Hendershot Replications
  • Reply to Above video from Russian Sister site
    Zaryad
    • vibrator power supply
      Some of these "vibrator power supply" circuits are DIRT-SIMPLE
      and a nice way to have a chopper circuit to do work with coils.
      No silicon needed. Some old school ways of doing things are better --
      higher voltage spikes, short-duration in time, rapid di/dt.
      This can be hard to do with bipolar transistors and mosfets, etc.
      Vibrator Power Supplies
      I'm finding it quite easy to use the back EMF from a relay, thru
      a large AC CAP, say 10uf upwards to 80uf, and then into a coil
      structure. You can easily control the pulse rate by bringing a magnet
      NEAR the relay to slow it down, or make the pulses more rapid.
      The wave forms are stable enough to TRIGGER on an oscilloscope --
      with just a little mechanical jitter. If the relay is lower power,
      and the CAP/MAGNET combination is a good one, the mechanical
      noise can be made to be almost nothing.
      • More Testing from our Russian Guy Looks interesting
        Hendershot
        • Just out of interest check out "shazizz" on YouTube He's gone Back ?!!
          • Art Aho Phamplet
            Originally posted by morpher44 View Post
            Hi Mark,
            What is the title of the pamphlet? With a title, we can easily google search for it and see if its on the web already so you don't have to waste your time if it is.
            If its NOT on the web, by all means put it on the web. Don't send it just to me. The purpose of this forum is to share all material with everyone.
            This page allows you to upload images (up to a certain limit of space).
            You can host the paper some other place too. Don't violates anyone's
            copyright.
            I can find lots about Mr. Ahoe and Hendershot.... but maybe you have
            something unique.
            Give us the title.
            -morpher44
            Dear morpher44,
            The title is: "A Case for Space" by Arthur C. Aho. Printed by South Antelope Valley Publishing Company, Littlerock, California 1968.
            Only six pages are given to the Hendershot technology. The rest of the 30 pages contains several speculations on other exotic subjects.
            The reason I suggested sending you this scan is that my data limit on this forum has long since been full, mostly onf E.V. Gray technology for photos and shcematics. Perhaps you have more room left in your account?
            Mark McKay
            • "a Case For Space"
              This it?
              • Art Aho Phamplet
                That's the one. Looks like someone took some time to type in that 30 page document. It must have been before the days of scanners.
                It looks like you are already covered for this source of comment on this technology.
                The only other reference I have is an old book on the "Piezo Electrical Effects of Wood". I once thought that the 51 (or 53) wooden dowles that supported the basket weave coils might have had some impact on the technology's operation. I never followed up on this line of speculation and it is a long shot anyway, but the concept was interesting. Other than the Tesla table Top Oscillators no other Over Unity device that I know of uses wood in any meaningful way.
                Mark McKay
                • Triboelectric Series and Hendershot
                  I watched a very nice video on a DIY Van de Graaf Generator.
                  This: How to Make/Build a Van de Graaff Generator Part 1 (Homemade/DIY) - YouTube
                  Some thoughts with respect to the Hendershot Fuelless Generator
                  having some Van de Graaff capabilities:
                  Negative Charges
                  The following materials would be on the negative side of the
                  triboelectric series and used by Hendershot:
                  * wood
                  * {possibly steel wire, or steel in cylinder -- coffee cans in the early days}
                  * sealing wax
                  * copper {in the wires}
                  Certainly there are other materials that can provide negative...
                  The following materials would be on the positive side of the
                  triboelectric series:
                  * human hands
                  * aluminum
                  * paper {e.g. kraft paper in hand-made capacitor}
                  In a Van De Graff generator, you have a means of moving charges
                  into a spherical capacitor -- into the INSIDE of it specifically.
                  Interesting that the Hendershot device appears to have a mix
                  of these charge carriers. Oscillating magnetic fields can move
                  charges as well, and they will travel around the fields in
                  curving spirals, landing on what ever target surface you
                  can present, per the magnetism.
                  An alternating field would move the charges BETWEEN
                  two structures -- the POLE and ANTI-POLE, and then the other
                  way round.
                  With the tank-circuit around the hand-made capacitor, we have a
                  "tuned" frequency of 50khz to 60khz ... Some place in that range
                  according to the capacitance and inductance value for the tank.
                  This is slightly beyond human "hearing", but would be sensed as
                  a sort of "pressure", if you were in the presence of such sound.
                  So yes, "wood", and other materials all can contribute in terms of
                  charges.
                  • triboelectric "friction" & "seperator"
                    Traditional Van De Graff generators use a motor -- powered by
                    electricity -- to spin magnets (or a coil), thus spinning a shaft --
                    and then brushing trioelectric materials against each other to create
                    friction, so that charges can then be extracted and sent to a capacitor.
                    Yet if "friction" of these materials is wanted, there are probably other
                    mechanical ways to create friction using magnets and small amounts
                    of electricity.
                    I was looking again at some of the pictures of the Hendershot Fuelless
                    Generator, and one stand-out feature is that the horseshoe magnet
                    is so strange, with 3-POLES. OR ... is it 3 Poles? You can't really
                    have a 3-POLE horseshoe magnet can you. A quick search via google
                    images turns up ZERO 3-pole horseshoe magnets. Nada! Zip!
                    So, one thought here is that Hendershot may have installed
                    a 3RD central "member" between the two poles, and extended it
                    slightly longer then the poles so that the "bar" can essentially
                    SEESAW over this object.
