If the primary and secondary are in series, you would want the primary to shut off before the current reached the secondary.
Free
If you can figure out how to run this you will have the free energy you seek.
I shorted one set of coils in the circuit diagrams but if you could run in three phases would be optimal.
the only way I can see to run the gates would be with a mechanical switch.
just putting it out there
air core or maybe a single strand of iron wire for a core-saturated core to interact with the environmentYou do not have permission to view this gallery.
This gallery has 2 photos.Half of the Answer is knowing the right Question
Tesla worked in three's
He used a rotary switch
It must turn counterclockwise in the northern hemisphere.
Clockwise in the southern hemisphere.
It pulses three coil sets at once
This gallery has 1 photos.Half of the Answer is knowing the right Question
I was thinking about the inverted buckboost this morning, it is the perfect candidate for a center tapped coil and a dual rail output.You do not have permission to view this gallery.
I just cant see the circuit, the only arrangement I see that makes sense is this one.
the gate switching toroid makes sense but what is it switching.
I will come to meYou do not have permission to view this gallery.
back in the day Akula was bouncing a signal between two coils and he found that the diode was dampening the oscillations.
you get pos and neg voltage oscillating between the coils.You do not have permission to view this gallery.
