Hendershot Replications
  • post withdrawn
    Originally posted by Gazzasore View Post
    Hey odd things happening here on the site
    I get your new post by email but they are not showing on the site
    Hi Gazzosore,
    Nah. Its not odd, I just deleted the post because I realized I shouldn't
    get too overly excited about some recent results. I realized after posting
    it that the Earth Ground, for whatever reason, was quite noisy tonight
    and so the signal I'm seeing is stronger than I've seen. It could be
    machines running in my house -- like washing machine attached
    to house plumbing.
    I've been experimenting with a new cone coil in Bashar STA thread
    and have gotten some interesting results for "passive - self-powered"
    heterodyne.
    More testing to do...
    -morpher44
    • I think the magnet he was using came from a radar magnetron
      Transformers in the coils
      A transformer has an energy field around it just as a choke does, he is taping this field by placing the transformers in the cap coils.
      SM does the same by placing the choke of his oscillator within the tpu.
      A radio might be used to tune the device because you can hear faint oscillations, some of the experimenters on this site use radio's to listen to the oscillations, just a speaker may work.
        • Morpher the Hendershot Motor Mystery PDF
          How many versions do you have I have 2 one is 140 page the other is 57 page
          I also have The Hendershot Motor - by the Utility Engines
          THE FOLLOWING IS THE LESTER J. HENDERSHOT STOREY AS TOLD BY MARK M. HENDERSHOT
          & secrets of perpetual power hendershot mystery by barry hilton
          and many other PDF files if you want any let me know and Ill send them to you
          Gaz
          • Gazzasore -- thread repeating...
            Hey Gazzasore
            Btw, this thread already has posted many of these pictures.
            Things are starting to repeat. You might scroll back and see
            if its been done before by previous contributors.
            Many posts are off topic too... which I suppose is just bound to
            happen.
            -morpher44
            • Patent US2025897 - EARTH INDUCTOR COMPASS - Google Patents
              • David Porter
                David Porter's statements in this video are
                reminiscent of the Hendershot Motor.
                Some things similar are:
                * 1850 RPM is similar to Hendershot Newspaper story where
                1800 RPM was quoted as the value when they tested his larger
                motor at the Army base
                * David Porter says at the end of this clip the power is taken
                from the magnet ... and they have to replace the magnet after
                a period of time.
                * Hendershot may also be pulsing the magnet with a duty cycle.
                David Porter is doing that with modern electronics, sensors
                to observe shaft location, TTL logic to PULSE the coils and the right
                time and computer interface to make duty-cycle configurable @
                runtime. Hendershot would have had to do this with coils and
                capacitors.
                David Porter - YouTube
                • Something that intrigues me is Hendershot wound a coil that picks up the earths magnetic field and converts it into current, the coils had to have current running through them to turn a magnet in his fueless motor.
                  This is just one configuration there are many, but the configuration is interesting, reminds me of the Adam's magnet motor.
                  • We know by studying the magnetron (proven tech) that a torus shaped magnet has a spinning field inside, Hendershot was tapping this field to turn his rotor.
                    Radar Basics - Magnetron
                    • Gazzasore you should have left the pics up, thread repeating sometimes helps refresh our memory, or we learn something new and see with a different perspective
                        Yes thats what I thought
                        But I must admit I hadn't gone through the whole Site as I really should had
                        But no harm done things are all tidy again
                        • The funny thing is in some of those photo's it showed the motor in good detail
                          It seems to me there were 2 types of motors one with basket coils and then one similar to an alternator I can see how the Alternator type could put out many HP and still be light
                          The the Basket Coil type as I see it would not and would be good for toys as it was built
                          Then there was The Hendershot Generator as the video build type
                          • Here's the coils inside a ring magnet, inside the spinning field of the ring magnet
                            • Create Free Energy with Magnetic Power Generator at Home
                              Create Free Energy with Magnetic Power Generator at Home - Video Dailymotion
                              • I remember reading reading somewhere that
                                It was said that Lesters Windings of his Magnets was the key to his device
                                So what happens if you wind a coil around a magnet
                                Do you get a super Magnet
                                I will try and find where it was said
