  • This is Kapanadze First Circuit
    If this is the kapanadze circuit , this is called Tesla System of Lightning, This circuit actually works and will only work when you understand how the circuit function.
    S2 is a normal switch to connect the circuit.
    S1 is a make and break or spark gap, solid contact rotary switch
    L3 is a Primary coil, Lowest Resistance, A very big thick few turns Low self Induction COil.
    L4 is a High Self Induction Charging Choke COil, maybe coupled on the Transformer former to increased its performance, It is a very long wire coiled somewhere in the transformer coil.
    RH= Load is any Coil form devices like bulb, motor, heater, relay as long as a coil and will at to the High Self Induction Coil.
    When the spark gap fires, Shorting the Capacitor to the Primary at the same time building magnetic flux to the Secondary of the 12v to 230v and its now accumulating x2 energy . L4 and Load is a combination of High Self Induction Coil is also shorted and building magnetic flux now accumulated energy by the magnetic flux.
    When the spark gap off, all the High Self Induction coil like the Secondary of the transformer 12v to 220v , the combination of L4 and load will discharge(COLLAPSE) the accumulated Energy from the magnetic flux build up and thus charging the capacitor.
    Kapanadze only will excite / kick the system to start it. This circuit will work as I understand it from Tesla, it is another variation of Tesla Oscillator but will only light or heat or run coiled devices.
    P.S. Don't mind the frequency calculator or resonance, because it is a amplifying nature resonance everything is automatic, like just hitting a switch and the missile goes off. Everything is automatic. The Resonance you have long known from the classical idea is not the resonance Tesla was talking about. Tesla's way is Controlled Amplifying Resonance because of the Make and Break energy accumulated is being amplified.
    • Originally posted by dunfasto View Post
      hi utopia!
      the red coil frequency should be 21-30 mhz its range is 21 mhz to 500 mhz
      but 21- 30 Mhz works fine.
      the caduceus coil- modulator coil frequency is 50 hz square or sine
      the energy produced due to NMR in copper tube and ferrite combination.
      NMR is nuclear magnetic resonance and all persons like sr 193 don smith and kapanadze or akula or chubinidze doing this nmr tech and producing energy.
      Fabrice andre did same.
      there is no clear evidence of the radiation but if the coil module is kept in alluminium mesh box the radiation can be avoided.
      even thomas henry morey used nmr so did meyer.
      note : caduceus coil can be replaced with cw+ccw coil.
      red coil can be 150 turnsCOLOR="Red"]
      modulation coil can be 50 turns (turns needed to produce 0.5 tesla magnetic field)[and output coil turns depends upon the volatge required[/COLOR].
      keep yourself updated at
      Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
      scramble pages + and -
      Kapanadze Cousin - DALLY FREE ENERGY
      good luck
      dunfasto
      hi there good effort on the diagram, few questions...
      -how does the 50hz amp differ from the 50hz oscillator?
      -is there a slit in the copper tube, would it act like a shorted turn or its ok?
      -is the output coil wound opposite? it looks like dots are showing that, but written all coils same direction.
      -is there a thick primary? looks like copper is primary and to high turns coil.
      -are there any shorted resonant LC?
      -is the caduceus coil single layer?
      sorry for all the questions, and cant help to wonder, have you built this? how can you know it works?
      i DO want it to work, just curious
      -Shunryu Suzuki
      • [/QUOTE]
        ...When On- Parallel Resonance, When OFF Series Resonance. P.S. I will only answer Mr. Clean question and nothing more. I hate those people mock me when I wanted to share some results and findings. But his guy instead answer humble. I Like Mr. Clean because he is open minded and a good person.
        It is only the first stage, there are alot more to come.[/QUOTE]
        much appreciated, you are a good person too. i would never cast away possibly good information before trying. that's why I was wondering if tried
        -Shunryu Suzuki
          Hi Dunfasto, Thank you for the wonderful info,
          Especially the links to the other forum:
          We are happy and we will continue with all the new valuable info.
