Hendershot Replications
  • Originally posted by David G Dawson View Post
    The illusion is again before our very eyes:
    This is what happened when I was doing a polarity check.
    The small Neo used in this 'magnet' is sitting on my Neo stack.
    The small Neo will only come out if the correct opposite polarity or attracting Pole is presented to its face.
    I thought the little protruding ends on each side were part of the mould but not so.
    These little Neos measure 5 x 7.5 mm and my extraction 'tool' is 6 x 12.5 x 4 mm, 24mm.
    I was unsuccessful in attempting to parallel the arms and now I know what is inside creating the 'magnetism' I can extract both Neos and simply apply some heat at the bend and it will straighten just like in a Smithy's shop.
    Didn't want to do that if it was magnetised.
    These were going to be used for the Wesley 'Neutral Zone' motor.
    Not what I call a Magnet as the one on the LHS, source unknown and the one I am using in the Hendershot replication, out of a a vintage speaker.
    N20Wolf,
    All you appear to be presenting is material that I already have and you appear to have some discrete knowledge of the device as if you have one working and don't believe that is the case.
    Do you have a working unit and could we please see your pictures and some more detail and not something that we already have?
    The Russian Hendershot Forum also I do not believe has a working unit, just a great deal of information which again, as Graham has stated, you cannot model on your Computers.
    I am currently running through the Russian Forum data but have not seen anything there that suggests a working replication as nobody is jumping up and down saying 'I have it working'.
    Just the facts please and not just more confusing information that is distracting.
    Thanks.
    Smokey
    Hello In Generator Lester Jennings Hendershot Use transformers with windings 5 to 1
    See this picture:
    Transormer Z1900 Universal (Bracked Furnished). He fits!!! This is very important, otherwise the generator will not work!!!!!!!!!!!!!!! No one does not have a working model of the generator Lester Jennings Hendershot. Must exactly to do otherwise will, not work nothing!!!!!!!!!!!!!! Coil in buzzer used from ringer just about 110 volt
    • Transformers were not critical according to Arthur Aho
      N20Wolf, Arthur Aho, who has personally worked for 2.5 years with Hendershot himself (1958-1961) and built 5 different devices and conducted a lot of testing, mentioned in his writings that the transformers were not critical.
      You were asked politely to publish your own results... so if you have it please come forward with it, there's where you can gain credit on this forum.
      • Drill template for 57 pegs Hendershot capcoil MK3
        For the ones that are interested, while looking for MK1 stuff, I found a drill template scale 1:1 on overunity.de for the 57 pegs of the MK3 device, if this already has been shared my apologies.
        Free Energy - Freie Energie - OverUnity.de
        • Hendershot Generator - Resonator
          Hello Graham,
          At Page 10 of your Forum (going backwards to 1) and also doing the Russian Forum and pulling out the meat of their articles and will Post later.
          Will do a build in detail with the facts to date of my second build which should assist others as I have already, in some instances, proved Lester's methodology as being correct.
          Later on this as I need to compile the detail in a correct manner and this will include the type of wire used, size and length and Inductamce.
          This is not saying that what I have is 100% correct but better than anything we have so far.
          Note that this is my second build, the first was the Russian scam video job which got me interested and then woke up to reality but I did have the basics in place and then rewound my basketweaves and carried on from there.
          Lots of information that is not applicable which needs to be weeded out.
          Have an excellent master for the basketweaves in PDF but how do I pass that on here?
          Yes, the thin horseshoe would be a requirement and also thought of the flat and thin magnet face would be a pre-requisite to the Wesley Motor.
          Round Magnets are now available with a side polarity vice ends (diametrically magnetised) and probably now for rectangles - NO, just checked, only the round or rod styles.
          Disappointed with the bought Horse-shoe as I expected them to be conventional Iron magnets and not what I bought with mini Neos stuffed into the face.
          Have mini Compasses on the way now.
          Probably make our own cut out of flat iron and add the magnets to the ends.
          Have some soft iron here which is thick enough for hand cutters and may make several up and laminate together but leave a 'U' at the front to contain the magnets - thinking aloud - I have asymmetric Neo small rounds here - have been collecting Magnets for years and have quite a display of all Ferrite sorts but no Alnico or Samarium Cobalt.
          The best method of pulsing into the coils externally is the one in the picture of the entire setup with the coil set in the bottom left.
          The bell ringer coils with other coils placed over the bodies and this gave good +/- input into the device at about 26 volts maximum but was unable to induce oscillation within the basketweaves.
          This is a picture of the trace achieved which looks balanced as that is what is required but the pulse may need to be more a square plus and minus and not a spike as this relates.
          This is when I looked at the schematic and questioned what I had as it seemed to be not conducive to oscillation and am still at that point and some of the schematics are not balanced and my reasoning says they should be.
          Have done the Skilling and Aho and deciding now on the next one and change-over is easy to do on my setup.
