Hendershot Replications
  • Dave45
    I think the magnet he was using came from a radar magnetron
    Transformers in the coils
    A transformer has an energy field around it just as a choke does, he is taping this field by placing the transformers in the cap coils.
    SM does the same by placing the choke of his oscillator within the tpu.
    A radio might be used to tune the device because you can hear faint oscillations, some of the experimenters on this site use radio's to listen to the oscillations, just a speaker may work.
  • Dave45
  • morpher44
    post withdrawn
    Originally posted by Gazzasore View Post
    Hey odd things happening here on the site
    I get your new post by email but they are not showing on the site
    Hi Gazzosore,
    Nah. Its not odd, I just deleted the post because I realized I shouldn't
    get too overly excited about some recent results. I realized after posting
    it that the Earth Ground, for whatever reason, was quite noisy tonight
    and so the signal I'm seeing is stronger than I've seen. It could be
    machines running in my house -- like washing machine attached
    to house plumbing.
    I've been experimenting with a new cone coil in Bashar STA thread
    and have gotten some interesting results for "passive - self-powered"
    heterodyne.
    More testing to do...
    -morpher44
  • Gazzasore
    Radio site Coils etc
    Professor Coyle
  • Gazzasore
    Originally posted by morpher44 View Post
    If 220VAC is the input, then 44VAC needs to be the output to be
    5to1. I purchased transfomers that have 120VAC input, 24VAC output.
    Center taps might be present and they would just not be hooked up.
    I might also add that in the USA, the standard is 60Hz so these transformers
    might be ideal around that frequency. This is not strictly the case, however,
    since I think these transformers can be pretty wasteful and might be
    off-tune.
    Ok so its a step down Transformer Well there you go I always thought it would had been up
    Ok so its a 220 VAC down to 44 VAC thanks
  • morpher44
    5 to 1
    Morpher these 5 to1 Transformers
    What would be written on them Here in Thailand its 220v
    I mean I dont understand what to buy
    off-tune.
  • Gazzasore
  • Gazzasore
    Morpher wrote
    ""They are likely the same diameter on purpose
    and in that orientation to create 3 spinning oscillations,
    spinning in the same direction -- cw, then ccw...""
    I wonder if this has anything to do with Tesla always working in 3's
    Here in Thailand now some power lines where there are 3 wires have a spacer that makes a Triangle shape I believe there is less power loss with this configuration
  • morpher44
    another thing I love about that photo
    There is another thing that is so cool about this photo.
    Who was walking on the WALL behind the device with
    paint-covered-shoes, and how did they do it?
  • morpher44
    seems very large
    Yes I would suggest that is a horseshoe magnet.
    It does look "special" in that you probably couldn't purchase
    that necessarily off-the-shelf. Hendershot may have had
    access to help from Army engineers and "special" custom
    made improvements over the many years he worked on this.
    Notice how that magnet has a circular shape, very similar
    to the cylinders. They are likely the same diameter on purpose
    The tranformers placed in the cylinders, I suspect, was just
    to save space and not necessarily crucial to success.
    However, on the other hand, I have two of these 5to1
    transformers and I'm struck by how nicely they do work
    as "pickup coils". You get a NICE pick up since the laminations
    in the coil respond very effectively to nearby magnets even
    to the point of bumping the table and noticing a SPIKE.
    So it may not HURT to put them nearby any oscillating
    magnetic field... as long as the PHASE allows for
    constructive interference into the circuit.
    Hendershot may have been able to MAP OUT on his board
    where are the fields are -- being a master with induction compass,
    compasses, coils, mutual induction. After plotting where all the
    fields are, he could then probably MOVE his coils around on the
    board to maximize constructive interference.
    Since winding coils is an imprecise science, and components
    have certain tolerances such a 5% less than you think or 5% more...
    the understanding of what the waveforms might look like --
    such as using an oscilloscope, may have been a necessary
    part of the "tuning" step. It is impressive that he could somehow
    figure it out in his head w/o seeing the waveforms. This may have
    come with experience, having done it so many times over and over
    again using his "rote" work-ethic. Us youngin's are so impatient. We
    just want to switch it on and see it work w/o knowing why.
  • Gazzasore
    Ok in the Photo that was Lesters last Generator he made see the magnet or is it a magnet ? seems very large ?
  • Gazzasore
    Yes seems like the go
  • MonsieurM
    on a side note ..... you can print the above image and place pegs to make an egg like coil ( basket weave or not
  • Gazzasore
    the shape of the coil looks almost egg like https://www.youtube.com/watch?featur...&v=NJ7saXwMYUU
    also considered a favorable aerodynamic shape
    Yes so this would be flower of life
  • MonsieurM