          Utopia Now ..
          hi utopia !
          orthogonal coils two layered. you will be needing this for ou.
          dunfasto
            hi mr. clean!
            oscillator produces just 5 volt or less output and we need like 20 volts for that amplifier is used
            its solid copper tube no slit.
            the tube is solid in case of fabrice andre but for chubinidze its split alluminium tube
            yes the output coil is wound opposite in fab andre
            in case of chubinidze thick copper primary tube wher as in fab andre its litz wire coil thin primary.-
            no there are no shorted resonant LC
            caduceus coil is not single layer ist multilayer. caduceus coil= cw +ccw coil= orthogonal coil multilayer. see the image i just posted of orthogonal coil.
            dunfasto
              send private message
              dunfasto
              • Kapanadze Cousin - DALLY FREE ENERGY
                magpwr posts
                dunfasto
                  hi mr. clean!
                  dunfasto
                  thankyou so much
                  -Shunryu Suzuki
                  • Originally posted by stupify12 View Post
                    The following picture is not the same schematic ?
                    • igbt or mosfet protection from frying!
                      read to understand 494 and phase splitter for driving mosfets or igbt.
                      dunfasto
                      • sine wave generator
                        dunfasto
                        • Now some info about technical aspects !!
                          Go on these links ... you can find here golden ore of informations in Free Energy area.
                          You need to register yourself and make free download.
                          For example Jorge Resines, Buenos Aires, Argentina - Publication(s) of Borderland Sciences from 1970th..
                          some-free- energy- devices- book
                          Energy Unlimited - The New Golden Age Science Magazine(s)
                          Energy Unlimited No 6
                          RE various OU compilation info from early 2007 at the EVGray yahoo group.
                          RE Various v1
                          Resonances of the Earth according to John Ernst Worrel Keely calculations
                          etc.etc.
                          ps: Many very interesting and important info you can find, download (and share) from here
                          Ernest Emery Richards
                          Ernest Emery Richards on Scribd
                          Informations are not a knowledge but are "The Bridges" which can take you over the wild river of ignorance. And save your life... and other people too.
                          • Question: How to invent Powerful Current Amplifier ??
                            Answer. No need to invent only learn how Mother Nature have done it.
                            Answer is very simple BARIUM TITANATE or BaTiO3 - Natural and perfect current amplifier. All you need is to excite him and harvest Free Energy. BARIUM TITANATE or BaTiO3 is an oxide of Barium and Titanium. It is a ferroelectric ceramic material, with a photorefractive effect and piezoelectric properties. He is insoluble in water, alkalis. Strongly soluble in dilute acids. Soluble in concentrated acids.
                            How to make personal barium titanate cylindrical capacitor in dimensions you want read here:
                            Barium Titanate Capacitor (BaTiO3)
                            You need TT (Tesla Transformer) and Barium Titanate Cylinder (CAPACITOR)
                            and you can start personal OU show.
                            Watch John Hutchison BARIUM TITANATE EXPERIMENTS
                            BARIUM TITANATE RF TEST - YouTube
                            free energy unit finaly - YouTube
                            Barium Titanate experiments free energy - YouTube
                            free energy now ! - YouTube
                            What will you get if you put BARIUM TITANATE CYLINDER in DON SMITH DEVICE COILS ??
                            NITRO !! (don't forget a GOOD EEARTH GROUNDING.. another BOOSTER)
                            Why Tesla had used the same Mass (weight) of his Primary, Secondary and Extra Coils ?? Because the main source of Energy is MATTER not versa.
                            ENERGY IS AN ATTRIBUTE OF MATTER NOT CONTRARY. For example "SPEED" of the car is an attribute of car. Without car you can't have a speed. It's Absurd. Same Absurd like "Speed of Light is a Constant". No it's not !!
                            When you accelerate matter (coarse matter particles -for example electrons) faster than light speed and than sudden brake it on some metal (matter) plate what you will get ??
                            New matter particles - very fine particles which had built bigger coarse particles looking from our macro level perspective. So DIG IT UP IN THE MATTER not out of MATTER. AETHER, ASTRAL and other levels of Cosmic reality are "LOCKED IN" matter. To get in another dimensions you need to go through "The needle ears". It's the only way out !!
                            • Originally posted by SERG V. View Post
                              Do you know other properties of barium titanate based ferrites or magnets ?
