impedance matching
  • impedance matching
    wot is impedance matching
    Impedance matching - Wikipedia, the free encyclopedia
    Google helps too at a lot of Questions.
      On radiant charger, I translate it as the coil and the charged battery has to has the same resistance.
        On the ssg they match the wire # to the battery size and call it impedance mathing
          I am not the most expert in the field, but impedance matching has to do with adjusting a specific load to a specific generator output.
          This rule does not apply only to electrics/electronics but to mechanical systems as well. A simple mechanical impedance matching system is the gears of automobiles or a bicycle.
          In order to understand it in easy in electrical systems, magine you have a battery to be charged (load) and 2 kind of generators of 1000 watts power. One coil that outputs (say) 11 volts of DC at serious amperage and a neon sign transformer that outputs 30mA at 10Kvolts (shorted).
          For charging the specific battery, both systems are highly inefficient for those generator's potential. The first case cannot "push" electrons inside battery since battery level is 12+ volts and the other high voltage, works but the battery is charged by the 30mA or at best 0.03*12 = 0.4 watts say whereas the transformer has the potential of a KW.
          So, an adjustment of outputs is called impedance matching.
          From my experimenting with pulse motors (SSG and adams type mainly) i have found out that the collapsing pulse or spike or BEMF or say anything you want has if it happens on a low resistance coil has the ability to self-impedance matching itself to the "load" or output, either it is battery or cap.
          What i am saying is that, if i am using a 12 volts small battery or a large 12 volt battery or 24 volts battery (2 in series) or caps to be charged at high voltage, the efficiency is more or less the same with capturing the spike.
          As i see it, if the collapsing spike does not encounters much impedance to its path it creates considerable amperage, whereas if it does encounters considerable impedance (a cap already charge at say 100 volts) creates far less current, but in any case the most of magnetic's field collapsing energy is captured anyway. That i have found out.
          So in my view, you should not worry excessively about impedance matching your SSG. have it as low resistance as reasonable and you are ok. As long as you keep the spike high voltage.
          Good core is a must to efficiency and spike. My best results over 70% have been achieved with solid state and extra thin laminations of superb quality for sound applications.
          Finally coils so far i have been experimented are standard 900 turns 22-24 awg, 10-fillar 28 awg at 110', 6fillar 24 awg at 300', 3-fillar 18awg at 100'. More or less, all output the same efficiency.
          Baroutologos
            There is also the maximum power theorum which is based on impedance matching and is relevant to these circuits...
            Maximum power theorem - Wikipedia, the free encyclopedia
                cheers 4 that
