspected the three poles are a center tapped side. and the other side does have choises that include 208 V 220 V and 240 V and Zero V they are all connected on that side as well. My question is like this, what side do I hook up to the circuit breaker panel "My load side" so conversly, which side do I hook up to the plasma globe setup.
    The center tap throughs me off, as does the zero voltage lead.
    I do want to feed my 240 circuit breaker box with two hot leads.
    I never heard of a center tap before hearing of DS's things so I am surprised it is used in other applications
    I know this is so basic, but I have never wired up an IT before.
    The " A and B " in that picture would represent the "nodes" where the hairpin would have an excited field. Shown in the Tesla picture below it where the lights are positioned. This would have to be experimented with to find the highest potental by moving the load around on the hairpin to find these nodes.
    I'm assuming your trying to use the transformer to step down the HV and use the lower output at higher amperage to drive a load. I would imagine, and I'm just speculating, that you would connect one lead to the 0v lead and another to one of the other leads that are marked for different voltges. The other side ( output ) would give you 2 sets of voltages depending on which pair you used. The outer two would be the higher voltage where the center tap and 1 outer would be at 1/2 that.
    Most iron type transformers can't deal with the high frequencies so it would be imperitive to lower this frequency to a point the transformer can move the flux around properly. A spark gap should be able to control the frequency but it will take some tinkering to find the most efficient output based on what your putting into it.
    Thanks for the Dollard video link the other day, that was an interesting set of experiments. I set up a system to test with only 3 links and the results ( as stated ) were very enlightening. I wasn't aware of the fact you could move both magnetic and electric to one end of the string. Quite interesting...
    ________
  • mlurye
    Anybody can give me some good advice on how to tune spark gap to oscillate at 200kHz. NST I'm using is 3KV with center tap, so working voltage is 1.5kV.
  • baroutologos
    Thanks amigo for the elaborate reply! I enjoyed that
    By the way, since the voltage arrestor is just a volatge arrestor, where might the ground be? From photos cannot be seen any ground. Perhaps its hidden?
    We know that a High frequencies, one wire-electrcity transfer is possible, yet one way or another, a ground is needed or current stops.
    Yet a second consideration without a spark-gap, is how to match NST pulsing with LC parallel tank circuit since they seemed not to be in the same frequency range. Any ideas?
    In any case, with or without a Spark-gap, yes we are dealing with plain resonance here. Not TEsla hammer-like cap discharges, nothing like things.
    Pure extra high Q, high frequency, high (relatively) voltage LC tank circuit that manages to stay if not to surpass 2-3 KV range.
  • h2ocommuter
    Cap. configuration and design / Transformer clarity
    Check out the link in my last post to give you a better idea of the cap placement. In an AC configuration the caps are constantly changing polarity. Sort of an "on demand" use. In a DC configuration the caps will store energy similar to a battery which can be used at will.
    You sort of lost me on the transformer idea, It looks like the input has a center tap ( or output which ever it is ), and the other side looks like it could be used as various voltages. I'm not sure, you'd need to poke around a bit with a meter to find the variables between different points...
    Thanks Dragon,
  • deggers
    UL 2161 Neon Transformers
    It seems as though a lot of the newer NSTs have ground fault protection. Perhaps this could be causing a sinifigant loss of output power in Don's circuits. See this PDF from Venetx.
    http://www.ventextech.com/pdf/Neon_Appl_Guide.pdf
    Also, doing a Google patent search on Bertonee will give you some schematics of their older units. Check some of the Citations and "Referenced by" also if interested.
    Nothing ground breaking (except for Robert E. Iannini's "Love Meter" perhaps)
    Just some info for those interested.
    I'm trying to figure out if a NST is the way to go, or else I'm going to make/buy something better suited for Don's device. (Tabletop-sliding coil design)
    I've done enough reading for a while. Time to make something go bang!
    Duane
  • amigo
    Tonight I though to try something out as there seems to be much confusion about the primary section of the circuit.
    A simple experiment, a center tapped transformer 110V 60Hz to 2x13VAC, and two 1N4005 diodes. Since I don't have a real ground, I used a water pipe connection.
    Per DS's circuit, imagine the transformer being the NST, center tap is our balanced mid-point grounding, which is connected to the ground (water pipe).
    Each end of the secondary goes to its own diode, and the two diodes are connected on the other end. There is no capacitor or the L1 coil as we are not emulating parallel LC tank here - not important.
    Also, there is no GDT in my test, as the voltages are insignificant. Even if we were running this in the original circuit full blast, I do not believe that GDT acts as a spark gap but only as a surge arrestor, as it is designed to do.
    You will need a scope for this test as it's much clearer what's happening. Scope lead is connected to the diodes while the ground is obviously going to the ground connection.
    As baroutologos suspected, this diode configuration will pickup up only positive parts of the cycle and combining them you end up with 13VAC at 120Hz, or 12VDC, depending what you choose to read on the scope (I used a Fluke ScopeMeter 124 for this test).
