Hendershot Replications
  • #61
    coils ...
    Originally posted by jeanna View Post
    Hi Morpher44,
    This is a very interesting thread.
    Youtube is down at the moment so I will watch those vids later.
    I would like to suggest that you put induction coils IN SERIES on each of those L's.
    I found that they are even more effective than capacitors. I am beginning to use caps too to tank and otherwise, but if there were one to choose it would be the inductor.
    It is an entirely different animal from the same coil being used as a transformer.
    The reason is that in series every pulse going down the line makes another spike and that 'creates' more energy.
    Give it a try. If I can find my way back here I will check back tomorrow.
    (I keep getting lost on this forum .)
    thank you, this is wonderful stuff,
    jeanna
    @ jeanna
    I think your intuition is right-on-the-money.
    One odd thing about Hendershot's circuit (actually in the
    Barry Hilton book there are several alternative circuits),
    Hendershot may have wound his current path unconventionally
    through his 5:1 transformers. These are standard off-the-shelf
    guys extracted from TV or something.
    On the 120V side there would be lots of turns around an iron
    core ... making for an inductance that could well be up
    in the Henries.
    His circuit is so weird it might be difficult to do conventional
    circuit analysis on it ... unless your good at that (unlike me I'm afraid).
    There is mutual inductance all over the place here...
    I too have the feeling that he is exploiting LARGE inductances
    by simply hooking all these coils up in series essentially. His 40 MFD
    and 80 MFD do something clever as well.
    In the circuit I'm experimenting, which is essentially half of
    Hendershot dual-coil arrangement, I can see pulses from a relay -- which
    amount to just high-voltage spikes really, turned into a SQUARE wave ...
    as if they were run through a flip-flop. This done with passive
    components ... coils ... capacitors ... no diodes ... no transistors.
    Its mind bending.
    I had this thought before ... but last night got this thought again
    after studying the Hendershot material.
    The thought was ...
    "Why did Hendershot select 5 15/16 inches for the diameter of his coil?"
    This bothered me because Hubbard too, who used PHI in his coil designed,
    came up with a radius for his first prototype that was a similar diameter.
    I have to assume that Hendershot used some sort of math to come up
    with this radius ... because it is so specific ... and so unusual.
    Its not a standard coffee-can size ... I don't think.
    In fiddling with the numbers, I came up with this ... using a very
    Hubbard-ish approach:
    Start from 60Hz.
    Take it up a power of two until your in the 2Ghz range.
    60 * 2^25 = 2.013266 GHz
    That is your standing wave that will appear on the top of your
    cylinder.
    Ok ... now compute how much distance that is using speed-of-light
    equal to 299792458 meters/sec.
    I get the value in inches to be 5.862540. The dowels were .125 inches,
    so add one half that ... twice ... yielding: 5.98754.
    Take the fractional part .98754 and multiply by 16 to get it in 16ths ..
    and truncate: 5 15/16 ... viola!!
    Better still, I wanted to check this line of reasoning ... so I thought
    to myself:
    "How did he come up with 14 turns for L1 ... which is clearly the
    coil that when combined with 7.8nF ... TUNES a special frequency?"
    "So is that special frequency also a power-of-two harmonic of
    2.013266 GHz derived above?"
    60 Hz * 2^12 = 245760 Hz (well below AM dial).
    What value of inductance would be needed to resonate at
    245760 Hz if the capacitor is 7.8nF?
    Answer: 53.768017 uH (assuming AIR-COIL)
    Now the question is...
    "How many turns on a coil form that has diameter 5 15/16 would
    be needed of 28 AWG wire to achieve 53.768017 uH?"
    Hendershot would have had the Wheeler forumla if he looked
    that up in some Radio Engineer book.
    Solving for N (number of turns), given:
    L = 53.768uH, D = 5.9375 in, H approx .33 inch (a guess)
    results in
    ***** 14 turns *****
    which is the correct answer!!!
    This is either an amazing coincidence ... or the very math
    Hendershot used.
    Caveat: The Wheeler formula is only accurate for when
    H > .4 * D which is NOT the case above. This cylinder coil
    has a height far too small for that formula to predict accurately
    the inductance. However, I'm not bothered by that too much
    because Hendershot was interviewed and stated that
    sometimes he needed to REMOVE wire since he wrapped
    the coil (presumably this last coil L1) ... with too much wire.
