Is the virtual ground of Tesla's Magnifying Transmitter, at Wardenclyffe and at Colorado Springs, also the beneficial geometry of using a hollow sphere (ellipse, toroid, etc) serving as a capacitor whose center is a floating plate grounded to nowhere and whose outer plate is an endless circuit, a closed loop, also leading to nowhere effectively giving us a virtual ground to both the dielectric field (held at the center of a hollow object) and to the magnetic field (endlessly encircling this hollow geometry)?
An example of voltage buildup (without any notable current) oscillating between two electrical analogs to two hollow spheres passing their oscillations through the coil between them at L1.
Here is the output of the schematic, above, simulated in Micro-Cap.
Compare this with the latest revision, below, of a single electrical analog to a hollow sphere plus one ground and an inductive and capacitive pair of loads held between these two terminals of a dipole...
Here is the voltage output of the schematic, above, generated by the use of the "Gear" method of approximating a simulation, plus an elevated "reltol" tolerance for divergence.
How to reset the tolerance for divergence in Micro-Cap electronic simulator by resetting "reltol" to a higher value than its default value of 1m (in order to minimize the possibility of getting fatal "Matrix is singular" errors) and select for "Gear" method of approximation to be more realistic for simulating power supplies.
I took the story of the Amman brothers' hollow copper spheres (whose newspaper documentation comes to us courtesy of Boguslaw and is cited here) and elaborated on this concept by attempting to conceptualize its peculiar properties by electrically simulating it into various versions of complexity versus simplicity...
Single-Wire Non-Transmission of Power, coming to us courtesy of Nikola Tesla's Wardenclyffe!
How else may we get a virtual ground to occur on one end of a dipole (as Eric defines Tesla's Magnifying Transmitter)? But by utilizing the geometry of a hollow sphere or a hollow toroid?
Did the Amman Brothers make use of this geometry in their EV conversion demonstrated in Denver, Colorado, in 1921, and Tesla replicated theirs and his TMT concept in his Pierce-Arrow demonstration in 1931 (inside his secret project box)? Did Tesla convert the virtual grounding properties of hollow spheres into its electrical analog such as I have done in my simulations? And have we misrepresented the contents of his "project box" by Peter Savo's misinterpretation of what type of vacuum tubes Tesla purchased from an electronics shop when he arrived in Buffalo, New York, to perform his demonstration of the conversion of a Pierce-Arrow into an electric car? Were these twelve so-called radio tubes, in fact, vacuum tube capacitors whose vacuum was replaced with a noble gas, such as: argon, or helium, or neon, etc. to contribute negative resistance to his circuit via these tubes? And was his two meter aerial (located on the backside of his Pierce-Arrow) not a radio receiving antenna, but in fact an ionization needle intended to inefficiently "dump" excessive overunity into the atmosphere three years prior to the formation of the FCC (in 1934) whose explicit mandate is to prevent this "aerial dumping of electrical smog" from ever happening again?
This last postulation comes courtesy of Mark McKay who has stipulated that the EV Gray motor's problems with excessive overunity were solved -- not by dumping it into batteries and exploding them, but -- by ionizing their excessive dielectric and magnetic fields through the engineering efforts of Richard Hackenberger working for EV Gray at the time (after Marvin Cole left Los Angeles in a hurry from freaking out over his development of levitation as a side-effect of his engineering efforts while working on the EV Gray motor).
These are my contentions in an ongoing pursuit of these mysteries...
http://vinyasi.info/energy/Single-Wi...former-v28.zip
http://vinyasi.info/energy/Single-Wi...rmer-v33c2.zip
