  • Thanks!!
    Boguslaw,
    Thanks, great information!!
    Best Regards,
    David Fine
    Someone asked me about L3 coil. Zilano posted once a schematic which I liked very much because it was a proof of my concept about device which variation is used by Kapanadze also. Instead of using big step down transformer like Dynatron we can use L3 coil of copper tube or rod.
    In my personal opinion this is the mistake everybody made about Kapanadze device. I think that copper tupe thick coil is not primary coil like in Tesla coil but it's output coil like in Zilano schematic. Think about it and everything will match.
    I think Tariel and Don Smith both said and had shown enough to construct working device when you connect both info.
    • Hi boguslaw,
      There would be no danger at all if you have a properly constructed coil since there would not be any heat.
      • Comment
          I have strange and interesting problem trying to step up voltage from Joule thief output - it stuck on first stage)
          Joule thief is not a good choice for driving a diode voltage multiplier. A diode voltage multiplier should have sine or square wave input. A Joule thief usually generates spikes. If you have a scope, look at the Joule thief output. If it is a series of spikes you have probably found the problem.
          • Originally posted by xee2 View Post
            I know that, I saw spikes but I don't understand why I can't step them up. They look like spikes but actually they are a mix of half-rectified sine just high frequency.
            • Interesting summation, I believe I've been saying this all along although it appeared to be falling on deaf ears. With the exception of one outstanding individual.
              Without the actual work and seeing the effects you'll never understand.
              • Zilano Circuit Request
                Hi,
                I need the Zilano Kapanadze Alien Team drawing if anyone has it. Thanks!!
                Best Regards,
                David Fine
                [email protected]
                  A diode multiplier needs positive and negative current flow at input to alternately switch the diodes. Google theory of operation.
                  • Congratulation!
                    I've been bumping up against this thread since the beginning and it has always depressed me until now.
                    The tone over the last two days has clearly changed and curiosity abounds.
                    Success depends on focus and I think you guys and gals focused. Something good will come from all of this and we may help save this world by our hard work.
                    I am curious about something.... The link I posted seems to be dead now. It has been live and good for over a year and just one day after posting the link here, it is dead.
                    Powerful people don't seem to want us to succeed. That is in itself a telling event. There is truth and functionality in Don Smith's device or why would there be such an effort to kill off information like this. When you find good information that can help us build big and better devices like this, you should always save the info to your computer and share it with those who need it.
                    Correction! It's working again, wow, that was quick!
                    Last edited by stoker_x1; 05-18-2012, 04:49 PM. Reason: Correction! It's working again, wow, that was quick!
                    • Outstanding Individual
                      Some outstanding individuals have been causing a lot of distractions. Anyway, good to hear you concur!!
                      • Wwts
                        Originally posted by Berg View Post
                        Originally posted by Nikola Tesla
                        Life is and will ever remain an equation incapable of solution, but it contains certain known factors.(1)
                        Those factors seem to be evident in this thread.
                        Indeed, it is so.
                        • Not quite...
                          One foot of 12 awg wire weighs much more than four feet of 24 awg wire.
                          I dont have any 4 awg wire, but It will be the same. The cross-sectional area doubles every three gauges....
                          American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies
                          Rick
                          • Actually I thought about this the same way for some time. But beeing without equipment and proper ee background I was not sure where to start. Now I will try to firnd some local electronics company and try to get the access to the equipment. I think your three plate capacitor circuit should work perfectly to replicate this .
                            • Originally posted by RAD-HHO View Post
                              Not quite...
                              Take 2 equal lengths of 10 ga wire ( both equal in length and weight ), use one as the secondary, cut the other in 4 equal lengths and parallel them together and they become the equivalent of 4 ga wire.
                              • Originally posted by David Fine View Post
                                If that is directed at me, you can be assured that I won't post anything of any substance here. I have no desire to share any of my successes here, where a few weeks ago I may have shared everything.