    So that little TWEAK to get it working might be a clue
    that this last coil requires a bit of guess work due
    to the inaccuracy of the Wheeler formula.
    If all of the above math is correct and was used ... then
    Hendershot derived his coil dimensions in a similar way to how
    Hubbard did it.
    Certainly they would have the Wheeler formula in common...
    but the bit about a standing wave across the top of the cylinder
    is a very ANTENNA-like calculation ... not normally done for coils ...
    except for perhaps TESLA COILS!!!.
    • #62
      Yes,
      I have recently seen a book by collins?? from 19early and it is all about how to make inductors and what to think about.
      [The link is posted by MW383 on earthbatteryNathanStubblefield thread opened by localjoe at ou.]
      I think we have a lot to learn from those guys in the early 1900's.
      Everybody who investigated electricity back then used induction coils. They knew a lot about them, so ... I will never be bored, that is for sure!
      Its mind bending.
      It is so incredibly simple and I am sure we can cut out enough dross to see it soon.
      Personally, I think the tall narrow spikes are the way to go.
      It is hard to describe what I was noticing mostly because I was having a hard time understanding if what I was seeing was important or a mental confusion.
      I had a set up that had pretty much fixed volts and frequency
      So 89v spikes and 208Khz frequency.
      I would look at the volts on individual lights or whole secondaries and it seemed that if I added more lights which should take the overall reading down, the reading went up.
      There were other things like this too, but since I am not too sure, I do not want to cause confusion.
      The thing about it is that it seemed that there is something that is taking the place of amps, and I think it is the frequency.
      Its like this if you look at only one spike it is immeasurably skinny, but if you cram 208 thousand of them into one second, you start to have something.
      It may be just right to have tall skinny spikes and the "ooo no, they do no work" may be just a part of the disinfo game, and since at 60 hz we MUST use amps, everyone believed it to be true for all voltages. I think at higher frequencies you can get the same work out of closely packed thin voltage spikes.
      But that is just my idea, I need to do much more to show it.
      thank you,
      jeanna
      • #63
        tall skinny spikes
        jeanna
        "tall skinny spikes"
        This high-voltage, narrow bandwidth events, when arriving from
        space can convey a lot of energy ... but in a very extremely short
        duration. Most are attenuated by our atmosphere and ozone.
        As we loose our ozone, who knows, it might become simpler to harvest
        energy from space.
        Also, when they arrive, they may arrive in multiple harmonics.
        I don't have access to a spectrum analyzer ... but it would
        be interesting to see if it can be shown that one event
        amounts of a signal across several power-of-two harmonics.
        If the answer is YES ... a scalar wave, or toroidal shaped wave
        packet may cause particle spins at various diameters as
        it travels past. Each diameter amounts to a signal at a different
        frequency. So as the smoke ring passes -- analogy here --
        little particle spins are left in its wake at different diameters.
        As for the "cylinder" coil form having a standing wave.
        Cylinders are known to LEAK at these end points.
        Ping a coil at 60hz, and every power-of-two harmonic is also
        ringing in the sucker ... right up the spectrum.
        The one that matches the DIAMETER of the coil (if
        there is a match) ... may STAND there ... and not leak away.
        Standing waves and resonance are two wild-and-crazy
        phenomenon.
        • #64
          I just bought a conical drinking cup today for use as a conical coil template. I think the shape helps match whatever is there...I read that from tesla quote maybe??
          I will give it a try.
          I guess I need to move my big camera file over to this computer so I can show a pic or 2 of my scopeshots taken at a place between 2 wires with probes stuck into the earth with stubblefield generators at each end. I have a comparison set of probes without the stubblefield gens too.
          The shape is the same but the inductance etc whatever he did increases the voltage from typically 5mV from just 2 probes to often 65-85mV with the coils at either end. It is ac on top of a 0.5v-0.7vdc. very interesting and amazing looking.
          BTW The stubblefield generator is a perfect wire replication of the ancient caduceus.
          The ancient drawings even look like wires in some versions.
          I understand that JNL has made a modern version that can produce scalar waves. HMM.
          Whatever is coming our way may be just what we need and maybe it won't hurt either. I like the idea of toroidal packets. Sounds great to me.
          thank you,
          jeanna
          • #65
            morpher,
            I would say that outside coil is wound on 6" diameter. Wooden dowel + 1st coil + electrical tape ... (in regards of 5 15/16 diameter)
            Mike
            • #66
              L1?
