Hendershot Replications
  • Earth's Magnetic Field and FID...
    Today I did a very simple experiment.
    Materials and Equipment needed:
    * Pulse Generator (0 to 10khz -or higher)
    * Oscilloscope (10Mhz or better)
    * Horseshoe magnet (strong ... perhaps 3 inch or so)
    * Horseshoe solenoid (each coil giving opposite pole when energized)
    * Longish keeper -- one that extends well beyond the magnet width
    * Pick up "air" coil -- to fit nearby the longish keeper.
    Place the horseshoe magnet oriented such that its back is facing north, and its left pole is north, right pole south as you face north as well.
    Place the keeper across the magnet, having the left side extend leftward, and the right side right up against the south pole.
    Place the horseshoe solenoid against the keeper as well.
    Place the pick up coil along the axis of the keeper.
    Connect the scope to the pick up coil.
    Connect the pulse generator to the solenoid.
    On the scope, dial in 50usec/div and the lowest AC voltage setting.
    On the pulse generator, pick and amplitude mid-way and select
    a frequency approx. 2Khz. Also, if your pulse generator can
    do square waves, select that -- NOT sine waves or saw-tooth.
    If things are working correctly, the pickup coil should be showing you
    nice 2khz spikes on your scope, one going upwards (positive) and
    the second one going sort of mostly downwards (negative), with
    a nice associated damped oscillation afterwards. This is all normal stuff.
    Now for the fun part.
    Take your frequency generator and slowly dial upwards higher than 2khz,
    and then also lower below 2khz.
    You should observe an "echo" pulse that is NOT the same amplitude as your solenoids pulse. In fact, you can increase and decrease the amplitude of your solenoid pulse, and you will see that this does not affect the amplitude of the "echo" pulses.
    Further, as you carefully increase or decrease the solenoid frequency, you should observe that these "echo" pulses will speed up scrolling BETWEEN your pulses faster and faster, or slower and slower. You can attempt to exactly match to get the "echo" pulses exactly between your pulses.
    You can effect, therefore, the duty-cycle of these "echo" pulses by dialing in MORE of them between your pulses ... or LESS Of them ... down to LESS then ONE for every one of your pulses. It is "beating" in other words.
    Now can this "echo" pulse be exploited for power generation?
    If you selected a "beat" that gave you say 3 pulses for every 1 of your pulses ... and if you were to also use less power to get the return, utilizing the MAGNET's field, the "echo" amplitude being more than one you put in,
    the pick up coils "tuned" for this 4x * 2khz frequency range will see a nice DUTY cycle that is more than what you are doing with your 2khz pulses.
    If you orient the horseshoe magnet such that its back is facing WEST, and everything else turned as well, you still see the "echo" pulses, but they are lower frequency and you cannot get more of them between your pulses.
    I found a paper titled "Nuclear Spins in the Earth's Magnetic Field" by P.T. Callaghan and M. Le Gros, which explains this better than I can.
    • Earth's Field NMR .. continued...
      Read about EFNMR frequencies here
      EFNMR on Wikipedia
      Depending upon your location, you will need anywhere from 1.3khz upwards to 2.5khz to see EFNMR "echo" returns.
      The Earth's field varies all around the planet.
      This is a useful resource:
      Earth's Magnetic Field Calculators - Instructions | ngdc.noaa.gov
      • Hydrogen Line?
        {post withdrawn... some wrong conclusions...}
        • Morpher
          I look forward to your Posts
          They are very informative and Precise
          Keep up the good work
          • Hello Morpher44, Drak, Dave45 and Gazzasore
            I want to thank you guys for all the helpfull information on Hendershots work, i am new here and am very interrested.... Im a bit confused i looked at this project and im about to begin but im confused as to how many rows of the 24 awg enamel wire are supposed to be used i read 12 but i see many more rows in Drak's coil and in yours as well Morpher44??????
            now the video of the Hendershot Generator being built has 12 then 6 then 6 but the 12 seems alot thicker then 24awg has anybody seen this?
            or can any of you tell me how i should begin?
            • Hendershot-like...
              Hi.
              You are paying attention. :-)
              In my case, I made a couple of Hendershot-like coils.