          This is the option to the Hendershot Resonator and suggested as the best method but you will notice that what I have here is a transformer which is working very nicely too and is showing 225 volts AC.
          What this is telling mie, is that I don't need the 1:5 transformers as I have already achieved the required voltage just a matter now of correctibg the pulse into an AC square wave at +/- DC potentials.
          The transformers I see as being a problem on the Forums and what these are used for in early B&W TVs are for Horizontal and Vertical oscillator drivers - the voltage used here is about 500~600 volts - simple Math 110 x5 = 550 volts and what Lester was using.
          The VA rating is about 15 VA and not in the 100s as I saw somewhere.
          I started out with 80VA toroids but what you see in my setup are laminated 30VAs and about to put in some 15VAs and these match the physical size of Lesters.
          For 240 volts my ratio needs to be 10:1, so a 240:24 is what I need and not easy to obtain and what I have are only 240/15 but will do until we can get an oscillation going.
          Don't think magnets below the coils is a hidden option here as in many of the pics the working device is sitting flat.
          Looking for the flat thin horse-shoe Magnets and wondering if any of the vintage Magnetos were of a stacked/laminated nature and will be watching out for those on Ebay.
          Notice locally that all of the Foundry type engineer shops are closing down as our generation retires and nobody there willing to take over - just another lost art.
          Wesley is the priority at this time to get the 'Neutral Zone' working as this would be the very first energy generator that did not require an outside energy source like Moray, Hendershot and Hubbard etc.
          I have a 'David Wells Machine' running here which is said to be a 'perpetual motor' and all that is required is to swap the two batteries as one discharging, charges the other whilst turning a magnet motor producing an LMD event (rainmaking) but doesn't quite meet that spec as it will eventually stop for lack of charge.
          Today is day 5 and runs 24/7.
          Will be messing around trying to get the correct picture size so you may see pics from me that come and go.
          Thanks.
          Smokey
          • Testing pic size.
            Ok, the top is 320x240 small
            640 x 480 medium
            800 x 600
            1024x 768 large
            Take your pick.
            I must have caught them in the middle of the update as I am unable to change the previous Post pic sizes where they were too large.
            Smokey
            Last edited by David G Dawson; 01-11-2014, 10:12 AM. Reason: pic size Image Shack update
              Hello Graham, At Page 10 of your Forum ......
              Was this just neodymiums at the polefaces without an iron/steel body ?
              If yes, then of course they were not horseshoe magnets !
              and of course different types of magnets also have different magnetic characteristics/impedances; especially different time related reactances !
              I would disagree because a squared pulse requires greater energy input.
              An impulse leaves the entirely separate cores/circuits to flip in their own dynamically related time periods too; also without the lower impedance interactions/loadings fundamentally related with square wave drive.
              David, this has been in my thoughts too - as if the core circuits should be common rail balanced about the buzzer/load lines.
              What this is telling me, is that I don't need the 1:5 transformers as I have already achieved the required voltage just a matter now of correcting the pulse into an AC square wave at +/- DC potentials.
              Check out say 2x 110V to 2x 18>20V AC, and non toroidal E-I type transformers, then take (or cut) the I off the E to insert thin paper in order to prevent Hendershot pulses inducing core saturation.
              Note - this is not square wave related.
              The centre magnetic buzzer might energise core fields, but these must be free to run in their own (foil-C tunable) time frames.
              Those transformer outputs are in series with one capacitor each and their outputs would be at a lower impedance. In combination with the top field core windings these series connected transformer-capacitors will generate a rolling (phased) magnetic field wave longitudinally through the sleeve - this to initiate a core field reversal plus loosely resonatable reset. (The winding fields are not tightly coupled with the core fields.)
              It is only the likes of mankind who comes along with those continuous squarewaves, they not being natural core, coil and magnetic field behaviours.
              Actually I have just ninety degree wondered as I check read this post -
              could not the value of the transformer secondary connected series C give us an idea of the frequency of impulse field rotation induced within the Hendershot cores ?
              I know of only two pictures where Lester's device is running. Do you have any others ?
              One is on a cloth covered tabletop lighting a lamp; I could so easily conceal ring magnets beneath a tablecloth on an apparently solid table.
              The other one is on a raised and sloping frame supplying a radio; I could so easily conceal ring magnets in that frame.
              If I have read correctly, then Aho took away a generator he himself saw being demonstrated by Hendershot, and yet he himself could not make it run for himself
              - because
              - he was not given the complete generator ???
              As an aside, if there had been something like a radioactive substance in the core wax then the generator would have run anywhwere; but it didn't for Aho.
              Smokey
              Far too many "lost" arts David .......... Cheers .......... Graham.
              • Hendershot Generator/Aetheric Antenna/Master Hole Plan
                Aetheric Antenna:
                This is scaled from the actual dimensions of the two plate aluminium foils used to build the Home-made capacitor.
                Graham, you may not like the name but this extends back into those elements below Hydrogen which we don't yet know too much about.