              Originally posted by mlurye View Post
              morpher,
              @mlurye,
              The calculation for L1 is bugging me.
              If the cylinder is ferromagnetic (which I am assuming),
              then I think you use the Wheeler formula and also multiply
              by the permeability constant ... 5000 or so for Iron ...
              something less if your material is say some sort of stainless steel
              that is magnetic.
              I'm leaning towards this being the case because for
              Hendershot to achieve resonance with L1 and the 7.8nF cap he
              made, L1 has to have a large inductance ... assuming buzzer
              frequencies.
              I messed around with that little "made in china" dual-coil buzzer
              I have. I hooked it up to my pulse generator. As I dial around
              in the frequency range, providing it a narrow DC pulse, the
              buzzer hums in the audio range, but won't pull the clapper
              to the solenoid until I'm in the range of say 90Hz to 110Hz.
              Its a narrow range. Anything outside that range won't do it.
              That buzzer solenoid essentially have a self resonance in that range
              ... which makes sense.
              Placing this pulsing solenoid in proximity of the Hendershot coil
              does induce a current in the Hendershot circuit.
              It has a magnetic field that is easily picked up by the Hendershot coils,
              even at a distance of a few feet. I'm impressed by the distance of
              mutual inductance ...
              If I connect a ground wire between the buzzer's metallic case
              and the Hendershot circuit (between the two big caps),
              that signal is BOOSTED substantially ... this being the one-wire
              connection between them.
              But what I'm realizing is that since Q is so high with these values --
              high inductance ... low capacitance ... the bandwidth
              will be an extremely narrow range. It could be on the order
              of one third of a Hertz ... or less.
              The chances of tuning to that one PEAK resonant place --
              for my crudely made thing -- might be very difficult.
              Also, I don't have a precise way of measuring the inductance
              and capacitance ... so knowing this sweet spot frequency
              is ball park only.
              I might have to rethink my coil ... to provide a slightly larger
              bandwidth ... so as to make tuning less difficult -- at the cost
              of smaller Q (and possibly attenuated results).
              L1 is a challenge.
              • #67
                I noticed 1 more thing,
                Everybody saying that cap should be wrapped around stainless steel tube. Check comment on fig1 The Inventions of Lester Hendershot. It says: stainless or Aluminum tube.
                And the coil I was talking about is L4, see schema on the link above.
                Mike
                • #68
                  L1 is L4?
                  Yeah ... in the schematic you are referring to L4 is what I'm calling L1.
                  Other schematics have that outside coil as L1. Yes its confusing.
                  Yes the tube the cap is wrapped around is puzzling.
                  If its aluminum, its paramagnetic .. which would actually
                  REDUCE the inductance ... so placing it in the coils like
                  that would influence their inductance the other way ... bring
                  the resonant frequency higher.
                  Stainless steel is problematic because there are several
                  varieties of it... each with different permeability characteristics.
                  These would be below iron ... but approaching iron in
                  permeability
                  Some stainless steels are non-magnetic, however ...
                  but that is a bit more exotic to find.
                  But again, IF the tube is paramagnetic or non-magnetic,
                  making the coils essentially air coils ...
                  the oscillations would be well up in the VLF frequency
                  range ... approaching the AM band.
                  I can actually see on my scope the following effect.
                  If I ping with pulses of say 1Khz .... I can see on this outer
                  coil (my L1, your L4), a dampened oscillation which corresponds
                  to that AIR-Coil assumed frequency. Its dampened, however,
                  and fades away FAR before the next pulse.
                  If I then slowly lower the cylinder into the coil,
                  as I do, that oscillation doesn't change in frequency, but
                  does get more and more dampened.
                  When the capacitor is completely inside the coil,
                  that oscillation is almost completely gone ... negligible.
                  If that oscillation is WANTED, then yes I agree with
                  you that these should be air coils ... tuning
                  at that higher frequency ... and an attempt should
                  be made to get that ringing to go longer ... and go
                  regenerative if possible. The Q in that situation is
                  not so great ... but the bandwidth is more reasonable
                  with respect to tuning. It becomes more wide-band.
                  If, on the other hand, we are trying to tune for buzzer
                  frequencies, I think the coil inductance must be brought
                  much higher using ferromagnetic material.