              I was attempting to get the same inductances, but NOT with the same
              dimensions that Hendershot used. I had found these nice little
              4.25 inch diameter paint cans and constructed a Hendershot like coil
              with a more narrow diameter. Plugging in that diameter to the
              equations for inductors causes my coil to need more turns.
              Messing around with this stuff is like cooking. You can change the recipe
              a little .. and after having done so ... you might discover some things ...
              like what works .. and what doesn't work.
              My very first thinking that Hendershot might have been "tuning" for
              a very specific Ghz frequency, with the standing-wave or half-wave
              directly across the diameter of his cylinder -- Antenna Theory.
              If that is the case, then Hendershot coil dimensions matter.
              If on the other hand, if his device is mostly LOW-FREQUENCY AC or pulses,
              then dimensions don't really matter and only inductances might matter.
              Further, realizes that in the Barry Hilton book, there are several
              alternate schematics and several generations of the so called
              Hendershot fuelless generator.
              What we are all doing here is attempting to "reverse engineer"
              something w/o knowing all the principals involved.
              I do know that in the case of the magnet-bar-clapper, we are dealing
              with frequencies in the range of 40Hz upwards to 200Hz ...
              Therefore, in terms of a "tuned circuit" for ideal power, you need
              to figure out the capacitances and coils you need for that.
              This makes sense in terms of the 40MFD and 80MFD caps Hendershot
              used in his original circuit (ignore the recent video which uses
              totally different capacitor values).
              As for wire types... One thing of Hendershot's day that people were into while doing
              the Radio hobby, was making all sorts of crazy coils and publishing all sorts of tables
              listing how many turns you need on what sort of former to get a coil for a certain wave-length for radio reception.
              You could actually buy Honey-comb coils in those days.
              Hendershot was making his own, obviously, because he was
              caring about "magnetism" in particular. Hence the equations for
              solenoid and the magnetic field produce may be more important
              here than the formulas for inductance.
              Solenoid - Wikipedia, the free encyclopedia
              I think the solenoids are probably needing to MATCH the field of whatever
              magnet you pick. If your magnet is super strong, you are going to
              need a pretty intense solenoid. If you magnet is more weak,
              your solenoid can be more modest. Hence, the notion of scaling things
              is ever present in this design ... and so the question would be ...
              "Can you change the recipe?"
              • some Hendershot Motor thoughts....
                While walking the dog yesterday I was thinking about the "first" Hendershot motor.
                Let us suppose there is a certain high frequency that is being broadcast with lots of power "near" Hendershot's home.
                In 1927, 10cm Radar was pretty new and the ARMY was training people to
                use it on mobile trucks that drive all around the country side.
                This early radar was BIG stuff with lots of power, etc.
                We also have the Hydrogen Line, which is a very interesting frequency ..
                20cm or so.
                Suppose Hendershot managed to re-wire his Son's airplane motor in such a way that the coil on the stator was "tuned" to these Ghz frequencies.
                A coil has a response curve that is linear "pretty much" from 0hz upwards to
                Fr (self-resonance). The self-capacitance in the coil will make this
                response curve start to bend down again after the peak of Fr.
                So at Fr we have the largest amount of energy reception.
                This is the place the coil will self oscillate. While it is self oscillating,
                there is power there. Not a lot of power ... but enough possibly to
                create a field on the solenoid.
                If Hendershot's motor was an AC motor -- which is possible
                because the story of the time discusses that his device could
                power a "sewing machine" sized motor and those motors were
                likely AC. You can do this with a DC motor too probably
                but Hendershot would have needed semiconductor diodes
                for a bridge rectifier ... and he doesn't seem to use diodes.
                As the motor starts to spin up, the magnetic fields in the solenoids
                will intensify and have LARGER spikes from the pole reversals,
                providing that nice positive-feedback effect. Further there will
                be EMF emissions that the solenoids will respond to better
                and better as the frequencies go from these slow mechanical
                frequencies upwards to 100hz ... or 300hz.
                Remember that 1800RPM is only 30Hz. But basically as motor
                goes faster, we are walking up the LINEAR part of the inductor,
                getting more power as we approach Fr.
                So here are some thoughts for an approach:
                1. Coil should be "tuned" to the frequency of the motor, but perhaps
                have a second "tuned" coil for the Ghz frequencies. Bifilar?
