  • Hi folks.
    Hi Harishsingh.
    Thank you very much for this very informative study material.
    I can only say it was a great deal of info I have found into these files.
    I took some minutes now to read the paper entitled "Search1997.pdf" and I am
    amazed. Definitely a Must Read stuff. Millions of thanks to refer us to this pool of good info.
    I didn`t know about this physicist called Dr. Panos Pappas Ph.D. !
    I can even read his native language, so please if you have any other such documents please give us links.
    Many thanks.
    Harish you said :If anyone has a copy, please PM me.
    Can you please clarify what copy of a document(?) are you looking for ?
    If you are refering to the big article you mentioned, or you inteded something else.
    Thanks and Best Regards.
    • Would U believe or not, Truck Dive from Ukraine build some kinda Free Energy generator based on induction cooker
      It means you don't have to be a professor or Architect or Nikola Tesla or ... whatewer to build your own perpet um Mobile
      cooker - YouTube
      • Deja Vu again! Static Extractor from Epower
        Originally posted by DilJalaay View Post
        Thank you for posting the circuit.
        Some one already experiment this with little modification.
        I do not remember but i watched a youtube video some one lit his xmas tree bunch of leds(220v operate) with this circuit.
        Here is the schematic.
        Regs,
        D.J
        Thanks for reposting this.I did show my version many, many posts ago.
        I did see the discussion by one replicator on youtube and Lorrie's suggestion to hold off on concluding free energy.
        Guys I am suggesting that you use an independent earth ground.No grid stuff.
        I am also suggesting that you could use a 12 volt to 110v inverter with a car battery as source.Now the grid officials won't come looking for you.
        Again connect to earth ground.
        Finally, how about using your own driver, this time pulsing 110 volts at say 100 khz same set up except ferrite as core and see what happens.
        If I am making some or no sense, do not hesitate to let me know .
        Best regards,
        Ged
        • Extension of the setup :things to explore
          I tried this or nearly identical. Had a phantom voltage but almost no current. Since all houses have ground tied to the Neutral in U.S. you are still going to see a reading on your house meter if you pull any thing real so I wouldn't call it stealing. But it really doesn't work and the discussion I saw about it said something about putting it on hold for reasons that it might not work.... So unless there is some major alteration to that diagram it's not worth wasting time on it IMO.
          Hello eWiz,
          To me the device maybe an asymmetrical capacitor.Did you measure the capacitance of your replication.(Measure the hot wire to rod and the output)
          Now I have done so.Now my next step is to try various setups.
          Less turns, same rod diameter,bigger rod diameters, with more turns.Hollow rods (more surface area) etc.
          I moved a step ahead and just used a capacitor instead of the rod.One with greater capacity.I also added a cap to the bridge.Yup, had more power.
          ...and we are back to Don's stuff.
          You know, Lorrie made a bigger and more powerful version,lots of coils and rods all connected in parallel.But I say use CAPS instead! Less expensive,less time,more capacity and it works. Go ahead, try it.
          Its easy to rig up.Just replace the rod with your favourite capacitor, and don't forget to add one to the diode bridge (optional if you like).Make sure the one on the diode bridge is of a higher capacity that the one replacing the rod or you may get a really loud explosion like the one I got and have pics of!
          My next step with this setup is to use my own hf driver,that should be good.
          By the way, I was really testing out wiseman's capacitive transformers when i decided to combine Lorrie's work with it and a little of Don's work.
          Have a blast!
          Ged
          • Hi GSM, Peculian and All,
            It's a huge subject to wrap your head around and I feel like I'm just scratching the surface. Am going to have to unlearn some things first. Am happy to share and learn your fascinating findings.
            I'm looking for the document titled
            "Energy Creation in Electrical Sparks and Discharges. Theory and direct experimental evidence. IECEC. August 1991".
            I'm cant buy this off the net since I don't have an international credit card.
            Something to do with exchange rates.
            I'm just looking for the experimental setup if you know. Thank you.
            HS
            • Originally posted by Gedfire View Post
              Hello eWiz,
              Have a blast!
              Ged
              I just did a quick and dirty test. Glad you are finding some interesting things with it. Wiseman's work is very interesting and I think is worth looking more at or incorporating some of his ideas in projects. Best of luck with it.
              • SR193 video
                Originally posted by dyatronn View Post
                Hello Patrick!!!!!
                Video about the 150th watt a lamp not mine. This video was laid out by the person under SR nickname. Any explanations by a principle of work wasn't, I personally consider that video a fake, this my personal opinion.
                I now am engaged in the target transformer of production. It seems that a configuration of windings of the transformer not naky as at usual factory manufacturing. coils of primary and secondary windings should be flat. At such transformer the reaktant is strongly suppressed, such transformers were developed by institute in India.
                While all in a manufacturing stage. As soon as I will carry out transformer tests - I will report about results
                Hi Dynatron,
                Apologies for the mix up - my mistake. I am looking forward to seeing your results on the tests of the specialised transformer.
                The Nuclear Magnetic Resonance people think that the SR193 video is an example of NMR and that there is a sacrificial disc or tube of metal inside the construction, acting as 'fuel' for the process, so I personally, would hesitate to write the video off. They also believe that all of Tariel Kapanadze's devices operate using Nuclear Magnetic Resonance. As it is not my field, I really can't comment on what they are saying. I'm hoping that they will produce a replication to prove or disprove the theory because if they are right, then we have open-source design and theory which should allow many replications.
