Hex-controller replacement
  • #16
    Originally posted by Groundloop View Post
    Do you have a link to the "Partic O kellys PJK book"?
    Free-Energy Devices, zero-point energy, and water as fuel
    /Hob
    Hob Nilre
    • #17
      @nilrehob,
      Thanks. My circuit is mostly done now. I only need to add 3 coils
      and assemble the metal box. If the 3 channel fast switch does not
      work as a charger, then I can use it as a battery de-sulfate circuit.
      So the build is not wasted anyway. But I hope it works as shown in
      the videos.
      Thanks for the link.
      Alex.
      • #18
        Originally posted by nilrehob View Post
        But how does he get the energy back to the *running* battery?
        The only way to do that, that i have seen so far, is by using two transistors/fets for each coil, and i cant see that in the video.
        /Hob
        You will no believe me but from the diodes cathodes it goes straight back to the positive of the drive battery through a little filter coil
        • #19
          I guess i'll put it on the list of things to try out myself
          So really sharp switching and fast diodes are the recipe for this circuit to work?
          /Hob
          Hob Nilre
          • #20
            Hi Groundloop. Any update for us? Your circuit looks interesting.
            • #21
              @rmitoday,
              My circuit is running well and is doing what I designed it to do.
              I have only run one test so far with a Ferrite rod core. Did not
              charge my lead acid battery at all.
              I'm flat out of enameled copper wire right now, so no more testing for
              a while. I was in contact with a person that could sell me some
              silver coated, Teflon insulated copper wire and a core, but I dropped
              the deal because I do not have any means to do a money transfer.
              So basically I have a nice metal box with a micro controller inside
              just dusting down at my lab right now.
              Alex.
              • #22
                @rmitoday,
                I will be receiving a toroid core and silver coated, Teflon insulated copper wire
                for this project in a couple of weeks time. Will be winding the toroid when
                I get it. Testing will follow after that. I will report any progress here.
                Alex.
                • #23
                  Iron or ferrite?
                  • #24
                    @eternalightwithin,
                    Once completed, the transformer will be identical to the one seen in the videos
                    on this thread:
                    Alex.
                    • #25
                      AWESOME!
                      • #26
                        Group,
                        My tests with the new transformer did not charge the battery.
                        I guess my switch is not fast enough the get the desired result.
                        When I say fast, I mean the rising and falling edges of the pulse.
                        I have tested at least 100 different SW timings and pulse durations.
                        The closest I got was a near unity result when the battery did not
                        charge but did not discharge either. (Or it discharged so slowly that
                        I could not see it on my meters.)
                        My attempt to get this work was a failure, but that does not mean it
                        could work for others.
                        Alex.
                        • #27
                          Alex i wish we could compare this with the Hex group would you join and post there Bro? THEY CAN HELP
                          Ash
                          • #28
                            Ash,
                            I've joined but get no confirmation mail.
                            A.
                            • #29
                              Hex Group?
                              Ash,
                              Which hex group is this?
                              Richard
                              • #30
                                @linesrg,
                                b-hex : Boyce Hex Controller project
                                Alex.
