Originally posted by dragon
No, I don't think so. I think you are drawing upon your experience to zero in on the part of the system where something unconventional might be happening. As you know and we agree on, conventional physics and electrical engineering does a very good job of explaining the vast, vast majority of phenomena we see in the world around us. But somehow, somewhere in these various "radiant energy" devices something very deeply unconventional is happening. But what exactly is it? Where does it come in? How is it produced? That's where the real answers lie and I think we are not far from figuring it out. Once we really understand what is happening and why, then I think it will be essentially trivial to extract any desired amount of energy from it.
The Meta-Project
Ok, now for a somewhat related but completely different topic. I want to point to Dragon's explorations as an example of what I would call the "Meta-Project", that is, the project about the project. Or perhaps, the project about how to do the project. Maybe I should be a bit clearer. As I mentioned before, us few hobbyists and experimenters are filling in the shoes of the scientists that can't or won't do this kind of research. But nevertheless, what are doing is real science; which involves making observations first and only later speculating what is happening and why, instead of putting the cart before the horse and only testing for what we expect to see.
It should be the goal of every experimenter to have enough parts, tools, supplies, and knowledge to be able to throw together an experimental configuration to probe and test any given idea at any given time. It took Dragon 20 minutes to throw together a bench rig to test one particular thought. Boo-ya, kudos to Dragon! Some day, sooner or later, whether it's through this particular line of experimentation or not, one of us is going to do such a test and see some very clearly anomalous results. Success in generating excess usable power in significant quantities is the eventual goal, but the amount of trial and error along the way is VAST. The idea should be able to fail early and often, to test ideas at minimal expense in time and money. The faster and more efficient at failure, the sooner we will get to success. This is what I call the "Meta-Project". It's all those intangibles that make a research effort like this possible. Things like at least some budget for parts. Good sources for scavenging. A reasonable workbench, even if it's just part of a basement or shed. Decent tools. A large parts box. Also the time to be able to spend experimenting, this gets harder with job and family responsibilities. At the intersection of all these things is the core of the research. The other things are all enablers, and spending time and effort maximizing them also increases the eventual chances of success at the main goal.
TED talk- The unexpected benefit of celebrating failure (Astro Teller)
https://www.ted.com/talks/astro_tell...rating_failure
Originally posted by dragon View PostThis environmental capacitance thing is still pestering me. I decided to explore this a little deeper, created some pseudo environments for the same circuit - replacing the antenna and ground. Among many of the tests that worked well was a 2ft 3" diameter aluminum tube with an insulated 20ga wire inside, completely isolated from each other ( no visible discharge ). Measures 55pf.
This functions exactly the same as the antenna/ground connections. Same power levels, bulb response etc.
I had thought that because I was using the NST powered by the grid that I was getting a feedback from neutral which is connected to ground although not directly to my grounds. Also, not connected to the secondary of the NST with the exception of a capacitive link through the core. Still that didn't explain the antenna requirement to make it fully functional.
I isolated the grid by using a pure sine inverter, driving it from a battery, same response so this removes direct grid connection.
My earlier thoughts using a pipe with an isolated rod inside are beginning to show some light. I'm getting a better understanding of what these guys were doing with the earth antennas 100 years ago.
The tube/wire replacement for ant/grd seems to operate best when the larger surface area ( tube ) is used as ground and the small area ( wire ) is the antenna. The tube becomes positively charged and the wire is negatively charged. I'm not sure the significance of this but I believe it will show me the answer as I progress.
I have some odd theories about what could be done with this arrangement which I'll share later but until I get this completely straight in my mind I have to pursue this to the final answer...
Edit: ( then again maybe I'm being a complete lunatic by focusing on this, what might seem, trivial aspect of the system. )
*This is an ION VALVE. I discovered it back around the year 1980.
I just did a quick google search and found this interesting ion valve history:
How to Build an Efficient Alternative Energy DeviceLast edited by radioionics; 02-04-2017, 09:27 PM.
Ahh, some very interesting circuits! In addition to the ion valves, I find extremely interesting the component marked "ion-gate" in the first schematic. It consists of a capacitor at the HV terminal of a NST and two diodes in the avramenko configuration. It reminds me very much of the Don Smith "Ambient Energy Generator" diagram:Originally posted by radioionics View Post*This is an ION VALVE. I discovered it back around the year 1980.