                  Here the Q goes VERY VERY high ... bandwidth becomes
                  extremely narrow and tuning becomes a pain-in-the-a**.
                  There are a few clues that lead me to assume the latter.
                  A. Hendershot's device was notoriously difficult to tune.
                  B. One photo has a sticker inside the coil with the letters "Fe" -- Iron.
                  C. Hendershot's early designs used coffee cans -- most are magnetic
                  D. When Hendershot switched from coffee cans -- which would damage
                  his caps due to ridges and left over dielectric in his hand-made caps
                  (presumably some sort of ARCing damage) -- he switched to
                  stainless steel (but kept his original coil geometry and turns) - I think.
                  It is possibly that Hendershot realized he needed to switch
                  away from a ferromagnetic material ... but this should have caused
                  him to alter his coil significantly ... much greater number of turns.
                  This is my line of reasoning. It may be incorrect...
                  What can be done ...what I suggest ... is that you
                  build various capacitors types to fit in your coil ...
                  one wrapped around ferro material ... and one wrapped aluminum ..
                  or a non-magnetic stainless steel ... and perhaps one
                  wrapped around cardboard or plastic.
                  I have more experimenting to do with respect to this issue.
                  • #69
                    To begin with, I will assume that we are dealing with air coil.
                    Did you figure out direction of coils and how they are connected? I'm certain that direction of coils and trasformers is very important.
                    Mike
                    • #70
                      more notes... can someone help with circuit analysis?
                      I decided to wrap counter-clock-wise when facing into the coil
                      from the top.
                      The notes state that BOTH coils are wrapped the same.
                      I think it is only important that you stick with the same
                      direction for both.
                      Hendershot's circuit looks like it switches the wires on one side ...
                      which might imply both coils are in fact the same ... and he
                      alters direction by that phase change.
                      I do suspect that the left coil and the right coil are
                      to do the opposite behavior ... one going negative while the other
                      goes positive. If they oscillated completely in phase with each
                      other, the potential different between them would be ZERO.
                      If they oscillate with a phase difference, a potential difference
                      can be established between them. A 180 phase difference
                      would yield LARGEST potential difference .. with currents
                      flowing to the left, to the right, and so on.
                      One challenge here would be to make both the left and right
                      sides exactly match to achieve that. They won't exactly match,
                      I realize, because that would be too perfect. The will
                      therefore BEAT just a bit. You can establish a potential different
                      between beating frequencies as well ... but for efficiency you
                      probably want to bring these two coils into synchronization or
                      as close as possible to it. -- speculation on my part --
                      The phase relationships in the circuit are complex. You have
                      currents going through these 40MFD and 80MFD caps which
                      will alter phase ... and you have it going though the 5:1 transformer
                      coils and the Hendershot coils.
                      In figure 5.3 of the Barry Hilton book we see Hendershot's drawing
                      of his layout ... with 1 & 2 being his coil and so called
                      "Resonance Tuner" ... aka C-Clamp on his capacitor.
                      Similar to Radio, this is the place were the feedback path
                      is re-entering the circuit to cause regeneration -- I believe.
                      As such this coil-capacitor tank circuit is the STARTING
                      point of the entire circuit.
                      In terms of circuit analysis, if you can simplify EVERYTHING
                      in his circuit down to just this tank circuit, we have
                      the 7.8nF cap (variable in that by squeezing it physically
                      the capacitance increases from that 7.8nF baseline value)
                      and the coil proper.
                      The combination of the outer coil (14-turn one) and
                      the one under (64-turn one) create a transfomer --
                      with inductive coupling.
                      NOTE: With an iron core we can assume a PERFECT inductive
                      coupling and use normal transformer analysis here.
                      If, on the other hand, we have a air coil, the coupling will
                      not be ideal .. and hence K (the mutual inductance constant)
                      will be less than 1 (at some value more appropriate for air transformers
                      closely wound -- whatever that is).
                      Certainly air transformers work as they are used in radio designs ...
                      but there are losses to account for since mutual inductance
                      is not ideal.
                      Anyway, whatever the load is on the other side of that transformer
                      is being impedance matched via the transformer.
                      Since its a step up with a turn ratio of 64/14 (or 4.57:1),
                      we can assume current is reduced on the other side,
                      but voltage increased.