    If this was a power supply unit, one would stick a big ass electrolytic capacitor between the joined diodes end and the ground to straighten that wave and get pure DC, but that's not what we are doing here, are we?
    Going back to DS circuit, let's assume he's using a 12kV NST, balanced mid-point grounding one, so 2x6kV. Considering the diode configuration it's really giving him 6kV at 2x the NST pulsing rate, if co-relation to my experiment stands, no?
    Thus he only needs to deal with 6kV at the output. Fine. We can understand now why the 4kV capacitors in the LC tank circuit. But wait.
    If he's half-a-good engineer as they say he is, then he would choose capacitors that are rated at 2x the circuit voltage, or at least 1.5x. So his voltages can not exceed 3kV or if he wants to play on the edge, 4kV, but I doubt it, or he'd burn his caps.
    Therefore when he says that the circuit works better at lower voltages, I believe it's because the circuit will burn the components if he pushes that dimmer higher. Incidentally that's one of the reasons there is a dimmer to begin with.
    Now, let's go back to the GDT in the circuit. I hope you read my previous post above and that quote I included. If you read up on GDTs they are mostly DC devices, used in TeleCom and similar fields for circuit protection. They are not meant to be constantly on, as a real spark gap would need to.
    In DS's circuit, GDT serves exactly the purpose it is built to do - surge arrestor. I would assume that the one he used is probably 2kV or perhaps 3kV as I would not put a 4kV one at the risk of burning my capacitors in the LC tank. So, I believe its purpose is to protect the rest of the circuit and as DS himself says, to limit the output voltage to acceptable levels.
    Thus the practicality of GDT as a spark gap gets thrown out, especially if the quote I posted is true, regarding GDT remaining shorted until all the current is removed. And, just to remind you, primary is a parallel LC tank so we are dealing with currents not voltages.
    I hope I made sense and invite your comments about the above statements.
  • dragon
    Odd feedback
    Originally posted by baroutologos View Post
    Parametric oscillation or not, below i present my understanding of the (non-functional?) table device of Don Smith.
    It seems that pure, high Q resonance is employed in his primary (parallel LC) tank circuit. Note that he has isolated FULLY the NST when not pusing the circuit. One end by the diodes and the other via the voltage arrestor.
    This was (the peculiar old 2 spark-gaps arrangement) we have no electricity trasmition back to NST via one wire (well known fact anymore at high frequencies).
    Voltage input can be regulated 0-9 KV say. this is set up so as to capture only the possitive cycle. Again this cycle seems to be x10 times longer that the LC circuit, in case the PVC has not any ferrite core (as Don has shown in other setups) thus lowering frequency.
    The NST theoretically should pulse only during the appropriate phase of the cycle (thus helping the LC to resonate and gradually increasing oscillation's amplitude (amperage) thanks to ultra high Q and to a point of course.
    That appropriate synergetic phase is defined by the spark-gap breakdown voltage and main C element's polarity and voltage level (at that instance).
    (Note in what i am suggesting cannot be parametric oscilaltion. At some short point at best resonance is maintained as undamped waves)
    Regarding the output circuit, i cannot grasp what DOn says. It seems a plain collector via air tramsformer action to me at this moment. In any case the frequencies involved and the capacities etc make no sense at calculating wavelengths since they go far beyond the lengths of the table top device.
    Considering the ground usage, i have thoroughly conviced myself via experimenting that at high frequencies, the ground has beneficial attributes (do not knwo why yet) regarding efficiency of output.
    @Dragon,
    You are the most experienced here in practical terms with resonance regarding efficiency on potential OU behaviour.
    It seems that you can enstablish a HUGE resonance of high Q only to exploit a tiny part of it.
    E.g. in a 50 Hz circuit, you could have 300 volts in the caps and 10 amps circulating (a virtual 3Kw) still to be able to "extract" via low resistance loads some, say, 100-200 watts at an expence of less watts for maintaining the large resonator from being rang down.
    Is that the case? Plain resonance? Could Don Smith devices could just be that what he says? A plain air core high frequency resonator and nothing else?
    Baroutologos
    I appreciate the vote of confidence, I'm still learning like everyone else here. The set up I posted some time back - is a basic input section of dons device - identical to your drawing ( without the coils ). My NST is a 2 wire version - 12 volt input. 2500 volt output. (Ventex 4015-12).
    I noticed after pulling the input power from the unit there was a continuous low grade spark across the gap and the unit continued to operate. Below is a screen shot of the unpowered oscillator. There are 2 levels of oscillation, the smaller group is at 333 khz and the spikes are at about 1:10 ratio or about 33khz. The spikes will continue for about 10 hours but the frequency of the spikes will degrade continuously. The smaller oscillations never change and as far as I can tell they don't quit. This has to be something from the ground connection. As long as the spikes continue it will energize a neon bulb, not bright but very noticable. Basically a visual indication that the circuit is indeed energetic.