How to Build an Efficient Alternative Energy DeviceAttached Files
Back to experimenting. My multiplier stacks are in, I bought two of the pre-made 12 stage stacks from amazing1.com. It's unlikely I can design and build anything as compact and good looking, and if you price out the components the cost isn't bad either. I want to use two, one positive and one negative polarity. Using either the PVM12 or the ZVS to drive it (with a suitable AC flyback transformer), the driver can sit at near neutral potential while the tips of the two stacks are at high potential (one positive and one negative). The multipliers are only offered in a positive polarity, but after looking at it a while I realized it should be possible to flip one around and desolder one diode from the end, resolder it onto the opposite end, and have the correct arrangement for negative polarity. This took only a few minutes to do, you can compare the two to see the results.
To get anywhere close to the full potential capability of the multiplier (30KV per stage) it will be necessary to encapsulate it in something insulating. Oil and paraffin wax are the two usual choices, but since I like everything to look good I wanted to pot it in acrylic. I bought an acrylic tube with an inside diameter (1") almost exactly matching the width of the stack, and I have some casting resin on the way. My plan is to vacuum encapsulate each of the two into a single unit with an integral protection resistor. Unfortunately, if a diode or cap goes bad there won't be any way to fix it, hopefully that won't happen. I haven't attempted this before so we will see what kind of results I can get. I will have to fabricate some end caps out of acrylic sheet and make sure the bottom is sealed liquid-tight before pouring the resin.
When it's done, even a modest 10KVAC drive voltage from the HVM should be able to get all the voltage my coil and other wires can handle.
Most excellent Bruce. I've looked at these, and many of your drawings in the past. It appears that I've reproduced a successful "ion valve" then. I believe these have a past much further back than you and I. These are only a few of many I've studied, a couple I've reproduced with some interesting anomalies which I continue to pursue in the ground circuits.Originally posted by radioionics View Post*This is an ION VALVE. I discovered it back around the year 1980.
US1220005
US1303730
US1349103
US1349104
We are still overlooking something.... this nagging quest I'm currently on is beyond the valve itself. This crosses over to both our works and I know your just as frustrated as I am at times. It's at the point of total frustration where we finally ask the right question, in that moment, the answer becomes obvious. I'm currently there....
Those are just beautiful !!! Do they really need to be potted? Or, is this just a precaution...Originally posted by tswift View PostBack to experimenting. My multiplier stacks are in, I bought two of the pre-made 12 stage stacks from amazing1.com. It's unlikely I can design and build anything as compact and good looking, and if you price out the components the cost isn't bad either. I want to use two, one positive and one negative polarity. Using either the PVM12 or the ZVS to drive it (with a suitable AC flyback transformer), the driver can sit at near neutral potential while the tips of the two stacks are at high potential (one positive and one negative). The multipliers are only offered in a positive polarity, but after looking at it a while I realized it should be possible to flip one around and desolder one diode from the end, resolder it onto the opposite end, and have the correct arrangement for negative polarity. This took only a few minutes to do, you can compare the two to see the results.
They come with a spec sheet noting that they should be potted for anything close to full voltage output, which is theoretically 360KV (less in practice of course). Air breakdown will occur with a unit this short. I'm sure you could drive them at a much more moderate voltage and get away with it open-air, but I just want to go ahead and encapsulate them and not take the risk. Plus I want it to look cool. Like I said, it doesn't HAVE to look like a prop from a sci-fi movie, I just WANT it to....Originally posted by dragon View PostThose are just beautiful !!! Do they really need to be potted? Or, is this just a precaution...
I could build a multiplier myself but obviously it would end up much bigger than this. With these small units I can put another daughterboard right above the HVM board to mount these two, so the hot ends feed directly to the board with the PPV's on it.
Originally posted by dragon View PostMost excellent Bruce. I've looked at these, and many of your drawings in the past. It appears that I've reproduced a successful "ion valve" then. I believe these have a past much further back than you and I. These are only a few of many I've studied, a couple I've reproduced with some interesting anomalies which I continue to pursue in the ground circuits.
