  • @ clarence
    Thanks. That is excellent building guide. Was Don Smith the author?
    • Originally posted by xilo View Post
      Hi Soundiceuk!
      Thank you so much for your reply with update. Thanks for the quick response. You are very helpful guy.
      Latest schematic v1.3
      The above link didnt work reporting page not found. Can you please post a working link? for Latest schematic v1.3
      Thanks in advance.
      Best Regards
      Xilo
      Here is the final version Xilo, no more edits. I'm sure the smart ones will come up with a few tweaks to get more power
      A MASSIVE THANK YOU TO PATRICK KELLY FOR POINTING OUT THE MUCH NEEDED LIGHTNING ARRESTOR!
      -TEAM ION VALVE -
      RADIANT ENERGY POWER RECEIVER v1.5 FINAL VERSION
      • @ soundiceuk
        What is an anti static electrical conductor and where are they available?
        • Originally posted by blackrobi View Post
          Originally Posted by zilano View Post
          easy option:
          use voltage divider between ht and primary input so u r saved from rewnding coil again. U WILL HAVE RIGHT INPUT VOLTAGE TO PRIMARY AND WHEN RESONANCE HAPPENS U WILL GET RIGHT VOLTAGE IN SECONDARY AS U WANT.
          usa a variable resistor between battery and your flyback so u dont have to use the voltage divider and u can control voltage at source so your flyback will have required voltage for your primary.
          So you mean that the fly-backs outgoing voltage be less then now let say 1200V and then there will be on each turn 240V meaning that the secondaries output will be about 6240V
          1200V is enough for the HV module output.
          Well I cant think any more, see You!
          yes, Don achieved the same thing with variac when he was using ac driven Nst. here u r using dc driven flyback so u have to use a suitable variable resistor to control the input fed to ur flyback. less input to flyback less output voltage at flyback and so on.
          rgds
          zelina
            A bit off topic but still my post should be interesting who study E. Leedskalnin work:
            Help with Ed Leedskalnin Riddle , any idea .
            Hello,
            I am looking for replicators who can assemble E. Leedskalnin flywheel and PMH in a way he did. Please let me know if anyone is willing to do hard work
            I think I finally did put puzzle pieces together on E. Leedskalnin generator and we had proof of his fuelless generator almost for 70 years..
            So instructions to remake one should be as following:
            1) The flywheel is made from same pole magnets what are squizzed together by force to make sharp magnetic poles. Because of that we do not have strong magnetic field in then edges on the magnets. The strongest point is only in place where two same poles are did put together. With resonant spinning they make maximum electricity in PMH and cause no drag. Bye bye Lenz law if I am correct...
            2) The 3 poles are fit in depth of PMH.
            3) The PMH is inside of metal core (the box in photo). That amplifies magnetic currents (in E. Leedskalnin book).
            4) The spark gap is used to take power out of high voltage from PMH on peaks only when magnets are approached already. NO MORE OTHER CONNECTIONS what are killing free oscillation!
            The copy of photo is in http://imgbin.org/images/8388.png
            The analysis of flywheel is in Flux Flow Analysis of the Edward Leedskalnin Flywheel | Energy Research
            Free Energy Demonstration - Delayed Lenz Effect - YouTube
            the only free energy Leedskalnin machine is PMH itself. used with diodes to charge cap. it doesnt even need to use any mechanical power or priming electrical power to generate power. its based on earths magnetic field. we call it TPU.
            rgds
            zzzz
            • Gfci Use
              Thanks for your help! however my uploads failed. Pull up the link FreeEnergyInventions.com and you will find all the info for photas, materials, background, operating description, etc. Note: the neon power supply used is no longer availabe because all the power supply companies changed their units internally to GFCI scenario so now they are useless for use with any free energy devices since they see any earth ground or spark gap in a circuit as a fault and auto trip!!!!! (@#$%&*() nice words really. I noticed a china supply unit mentioned to XILO earlier that could be used instead maybe. try the info and enjoy! mike.
              Thanks for bringing this up.
              I am thinking about getting a NST.Still concerned about the GFCI, to counter that I am thinking that if we just pulse one side of a capacitor with the positive leads, would the GFCI still trip? The neutral would have been left ungrounded.
              Any possibility of this working?
              I have found my flyback to very reliable.I have actually been collecting em from tv repair shops along with capacitors and assorted stuff.I try to have them in various sizes.The unfortunate thing is that I am not certain of the voltages.They are definately over 2000 volts based on the length of the arcs in the sparkgap.Fortunately,I took a chance and got manageable voltages from the other side of a homemade capacitor.
              LtSpice is definately worth trying out.The evidence is not concrete,but trying plauson,albiet with no spark gap and various combinations of capacitors and modified circuit designs from are showing some striking results.I do feel nervous about the outputs I see sometimes showing up when i tweak values.