    The spark gap is made of Tungsten/thorium rods, before I was using basic steel which would corrode over a period. I thought a better grade of metal would extend the "spike" time but it didn't seem to change. I actually had quite a difficult time getting the spark gap set to duplicate the same results with the Tungsten rods.
    Because of the arrangement I realized I had to consider the spark gap as a very low capacitance in its operation. As it continues you can't visually see a spark but it might transfere electrons similar to an air capacitor. The diode junction time most likely plays a part on it as well but to what degree I'm not sure.
    You cannot remove energy from the system but I believe it might be possible to utilize it in a way that wouldn't disturb it's natural operation, unfortunately so far everything I've tried has failed. It's quite interesting just in the sense it will oscillate for so long without power... I think there is more to it than I understand.
    ________
  • baroutologos
    @Dragon,
    Baroutologos
  • boguslaw
    I think you are on the right path.Could someone draw a plot of parametric oscillator output with synchronized in phase square wave driving FET on twice the resonant frequency of parametric oscillator ?
    You might see something interesting there...
    That was something I found 3 years ago but I missed that point...
  • baroutologos
    But the way, i checked the caps from the photos of Don's smith device. They are really Cornel Dubillier of the CMR series, although the serie stops at CMR08 now and it is very small capacitance. http://www.cde.com/catalogs/CMR.pdf
    Indeed it could be easily customed made for Don's needs. By the way, the caps are plain caps of high reliability/qaulity MICA kind. They are quite expensive also. (another category 5kv 20nf MIKA kind of Cornel Dubilier sells as 400 USD)
    For some reasons MICA caps are the way to go. They offer high pulse rate as Mr Mckay has find out. MICA and vaccum caps are the best for the job. Apart from pulse operation they offer exceptional Q values.
    Anyway, no varicaps involved and the diodes there are of the VARO type at the slow frequency of NST 30KHz IMO cannot play a dramatic role in parametric oscillation except that of rectifying the current.
    Again the topology of the primary circuit does not make sense to me, assuming the NST has not caps inside that will discharge via the cap arrestor to the primary parallel LC circuit.
    Last but not least, using a simple Tesla Coil calculator, and making rough estimates, the typical LC resonance of the primary circuit is about 300 Khz (a harmonic perhaps of the NST?)
    Baroutologos
  • dragon
    Allright, Wow, right on the button.
    I have two quiries I could use help with here...
    I don't know if this is what I need to solve the charging cap thing I have going on. I cannot seem to be able to charge them. what I am getting is the sparks going all the way through the caps. The energy does not accumulate inside the cap.
    I am running the L-2 through the spark gap, then to the caps and LED's. then ground.
    The second problem is understanding my Isolation transformer.
    There are no labels on the unit except what you can read in the pics. so I am not sure which side is in, or out.
    Each side has continuity across the leads except for the Green ground wire at the bottom, it does not seem to be grounded to anything internally or externaly.
    Could someone shed some light on this for me.
    I hope nobody thinks this second question is infantile,
    ________
  • dragon
    Thanks Dragon for this insight. I was completely unaware of the parametric oscillators. perhaps Don makes use of the concept?
    I have seen devices based on this concept. One is in this forum http://www.energeticforum.com/renewa...html#post73799. Another is Hiddink's patent (same concept, plasma used as the second cap plate)
    J.L Naudin has tried (unsucessfully ?) to produce Ou with parametric resonance.
    Don Smith has stressed that the front caps are customed made. Is there any chance those little 100nF caps to be vari-caps instead?
    In any case, have we any evidence that parametric resonance is ou?
    Baroutologos
    The thanks actually goes to Armagdn03, he's the one that guided me in the right direction to discovery. I found you could recreate the effect using diodes and/or LED's in a tank circuit. Just like an LCR but replace the "R" with diodes pointing toward each other. In the middle of the diodes send a signal in, when it's in resonance there will be 2 distinctive peaks of 2 frequencies. The diodes will act similar to a varactor because of the time it takes to recover.
    Don's diode set up is most likely creating a similar effect. It would appear to me the cap(s) is simply to set the resonance of L1 matched to the NST.
    I ran into this the other day while poking around on the web, http://www.hvlabs.hu/zpe/Gruz/kapanadze.jpg , It appears to be a don smith device modified to operate a Tesla hairpin output of sorts. I thought it was interesting in it's simplicity... A translation would be nice for the details but most can be visually interpreted.
    I found it quite interesting playing with the parametric oscillator, but it would appear that even with the build up and ring down the average energy put into it would be equal to that out of it. The attachement shows one version of it.
    ________
  • baroutologos
    Baroutologos
  • h2ocommuter
    Parametric oscillator
  • boguslaw
    YES
    Parametric oscillator - Wikipedia, the free encyclopedia
    with feddback output to input.