                Thanks for your reply,
                Patrick
                • Originally posted by zilano View Post
                  THE VIDEO LINK BELOW IF ABSORBED FULLY IN MIND AND RELATE IT TO DON U WILL FIND HOW DON CIRCUIT WORKS. REMEMBERING THAT RESONANCE REDUCES POWER INPUT TO ACHIEVE LOWEST INPUT.
                  THE BUFFER CAPACITOR CAN BE USED AT INPUT AND OUTPUT IN DON CIRCUIT.
                  THIS BUFFER CAP ACTS AS FLYWHEEL AND BRING ABOUT FLYWHEEL EFFECT AND EXTEND A DELAY TO RELAY SWITCH FEEDING OUTPUT BACK TO THE INPUT IN DON DEVICE TO MAKE IT SELF FEEDING.
                  Capacitor charge via motor and diode - YouTube
                  VOLTAGE AND ENERGY OF CAP
                  IF U INCREASE MFD FROM 2 TO 4700 SEE IT YOURSELF HOW MUCH ENERGY U GET AT 10000 VOLTS
                  Electronics 2000 | Capacitor Charge / Energy Calculator
                  WHEN U USE C=4700 MFD AND VOLTAGE=10000 VOLTS
                  U GET
                  Energy E = 235000 Joules
                  THAT IS 235 KILO JOULES
                  RGDS
                  ZZZZ
                  This is what the gorgeous buffer cap does.
                  Windows 95 Stanley Meyer Original WFC.v1 Software & Voltage Intensifier Circuit Demo - YouTube
                  And the safety spark gap across the cap now seems mandatory.
                  HS
                  • Jean-Louis Naudin´s replication of Kapanadze's generator
                    Hi All:
                    Just want to know if someone has replicated Jean-Louis Naudin´s replication of Kapanadze's generator. He has showed to be a very serious and reliable experimenter. He gave all details in his page. He reported an input power of 153 Watts, and output of 2400 watts.
                    (http://jnaudin.free.fr/kapagen/index.htm).
                    • Hey People
                      I have a new build of one of DON SMITHS devices. He called it the Bonus Device on the video. I have gotten it to work but not well I have made a few modifications to it to get it to light a bulb. But it only lights dimmly. Anyway here it is below Also it needs alot of experimenting with to get it right. This is just what I have at this point.
                      Als here is a Vifeo I came accross. It seems there is a new kid in the sand box and the us kids don't like it. And are making every effort to stop it. Seems they will lose there hold on technology and power. It will be interesting to see what happens.
                      Free Energy - Nuclear Engineer M.T. Keshe @ ElektorLive! - YouTube
                      • Thanks!!!
                        SLOW-N-EASY Thanks!!!
                        • Keshe
                          I'm not happy with this foundation. As usual only theory and books to buy.
                          If you want some verifiable data on this stuff check out Leedskalnin.
                          • Hidden in the past
                            Hi folks I note that in several posts members are locking horns with the sticky subject of the asymmetric capacitor , Both Robert Adams and Harold Aspen of New Zealand and the UK respectively were both giants in the electrical and free energy fields unfortunately we do not have the benefit of their presence any more.
                            Both of these gentlemen worked together for a while and indeed share British Patent GB2282708 w.r.t a C.O.P+1 electrical motor generator .
                            of course t.p.t.b shouted fraud and did their best to ridicule the work and research , but as both men were at the very top of their respective disciplines and certainly in no need of a few grubby bucks generated by some scam, the mud wouldn’t stick.
                            However as regards the Don Smith project and Aetheric energy conversion it is some of Harolds later work and patents I would like to draw your attention to, particularly GB 2390941A and GB2432463A which are a natural progression and development concerned with the generation and use of “atmospheric electricity”
                            and
                            Download GB2432463A_ASPDEN.pdf for free - Ebookbrowse.com - Ebook Search & Free Ebook Downloads
                            regards Duncan
                            • Duncan:
                              I do not doubt that this happened, Duncan -- but request a reference or article on this. Is there anything written down? I think it is important to document such suppression efforts.
                              Also, what has happened with the Aspden motor-generator by now? is it available anywhere for testing? that was a 1993 patent...
                              • Hi prof It is made very clear with regard to the motor gen set that timing and construction are critical and difficult and of course as with all C.O.P +1 systems it is really down to individual constructors. looking at some of the prior threads on this forum here is one demonstrating the validity
                                although It was really my Intention to draw attention to the later Conversion work, P..J.K has done his usual superb job on this pulse system and supplementary information.
                                When you ask what became of the system Robert Adams himself who was chairman of the NZ I.E.E explains the extream measures used to silence him and his systems..
                                Prof ….you may as well ask me what became of Steorm or this guys work VTS_03_1.mp4 - YouTube
                                well Its being used on a commercial scale
                                Alternative fuel Magnegas - YouTube
                                Its certainly being used in air ports in Europe and as Santilli says its in use by municipalities so why don’t you see it “available for consumers” at a domestic level? Surly you don’t need me to answer that do you?
                                What is required is a system that’s so simple to construct and put into operation that Mr average can do it in his garage, which is why I draw attention to Harold’s later work in the hope that it can supply the answer to a difficult missing link. As for systems like Santilli's well like Tesla its been suppressed for years here's a basic outline of Santilli's system shown in an 1898 patent for domestic use
                                I don’t really think you need to ask why we don’t have an advanced system of this in every house
                                by now, do you? I'm sure you have more nous than that