                      Normally what someone might do is just hook up
                      the 1:5 transformer again on the other side of this 64 turn coil
                      to bring the voltage 5x even higher, and the current 5x even lower.
                      But instead we see things wired all around using the other
                      coils and transformers in a non-conventional way.
                      The other coils look similar to the "tickler" coils found
                      in regenerative radio designs.
                      So yes circuit analysis might shed some light here IF
                      you can properly account for all the mutual inductance
                      -- and possibly some non-conservative field effects.
                      Those really good at electronic circuit analysis might
                      be able to model this using spice or something better.
                      A simulation might need to model these mutual inductive
                      effects in a special way.
                      If we could get the help of someone really good
                      with this sort of circuit analysis, they might be
                      able to shed some important insights into what
                      the circuit should actually be -- out of the
                      many choices presented in the Barry Hilton book.
                      • #71
                        Neutral line.
                        @Morph44.
                        I saw your latest video running your relay and magnet around the iron bar.The Neutral line is close to the surface of the permanent horseshoe magnet. When it runs through the iron bar, the bar is depolarized, however still strongly attracted to the magnet. Inside the neutral line the poles form in opposition to the horseshoe magnet, while outside they reverse into attraction mode. Picture an iron bar with a soft iron rod attached to the center and running first from the bottem of the armature, through a heavy spring, a frame followed by two solenoids in tandem, and a wing nut attached to threads on the very end. Now, placeing the magnet on the frame sideways like Wesley Gary, the soft iron bar can be positioned so the neutral zone runs through it and is depolerized. Now, two South pole activated Reed relays must be positioned at the ends of the iron bar, wired reverse polarity to one of two batteries that drive each solenoid independently. The bar first must be jiggled out of the neutral zone, then one side polarizes south and triggers the solenoid to carry the armature down through the neutral zone to the side of reverse polarization, and a fluctuation follows. This is a tensioned self positioner of my own design I offer you to try and recreate to generate a great amount of intense power from the magnet armature. The fluctuation only needs to be a half millimeter in width. What do you think?
                        synchro.
                        • #72
                          mechanically challanged...
                          Originally posted by synchro View Post
                          @Morph44.
                          synchro.
                          @synchro
                          I think I'm mechanically challenged.
                          I admire German engineering where parts are so nicely machined
                          and precision is an art form.
                          I'm good with scotch tape, and cardboard and glue ... and that
                          is about it.
                          There is a temptation to play with these strong neodymium magnets,
                          but they are so strong that they border on dangerous.
                          I buy this notion of neutral zone and I observe that when
                          the metal clapper SLAPs against the core of the coil, that a BURST
                          of energy is released and easily received by nearby coils.
                          I imagine zillions of little atoms suddenly spinning around
                          as the metal makes contact.
                          When the metal is pulled off, again, huge burst!!
                          So yes there is the nice feature in these buzzers and relays
                          and coils of back EMF to recover the other-side of your pulse energy ..
                          but if you slap metal together, there is yet another untapped
                          energy phenomenon in the metal itself.
                          Do you have a URL you can share showing us your design ... or
                          can you paste a schematic or diagram or picture?
                          • #73
                            positive feedback...
                            • #74
                              latest video...
                              In this video I show some results while testing
                              Figure 5.13 (or half of the circuit really)
                              from Barry Hilton's book.
                              YouTube - "Hendershot Fuelless Generator" -Mark Hendershot 1995 Update
                              After I made the video, I removed the iron bar
                              and put the relay right in the horseshoe magnet.
                              This dropped the supply current down to 2.5mA @ 6V
                              (< 15mWatts), and the Neon lights just fine
                              with nice 300 volt spikes.
                              I am not yet able to light a 4Watt incandescent bulb yet, however.
                              I wonder if these 300 volt spikes could do electrolysis
                              to make hydrogen?
                              • #75
                                Originally posted by morpher44 View Post
                                @mlurye,
                                Running a quote from "Hendershot in Farbe.doc" thru Babel fish ...
                                morpher,
                                Here is the same document translated by Joit MEGAUPLOAD - The leading online storage and file delivery service (thank you again Joit, very nice job) check title of this document. It was built by Aho.
                                And yes Hendershot did use ferromagnetic materials for the ring. My assumption, it was used as base for capacitor and nothing more.
                                I just finished building 1st coil, it took me 3 days. 2nd one should be a little bit easier
                                Mike
