iron sheet needeed
  • iron sheet needeed
    Im trying to build this The self sustaining electric generator
    iron sheet are the problem any ideas?
    Hi Bodkins,
    I wonder if you can use plumbing pipes for the outside 'primary'.
    I made one stubblefield generator from this. I was told it was soft iron which is the reason I used it.
    A metal roof from the old days, but probably not in UK.
    jeanna
      Any thin sheet metal not galvanized and flexible will be close to 95% +- iron.
      Anything thin counts less than 1/16 inch (1.5875 mm) or less.
      Thats about the best iron your gonna get outside of welding rods.
      Matt
        thanks you two 95% is good but it says The iron sheeting is to be in the range of 0.010" to 0.015". The iron sheeting should be as thin as possible as it is desirable to obtain the most powerful fluctuating magnetic field to be induced as close to the wire as can be physically and electrically achieved.
        if im going to gold plate this i need to be sure!
        jenna great work on the earthbattery
          Hi Bodkins;
          I expect automotive exhaust pipe would do quite well. 1 1/2" is a pretty common size.
          Al
          Antiquer
            china Flexible iron sheet magnetic sheeting soft magnet vinyl sheet flexible magnet sheet iron roll sheet
            The only other thing to do is find someone with an industrial hot metal roller and have is rolled out from cast product or somthing.
              gold plating...
              Don't forget the cherubs?
                iron sheeting
                Hi Bodkins;
                Sorry, I misread the diagram. Maybe these people have what you need.
                McMaster-Carr
                McMaster-Carr
                Al
                Antiquer
                  gold plating...or ... monoatomic gold?
                  I have been fascinated by the "white powder gold" craze.
                  It occurs to me that experiments should be performed
                  with white powder gold to see if there are electrical properties of
                  interest.
                  The human benefits of this material may be that the monatomic
                  gold attaches to DNA, allowing electric currents to flow
                  less attenuated.
                  Single atoms of gold may have properties quite unusual.
                  Certainly the Egyptians were interested in making the stuff --
                  or so the story goes.
                  It is interesting that this device wants gold plating on the iron
                  sheets.
                  Gold certainly is well known for its low resistance and
                  so it may serve as a better conductive material here only.
                  White power gold is rumored to be a "room temperature"
                  superconductor.
                  If you can remove resistance from an LRC circuit,
                  you can make it RING indefinitely.
                  Better still would be negative resistance ... regenerative oscillations.
                  There is great interest in these monoatomic materials..
                  Cookies Required
                  Future Technology From the Past
                    Originally posted by ANTIQUER View Post
                    Hi Bodkins;
                    McMaster-Carr
                    McMaster-Carr
                    Al
                    thanks this is a great place for stuff,
                    morpher44@dont get me started on the cherubs, been reading about cubits and solomans temple. may try and build this using cubits.
                    Matthew@ the flexible stuff cant be gold placed?. can you have a look at this McMaster-Carr
                    ANTIQUER sent a link and it looks good to me the size is to big but its a start.
