Originally posted by Garsony
SGG II "cold electricity" by Mopozco
If anyone knows the coil dimensions and windings please share.
HS
Nonsense conflicts
Guys let stop this nonsense of conflicts between us and concentrate more on Don's circuit.
Zilano once you've said that you want to help. Helping others does not mean that you give riddles to others. If one really want to help he just offer his hand heartly.
Ok thanks for your input guys and let just be more tollerant to each other on this forum.
I read it with much interest. Unfortunately I'm not in a position to comment on it yet. But thanks for it anyway, it's another valuable piece in the jigsaw which is my research.Originally posted by boguslaw View PostHmm... so nobody reviewed my explanation ???? I could have expected that
Boguslaw Posts
Everybody is not ignoring your posts. There are some major distractions on this thread. Those distractions are screaming louder than you are and thus getting much more attention.
Thanks for taking the time to put that together and share it!!
I was re watching some video's of Don's and these two are interesting.
Part 14 at the 4:30 min mark a guy walks up and asks Don if what is in the
suitcase is a scaled up version of what is shown on the board, Don Lied and
said yes it was. He lied because the guy then asked if he could see inside the
suitcase and Don says flat out NO, he says because there are other
proprietary things in the suitcase in direct conflict with what he just said. He
then unleashes a walloping of bluff and bluster almost ending in a thinly veiled
threat.
Bottom line is the device that powered the light bulbs was not shown at all
and the battery was not shown or measured, he admits there was more in the
suitcase than what was shown. The demonstration could easily have been
powered by batteries.
Donald L. Smith 1996 Tesla Symposium Part 14 - YouTube
Part 14. At 1:40 to 2:10 he admits a small inverter could run the bulbs from
the battery in the suitcase. It makes no difference what the output load is if
the input is not even seen or measured.
He doesn't allow the battery to
be seen or measured at all as far as I can see.
Donald L. Smith 1996 Tesla Symposium Part 13 - YouTube
Back in part 13. at about 7:20 he says the bulbs burn out quickly, but they are
measured to have only 100 volts across them. Something doesn't add up
there either.
He states the output is a modified Square wave and it is measured at 60 Hz
with 100 volts across what appears to be 400 watts of bulbs from what I can
tell.
Donald L. Smith 1996 Tesla Symposium Part 19 - YouTube
Then Part 19 at about 2:40 a guy puts in some 100 watt bulbs to make 1000
watts and the voltage was about 68 volts and was dropping.
Yes a short period of time is correct for a small battery but he did not see
the battery to say anything about it, he is describing the battery Don told him
was in there. To be lit properly and exhibiting 100 watts output the bulbs
would need to have 110 volts or so across them, not 60 or 70 volts. He
probably used a 600 watt inverter.
A regular UPS system can run a load of over 600 watts for a few minutes with
a 7 aH gell cell battery before low voltage shutdown, and they won't allow the
voltage to go that low. He could have had several of those batteries in the
suitcase. It's not recommended but they can do it, mine have.
The guy also says back in part 14 that when a square wave is measured the
voltage reading is generally 100 volts rather than 110 volts which I assume
would be measured on a sine wave from mains. so the 68 and dropping was
more like 58 and dropping which is pretty much half power when trying to
power a 1000 watts load. Looks like the battery was going flat, remember no
one seen the battery if it was shown I didn't see it. It could have been a
layer of Nicad batteries of considerable capacity in the bottom of the suitcase
he claims was mostly empty.
Yay for the guy in the blue shirt.
He called Don out and showed him up.
I think it was a very suspicious demonstration. And considering this thread is
for discussing the possibility that Dons devices were in fact too good to be
true, I think a valid discussion point is this demonstration.
What else is suspect in that demo, I wonder.
My suspicion is he wouldn't take the 5 million for the suitcase device because
it would then be known the setup was just an inverter in a box with batteries.