                At Tidbinbilla I spent many hours waving the 64 metre Antenna around the skies looking for Water Masers using a 24 Ghz Maser and our CSIRO 'scientists' in attendance and associated with the above.
                I was just told recently that NASA has donated the Tidbindilla multi-antenna site (5) to the CSIRO but will still probably track the deep space probes like the Pioneers and Voyagers which was my main position there.
                What you see here are two dipoles just like an antenna but spiralled.
                Reason for posting about an EH antenna - two fields being generated:
                Robert hart -- EH Antenna
                Coaxial inductor and dipole EH antenna
                Master Hole Plan:
                This is the PDF master hole plan for the Basketweave coils - you need to adjust this using any suitable program so that the centre of the holes measures exactly 5 15/16" - 150.8125 mm diameter:
                Back later with the wire sizes as this is what is probably keeping some of you from progressing.
                Remember, I am only passing on information which has been developed by our Group and to the best of our knowledge is a close as possible replication and my effort so far, is the only one at this stage of development.
                Smokey
                • Why not fast-track this?
                  See: Hendershot Generator Complete "do It Yourself" Kit Includes 2 5 Hour Video | eBay
                  Wonder if it works?
                  Resonance to all !
                  • Originally posted by Beamgate View Post
                    I would recon that it could not work as Hendershot demonstrated with those non-original values of electrolytic capacitors, also without any foil type core-capacitor tuning arrangements.
                    I don't see a proper horseshoe magnet being provided either - large good ones are not cheap, and very difficult to find these days.
                    Clicking the close page button was the only fast-track activity occuring here !
                    Cheers ............... Graham.
                      Basket weave Coil:
                      Diameter I posted earlier was incorrect and have just corrected, my apologies.
                      Should be 5 15/16", 150.8125 mm.
                      Smokey
                      • Hendershot Generator - Progressive Build
                        Hendershot Progressive Build:
                        These pictures are taken from a Progressive Build Document that I compiled.
                        Please note that the ratio of wire size of L1/L2 & L3 are in respect to the Golden Ratio of 1.618.
                        It is believed that Lester was aware of both pHi and pi and here we have chosen to work in this area between the two as you will see in the document.
                        Once again, these are our own observations of what is involved with this device and may not be correct but does open up another door into the thoughts of this man and his designs.
                        I have completed some frequency generation detail but will not go into that at this point.
                        Do not waste your time with Computer 'models' and solid state means to option the Resonator but deal in what Lester had to work with and get your brain to work outside of what you think you know as modern day technology is NOT the answer.
                        You may like to get involved with what you think you know best but that will not help you.
                        A complete mind-set change is required.
                        This from experience.
                        It would be greatly appreciated if you would read the Pages that have come before in this Forum before you Post, as I had done, else you will probably be wasting our time.
                        Thankyou.
                        Smokey
                        • Schematic Clarity
                          Thanks David, you have done a great job in helping all who want to get a good build with some needed details. Here is some added detail on those who have good RF and RLC skills, from page 98 in my book "Talking to the Birds". Regards Arto.
                          • For the transformers since they are 1 to 5 ratio, lets say 1 = 24v and 5 = 120v.
                            Transformers made for air conditioning industry and used in most of all the FAU units in our homes to control the condenser contactor are 24v.
                            But they are 5 turns primary to 1 turn secondary.
                            I'm just guessing these would work and they are mostly 40va secondary.
                            If they are 40watt secondary they are roughly over 1.5 ampere secondary, which is only 0.3 ampere at 120v primary.
                            My question is about the primary power for the load from the Hendershot Generator.
                            Is the transformer the supplier of current to the load or does L1? also supply current?
                            • Scale 1:1 drawing template for drilling 57 pegs
                              Basket weave Coil:
                              Smokey
                              Earlier I posted a link where a scale 1:1 drawing is available, but it seems the link does not work well, so I'll upload the PDF. Credit to overunity.de.
                              • Originally posted by adam_mizer View Post
                                Please note that Hendershot's original transformers were the type they used within tube driven television frame output stages.
                                110/120-24Vac transformers were available in his day but he did not use them !!!!!
                                Frame output transformers have a much high frequency response as was required by the saw-wave type of field-beam TV deflection required.
                                If you wish to use a modern 50/60Hz mains transformer as a substitute within in a Hendershot replication it might be better -
                                to split the core out from its mounting bracket -
                                cut neatly through its side welds in order to separate the 'I' header from the 'E' core -
                                insert a piece of normal 80g copying paper between the 'E' and 'I' parts of core -
                                ensure the transformer is clamped tightly back together, or sealed back together with superglue whilst the 'E' and 'I' are clamped.
                                The transformers are connected with the series capacitors to turn the overwind pulses from the centre magnetic frequency regulator into alternate/ongoing rolled phase impulses within the twin cores.
                                Cheers .............. Graham.