              There is so much to learn.
              I would like for Zilano and T-1000 to finish their last dialog.I found it quite interesting...
              best regards,
              ged
              • Inline embedding.Good stuff
                Originally posted by zilano View Post
                when u upload the pic on this forum it shows as thumbnail in the post u posted. now go to ur own post and just right click on the thumb image of ur own post and select open in new window. another window will open and will show u the larger image of the pic u saw in thumbnail. again right click that big image and select copy and come to ur own post page and click edit it will open the edit window to edit ur post. now where ever u want to paste the picture in ur own posted text just right click and select paste and ur image gets pasted along with ur posted text.
                its called inline embedding pictures. same way u can paste any image along with text. the same feature apply in emails too.
                rgds
                zzzz
                Thanks! I've always wanted to do this but never got to it.
                Goodstuff!
                Ged
                • Originally posted by xee2 View Post
                  @ clarence
                  No- smith was not the author. the author was a member of freeenergyinventions.co. however don smith was the designer of this exact build as it was one of his earlier devices as shown in my attachments. notice the exact similarities as you will see. thanks for reading, mike.
                  • Originally posted by soundiceuk View Post
                    -TEAM ION VALVE -
                    Hi Soundiceuk!
                    Thank you! so much!
                    thats awesome!
                    Best Regards
                    Xilo
                    • Voltage on L1
                      Hi Zilano Hi All
                      Well thanks for that but I ment to achieve to control the outgoing voltage from the source output /flyback /
                      Please read this
                      if you read the PDF then you will understand this:
                      9V battery and 17 turns = 0.53V by 1 turn
                      3400 turns * 0.53V = 1800V the flybacks input voltage
                      L1 coil with 5 turns will have 360V on every turn
                      Now how the calculation goes with L2 split coil
                      as L2 have 2*13 turn what will be the output voltage
                      1: 360V * 13 turns = 4680V
                      2: 360V * 26 turns = 9360V
                      Don Smith uses 8000V capacitor on the L2 side, and if the NST output is 2000V then L1 with 5 turns will have 400V on every turn, and as the L2 has 2*17 turns or 34 turns then the outgoing voltage would be
                      1: 400V * 17 turns = 6800V
                      2: 400V * 34 turns = 13600V
                      Did he take only one side of the coil for voltage and the other side gives the amperage
                      which one to follow?!
                      rgds blackrobi
                        Hi Zilano Hi All
                        Please read this
                        rgds blackrobi
                        don coils work like 12-0-12 transformer if u leave the middle end and take output from extreme ends the voltage will be 12+12=24 volt
                        if u join extreme ends and take output from joined extreme ends and middle tap then the voltage is 12 volts.
                        the 17 +17 turns joined and middle tap will give you 6800V
                        else if u take output from extreme ends leaving middle tap then ur output voltage will be 13600V
                        u have to do hit and trial method. use a variable resisitor able to handle atleast 5 amps and connect in series with battery and the oscillator circuit of ur flyback keep it lowest and try to run ur circuit. and slowely increase it so u get optimum voltage on secondary that u want.
                        if u could measure the hv of ur flyback voltage with a hv probe if u have one then its easy. else u have to do hit n trial method using variable Resistor in series with ur battery.
                        DIY High Voltage Probe for digital multimeters
                        Fantastic high voltage meter or probe to solve complicated repair problems
                        rgds
                        zzzz
                          Hi Mike!
                          plz post the link in reply. copy the link of website and paste it in your reply. so all members can see the page u r refering to.
                          thank you for ur effort and zeal!
                          thankx for the info and welcome to the forum!
                          regards
                          zelina
                          • step by step
                            So far it is clear!
                            Well there is two PDF that I have posted, according to achieve stable source for this device.
                            In this PDF I post a schematic of the variable source from 2-30V
                            In this PDF is a driving circuit for flyback and the calculations that are mentioned
                            To step forward I need to achieve the skill how to get resonance between L1 and L2
                            That will be a Little step to mankind
                            , but a Big step to me !
                            • This video shows work similar to ThaneCHeins - YouTube long term research, you should see REGENERATIVE ACCELERATION INDUCTION GENERATOR - NRC David Lisk Video 4.mov - YouTube ..
                              High voltage coils in generator are starting to be driving coils on certain rotor speed (resonant frequency) and help motor to drive rotor while generating electricity!
                              It is not same as E. Leedskalnin was doing.
                              • Originally posted by zilano View Post
                                Hi Mike!
                                regards
                                zelina
                                Hello Zelina-the page I was referring to was at freeenergyinventions back in october of 2010-since then when I pull up the site I find it has been sold and dont have the former sucess with the page- however I did save it to my computer back then and I did just post the pieces of info as you can see above in the recent posts. thanks for you reading and interest, mike.