With no measuring or even viewing of the battery the demonstration proved
absolutely nothing, there is no reason for anyone to believe the setup did not
just run from batteries. Not to mention all the inconsistencies.
CheersLast edited by Farmhand; 05-13-2012, 10:46 AM.
Apperantly, from what you post you belief everything Zilano posts and obey her, then you'll be admitting to yourself that you're incapable of thinking for yourself, incapable of making your own decisions and choices.Originally posted by vidbid View PostApparently, from what Prompt posts, he believes that he can tell you what to believe, what to do, that you'll fall in line, and obey him. If you do obey him, then you'll be admitting to yourself that you're incapable of thinking for yourself, incapable of making your own decisions and choices, and incapable of deciding for yourself what to believe.
Remember me warning you about the RomeroUK fake, you wouldn't listen at first and had the same attitude like you have now.
If Zilano can say what she want's then so can I.
Incredible
Wow man. Please give it a rest.
Originally posted by scratchrobot View PostApperantly, from what you post you belief everything Zilano posts and obey her, then you'll be admitting to yourself that you're incapable of thinking for yourself, incapable of making your own decisions and choices.
your capacitor impedance must match to impedance of the power source.Originally posted by SLOW-N-EASY View Postthanks for your help. i have tried a spark gap but the frequency is to low. i can spark it with a screw driver
but the gap will not run. it like the cap is filling up but will not release to the spark gap or iso transformer .
i've even tried a relay and the juice transfers to the transformer but put a load on it and it goes away.Its
like it was never there. and the relay will not run like a normal sparkgap or relay . I appreciate the help
but i can't figure what to do to it next. I'll also look through your old post and see if it gives me a sollution.
thanks again
regards
i think that impedance of your capacitors is too low on source frequency.
You have to calculate a Xc (reactance of the capacitor) on frequency of the power source. then you can calculate a current comming from power source.If you took too much current then voltage from power source wil decrease and since loop is closed over capacitor, it will never increase to value which can jump over air. Imagine capacior as resistor. where resistance equals Xc on source frequency.
You probably need to decrease a capacity of your capacitor.
Missing parts??
Hi!
All the time we are focusing on the same information over and over again..
I have been looking for information about Don, Leedskalnin and Tesla that is not in the forum threads
I think maybe Don also was looking for missing parts for a long time like we do.
We must start doing things we "know" are totaly wrong, then we will find the secrets, I think there are many roads to the same goal
Kind rgds D"Being myself a remarkably stupid fellow, I have had to unteach myself the difficulties, and now beg to present to my fellow fools the parts that are not hard. Master these thoroughly, and the rest will follow. What one fool can do, another can."
Silvanus P. Thompson, F.R.S.
It's unfortunate that we must have this type of interaction, but I'm not one to back down.Originally posted by scratchrobot View PostApperantly, from what you post you belief everything Zilano posts and obey her, then you'll be admitting to yourself that you're incapable of thinking for yourself, incapable of making your own decisions and choices.
Nothing personal.
counteroffer
Are you a parrot?
Straw man. Produce those posts, scratchrobot.Originally posted by scratchrobot View PostApperantly, from what you post you belief everything Zilano posts and obey her
Can't you be original and come up with your own material instead of copying me?
Again, can't you be original and come up with your own material instead of copying me?Originally posted by scratchrobot View Postthen you'll be admitting to yourself that you're incapable of thinking for yourself, incapable of making your own decisions and choices.
By copying me you're admitting to yourself that you're following my lead, modeling me, and thereby ultimately obeying me. Stop it. Try to be original.
A false analogy is logically invalid.Originally posted by scratchrobot View PostRemember me warning you
Straw man.
As if it mattered to me. You can say whatever you want, but it's unfortunate for you that you can't come up with any of your own material.Originally posted by scratchrobot View PostIf Zilano can say what she want's then so can I.Regards,
VIDBID
Kind rgds D
