  • Originally posted by usu View Post
    Hi!
    What the program do you use for making the screen shots?
    Sergey.
    use screenshot captor its free and so good.
    Screenshot Captor - Mouser - Software - DonationCoder.com
    zzzz
      Hi,vidbid!
      If you remember i asked you the link.
      It was the video about device which collected under this scheme.
      And there we see again the method that zelina described before.
      Best regads,
      Sergey.
      @Sergey,
      Point, Set and Match for Sergey!
      I agree with Slovenia's comment..
      VIDBID
      • Hi all
        Hi Vidbid
        Wow
        this thread is bringing more and more in info and replicating technologies.
        all is becomming nearer and nearer in our hands
        and by waiting my 2 similar car coils to go further in the replication of Mrclean's experiment...
        i found some matos in my shop to crudely replicate the russian/ Larsko/Capindres / experiment
        Always very happyto be here, and hope to all of you good success
        Laurent
        Power from excited ferrite torroid 1.wmv - YouTube
        • Screen Image Capture with Print Screen Button and Microsoft Paint
          Hi!
          Sergey.
          When I see an image I want to capture, I push the print screen button (Prt Scr) and I use Microsoft Paint.
          With Microsoft Paint already open, select Edit, then select Paste.
          See:
          VIDBID
          • Originally posted by zilano View Post
            zzzz
            Hi!
            Could you please answer to my questions?
            Sergey.
            • Woopy
              Originally posted by woopy View Post
              Hi all
              Hi Vidbid
              Wow
              Laurent
              Thank you, Woopy!
              I'm a very big fan of yours.
              You distinguish yourself as an experimenter and set the standard.
              VIDBID
              • Zilano
                coz its current amplifier device and a convertor for rf/hf for usable electricity.
                moray tapped fine hf vibrations that cudnt drive the secondary of trafo. so this energy has to be amplified by some device. moray used copper wire running between lead plate and silver plate.
                amazing Capindres' Device do the same it uses fe and cu and cu all ++ we must not call it a resistor coz its not.
                rgds
                zzzz
                @Zilano,
                Thank you for expounding on that. I enjoy your commentary.
                VIDBID
                • VIDBID IRFP is not Russian
                  @ Vidbid
                  Wrong it is miss leading information.
                  IRFP is an International rectifier registered trade mark it is not Russian never been
                  address:
                  WORLD HEADQUARTERS: 233 Kansas St., El Segundo, California 90245, Tel: (310) 252-7105
                  Please read and check the information relevancy check the biasing of the circuit before u fill the pages with !!!!!
                  Data sheet attached for IRFP22N50A.
                  For other versions check the web site International Rectifier Home Page - Flash Detection
                  JJ
                  IRFP20N is a Russian component.
                  • Originally posted by Michael John Nunnerley View Post
                    10watts in England can produce 20watts in Australia "why is that?" you need high sun spot activity to do that and also the right frequency range "what is that telling you". This is an area which main stream really does not investigate and a good example is that all the advancements in radio HAVE COME FROM RADIO HAMS, none professionals!!!!!! so keep up the good work you are doing here and maybe we can show the main stream a thing or two.
                    Mike
                    Yes I have read that too, and I believe it is true. Can you give a link to the
                    published info so we can all read the details of this happening. There must be
                    a technical paper to cite on this effect.
                    EDIT: Here are some links.
                    In this first link would or could the effect be related to the "detected power and noise".
                    Is the effect related to antenna gain ?
                    Re: What does Antenna Gain Mean? If a transmitter output is 100Watts and your
                    Quote below from link above.
                    At the receiver, a 100 watt transmitter with a 3dBi antenna produces the power density equal to having a 200 watt transmitter.
                    Is that an amplification of energy ? Or can it be ? It's very interesting and I'm
                    very glad we have someone here who can explain it to us a bit better.
                    Thank you
                    cheers
                      @ Vidbid
                      address:
                      Data sheet attached for IRFP260N.
                      JJ
                      • modulating using transformers
                        TV Power to Mod Transformer
                        Nice link to using tv or crt flybacks for modulating transformers, Food for thought check out figures 1-2-3-nicely written short and to the point.Thanks MJN
                        Randy
                        • @ vidbid
                          You can also use low power mosfets. Slayer exciter IRF510 at 1 5V - YouTube
                          • Xee2's Device
                            Originally posted by xee2 View Post
                            @ vidbid
                            @Xee2
                            Thank you. I appreciate the information.
                            I wonder what would happen if you connected the open end of your L1 as seen in your schematic to an earth ground?
                            Maybe nothing or maybe something.
                            VIDBID
                            • Found it.
                              This link has some information some might find useful as well.
                              Especially this part - "1.2 Production and loss of electrons in the ionosphere"
                              Introduction to HF Radio Propagation
                              Ahah, Here in this post. http://www.energeticforum.com/115682-post50.html
                              our hardworking friend lamare uncovered some info. With references/links.
                              new clues to guide this free energy path?We can amplify waves in the magnetosphere for a Global Communications at lower frequencies
                              Maybe no mystery. Maybe some "opinion" in there, I'm not sure which link the
                              quote came from. I quoted that quote directly from the quote in lamares post.
                              This info was first presented by lamare to my knowledge. I remembered
                              reading it and went and found the post.
                              They seem to be saying that this was the mode of Tesla's Magnifying
                              Transmitter, I'm not sure I agree with that if they are implying that.
                              I don't think the experiment the cite was done with regular radio transmission/receiving equipment.
                              All roads lead to HAARP. Fantastic. I can only imagine what they
                              are up to these days. No need for paranoia though, they don't own the planet.
                              • Sergey Contributions
                                @Sergey,
                                Thanks for the information.
                                Generator
                                Scheme
                                Variant
                                I'm intrigued by the variant design.
                                VIDBID