US1220005
US1303730
US1349103
US1349104
I thank you for the acknowledgement.
These are good underground antennas. I've seen these many moons ago, but I appreciate you posting them.
I found this more recent patent in my search process: US3183510
Electrical energy from ambient radiant energy
Here is another ion valve magazine article I found tonite:
http://www.radioionics.com/pdf/Elect...iantEnergy.pdfLast edited by radioionics; 02-05-2017, 05:00 AM.
Don and I used to talk on the phone at least once a month. I miss the dude. This circuit was Don's way of showing how he drew in energy from what he called the ambient. Some call it the "zero point energy." The energy actually comes from the charged ions that are stored in the atmosphere of the planet.Originally posted by tswift View PostAhh, some very interesting circuits! In addition to the ion valves, I find extremely interesting the component marked "ion-gate" in the first schematic. It consists of a capacitor at the HV terminal of a NST and two diodes in the avramenko configuration. It reminds me very much of the Don Smith "Ambient Energy Generator" diagram:
Looking at the second figure in this document, the one called "Improved Edwin Gray Circuitry", it would seem that the antenna and ground are not, strictly speaking, essential elements for pulling energy from the "ambient" through this method. Based on my own experimentation and knowledge of the Avramenko configuration, I would propose that the capacitance of the entire circuit acts as its own "antenna" when pumping electrons with the AV plug.Originally posted by radioionics View PostDon and I used to talk on the phone at least once a month. I miss the dude. This circuit was Don's way of showing how he drew in energy from what he called the ambient. Some call it the "zero point energy." The energy actually comes from the charged ions that are stored in the atmosphere of the planet.
I also note that this configuration has a lot in common with what I was trying with my benchtop Tesla coil a couple of pages back in this thread, where I obtained white sparks on the spark gap and it seemed that the coil had increased power (not a direct measurement, just a qualitative observation).
Moving forward with my obsession and a bunch of new tests... Originally my question to myself was why would there be a power draw on an open circuit, that is, the same draw that would be present in a closed loop. One would expect to see an "idle" draw on the transformer if it was an open circuit. The reduction in power when using the ant/grd then could be explained by the capacitive coupling. Calculating the reactive resistance showed that it was indeed running in a closed loop. The ant/grd having a 13kohm resistance gave a clear indication of what I saw as the drop in power consumption between this and the direct connection. With a 13k resistor in the closed loop circuit it performed like the ant/grd circuit. So what, if anything, is to be gained here?
I set out to build an artificial environment to replace the ant/grd yet still maintain the capacitive effect I was seeing. Thus the tube and wire - large surface area acting as a ground and small surface area as the antenna... the infamous "Ion Valve". Worked perfectly with slightly less input consumption. The capacitance measured in at around 55 pf giving me an over all resistance of around 75k. This corresponded closely to what I calculated. So then, what is the key mechanism that "brings in", "attracts", or otherwise supplies energy in excess of the original input?
In pondering this I also realized that with the added resistance ( ant/grd, ion valve ) there was an RC time constant involved here as well - a tiny delay in response, which may or may not have relevance..... The next several experiments ended in complete failure - the goal was to reduce capacitance even farther thus finding a maximum impedance that I could get by with that would still allow the system to run, hoping for a reduced input requirement yet still provide a reasonable output. Obviously I went to far and it simply became an open circuit once again...
I fashioned 2 plates that could be adjusted for distance, one large one small - quickie calculations on distance and size ( overall a "best guess"). At a gap of around 1.25 " there was noticeable activity in the gap, at just over 1" it flashed and maintained an arc. So, alright we had an output and all was running as expected, only a slight drop in input requirement which was disheartening, it dawned on me that the transformer couldn't do this on it's own. I'm using an 8kv transformer throttled by a 15uf cap so it's most likely running in the range of 4-5kv. The gap being an inch or more indicates a voltage far in excess of what the transformer alone would do.
Ending this portion of my investigation I observed; No energy in excess of input, nothing to indicate a reduction of input other than the inherent resistance, it functions solely as a closed circuit not as an open circuit... but an interesting development leading to a place to start a new investigation.
Originally posted by Wistiti View Post
Hi guys!
Does anybody have an idea of how I can determine the + and- leads from the output of these module..?
Thank you!
