Quest for fastest and sharpest solid-state switching
  • #16
    no digital meter
    When you want to see the true voltage or current, don't use digital meters if you are measuring something that is not pure DC or regular sin wave in range outside of ~40 to 200 Hz.
    If you do use digital meters on other wave forms, you can be sure of wrong readings and in some (not rare) cases your meter is in danger of being shocked and defected.
    Analog meters give much better, closer to true, readings in wider frequency range and other than pure sinusoidal waves.
    The error can be quite big. For example, I did some comparisons, where a digital meter (same model as in your video) was showing 0,01 A but in fact it was 0,1A (confirmed by oscilloscope) of alternative current reading. Then I changed to an analog meter it showed 0,11A.
    Or the digital meter was jumping from 14 to 140 V but on the analog volt meter was around 13 V.
    I have an old analog meter LAVO3 (made in Poland in 70ties), it cost olny 1,5 euro, it is accurate by ~3% for sinusoidal waves up to 100 kHz. My FLUKE87 become unreliable at this frequency
    I have check many old (over 30 or 40 years old) meters, they are still doing wonderful job. Get them if you have a chance.
    • #17
      Thank you, never though the difference would be that big. I just measured it with analog and it's true that it only give half of previous. It show a little more than 200V.
      There is little difference of current reading with DMM and AMM though. Using 300ohm base resistor it read 0.24A with digital and has around this number with analog. I can't measure 100ohm base resistor though, since in the digital it measured as 0.4A and my analog only have 0-250mA range max.
      • #18
        banki waste spark circuit
        Originally posted by nvisser View Post
        where is the banki waste spark schematic, anyone???