                    There would be "friction" indeed. But "friction" isn't necessarily
                    bad if you can harvest the charges into a nearby capacitor.
                    The mining industry uses this for a machine called a
                    "triboelectric sepeartor":
                    For iron ore, gold Triboelectric Separator,Triboelectric Separator supply
                    This is possible to do with "spinning" machine ... but also
                    just machines that are "friction" machines.
                    So one possibility here is ...
                    can you create lots of friction using very low power?
                    Can a magnet be brought into oscillation and "rub"
                    triboelectric materials -- in order to charge a capacitor?
                    • Aho Quote
                      "A firm squeeze again started the output and you may be assured that
                      it was a thrill to hold this pulsing condenser. It was a feeling of holding
                      the pulse of the living universe manifesting itself in a machine, even as
                      in a living body." - ARTHUR C. AHO, 1968
                      In thinking about this statement, the hand-made capacitor
                      (condenser) is vibrating. For it to be vibrating, you need some
                      pretty good voltage oscillations going on. As it vibrates,
                      you have "paper" and you have "aluminum" rubbing against each other.
                      Hence, this hand-made capacitor can exhibit triboelectric effects
                      if it is mechanically vibrating. The charges would BUILD in the capacitor,
                      and then provide power to the tank circuit, keep a high 50 to 60khz
                      oscillation going in the cylinder & coil area.
                      So "hand-made", as opposed to using some SOLID off-the-shelf
                      capacitor is probably necessary ... again another argument against
                      buying these 500uf or 1000uf caps shown in the recent HOAX video.
                      • I was having trouble with the connection to the foil on the hand made capacitors so I used a piece of metal I got at Lowes. I cut it into a small strip, soldered a wire on the end of it, bent it in half, and used a vice to clamp it on the foil. It made a very good stable connection.
                        Very close to the 7.8 that I can use my hand to squeeze the foil together to get 7.8
                        Finally got my horse shoe magnets.
                        Hopefully I will be able to play soon.
                        For the rest of the build pictures you can go here.
                        • capacitor discussion...
                          Nice build drak. You are obviously more talented than me.
                          Last week for fun ??? I made another hand-mad capacitor.
                          It a lot of bending over and getting up again .. tough on people over
                          40 -- unless your in good shape. I was in a swet trying to do it.
                          My calculations were incorrect and my capacitance came out to be
                          36nF, not 7.8nf. I was reading how its not so important that you
                          get exactly 7.8nf ... but instead that you get BOTH capacitors
                          within 1% of each other. There was some hand-written paper of
                          Hendershot's with 1.3MFD on it. So your hand-made caps
                          can possibly be anywhere between 7.8nF and 1.3uF. Tuning-wise,
                          this is between 50khz and 59khz ...on the tank circuit.
                          I recall thinking about this frequency ... and what it might be used
                          for is that when the circuit goes into a rapid 50-59khz damped
                          oscillation, the solenoids near the magnets may essentially
                          NULLIFY the magnet's field for a time until the damped oscillation
                          gets all weak -- at which point the magnet WINS again.
                          Just a guess.
                          In messing around with these types of circuits, surely the oscillation
                          will be DAMPED quickly and the other frequency of interest
                          are the periodic -- SLOW -- pulses from the buzzer.
                          Nice idea regarding connecting the capacitor leads.
                          Yeah you don't want COPPER touching ALUMINUM.
                          Your capacitor leads can be steel wire, and you can sort of
                          roll foil around them tightly.
                          Scotch-tape. Hmm..... It was mentioned as something you
                          DON'T want in the hand-made capacitor for fear that it provides
                          a PATH for the AC currents. So if you had tape that touch one file,
                          then touched paper, then touched another foil, think of the TAPE
                          as a short. Double-sided tape might be OK if you have it ONLY
                          between the foil and paper....
                          Scotch-tape is there on the triboelectric material list.
                          You can do the following with this tape. Tape it to itself so that
                          non sticky surfaces appear on both sides. Walk over to your
                          bathroom mirror and rub the tape against the glass a few times
                          and let go. Watch it stick due to the charges....
                          Actually using shipping tape between foils plates might be a pretty
                          good dielectric material.
                          I think its interesting to make a SLOPPY capacitor with
                          TRIBOELECTRIC materials. SLOPPY in the sense that it is sensitive
                          to vibration ... and creates charges for you as it vibrates.
                          I hooked my attempt up to a oscillator circuit and its interesting
                          because you can here AUDIO tones from it.
                          • Originally posted by morpher44 View Post
                            Thanks, but I doubt that.
                            If you have an 8 foot piece of plywood, it makes it 1000% easier.
                            Ooops. I didn't know. I can take them apart and remove the scotch. Wouldn't be that hard.
                            • Why have I never heard of the Hendershot?!
                              I'm sure you have thought of this, but goat hair, aka cashmere, does not conduct static electricity very well if at all.
                              I have a lot of reading to do on here.
                              Best of luck to all.
                              • goat hair
                                I didn't know goat hair was anti-static. But ... I read up quickly on it and there is a warning in that it works best when in a moist environment. When dry ... all bets are off. So in a desert, goat hair may act differently than in a humid climate.
                                Cat hair ... human hair .. these are really good triboelectric materials with
                                positive charges .. or leather... rabbits fur...
                                In fact, I think Schrödinger's cat probably is alive since it would rub its fir
                                against the steel and prevent the radio active decay from releasing the small flask of hydrocyanic acid. Nine lives indeed.