                The Ghz coil gets it going, the 30Hz coil keeps it going...
                2. Solenoids in the motor need to balance the magnetic fields of the
                motor exactly with a given amount of current. If you want current
                very very small, you will need lots and lots of turns OR a
                better way to WIND the coil to give a larger magnetic field with less
                wire.
                3. By using a pre-magnetized core in the solenoid, the fields
                you create with the coil are added one way-subtracted another way
                as poles reverse. This possibly can be exploited so that less wire
                is needed.
                4. The "reception" of these Ghz frequencies requires full-wave, half-wave
                or quarter-wave antenna. Approx 8inch, 4inch or 2inch. A dish would
                be ideal but would be unidirectional. If Hydrogen Line, then aim
                it to the sky and point at the area of the sky with most intensity.
                5. While prototyping, have a nearby Ghz RF source that blasts
                microwaves at your motor to get it going. This RF might be something
                you can turn-off once the motor gets going.
                Does this sound possible?
                • Thank You Morpher44
                  ok, so i guess i will try and build it like the one in the hendershot video, what do you think??????? keeping in mind and without listening to much to the specs provided???????how does the first 12 windings in 20awg sound to you, then the next 2--- 6 windings in 14awg.
                  • The Device in the Video is a hoax if you paid for it ask for your money back
                    Just follow what Morpher Does
                    • Question????
                      Now in the video it does not include a 4th copper coil wrap around the L1 is that something new you guys discovered?
                      • OK gotcha
                        No i did not pay for it some one posted a link to the video and i followed it.....ok clean slate i will forget the Video and the specs, where should i a not so experienced electrical engineer of complete useless devices begin.....you guys are the pro's.
                        • Go Here there is lots of information
                          Lester J Hendershot - The Hendershot Motor/Fuelless Generator - Hyiq.org
                          Do lots of reading
                          As far as we know no one has got this device working yet
                          But and many other people around the world are trying
                          • Ok
                            well i do have a 2.4ghz remote that i can use, i dont have an ociliscope so i might be stuck there.....but i guess ill go back to youtube and start watching all of your videos and learn a little more first......
                            • thank you
                              i will, i thought someone has already done it......
                              • hardly a pro
                                RCGUY.
                                Geez ... don't follow what I do. I'm not an electrical engineer either. :-)
                                Everything I know is self taught and a hobby for me... not my career...
                                and remember, I have not built a full replication yet myself.
                                I've just made a few videos doing various experiments and learning as I go.
                                So I recommend you do the same ... and please share what you find out.
                                One advice I can give on coils. It is better to "over-wind" them number of
                                turns wise. You can always create a TAP by scraping a little of the insulation
                                and connecting to the TAP that way. If you've ever made crystal radio sets,
                                one way of tuning was to have a coil with a metal SCRAPER thing that you
                                could move back and forth over the coil winding, TAPPING at various places
                                on the coil.
                                {btw, part of the Hendershot story is that he sits there for "hours" with a wire,
                                probing around, here and there until it starts. That description, to me, sounds
                                like he was searching for these TAPS on the coil. Once found, he's hit the sweet spot
                                so to speak}.
                                This is a CRUDE variable inductor. The problem with variable
                                capacitors for radio are they are in the PicoFarad range and specifically
                                designed for radio. A variable capacitor in the nanoFarad range is not easily
                                purchased off-the-shelf. So Hendershot hand-made his capacitor and used
                                C-clamps to tighten or release pressure on it to create a CRUDE sort of
                                variable capacitor. You will never be able to get frequencies "tuned"
                                with out some sort of tuning capability such as variable capacitance
                                or variable inductance. Another way to get variable inductance is to
                                move ferromagnetic material IN and OUT of your coil structure.
                                So the cylinders, for example, if magnetic, could be moved UP and DOWN
                                within the coil to adjust the tuning.
                                But ... we don't know what we are tuning .. do we?
                                Is it frequencies in the AM radio band ... such as the most powerful
                                radio station near your house? OR ... is it just to create the phase
                                relationship for a proper heteordyne between the two tank circuits?
                                OR, is it resonance for the oscillating magnet-bar-solenoid thing?
                                You can't just WIND some number of turns and succeed. You need to
                                investigate this thing with a spirit of discovery and see what works.
