Hendershot Replications
    Hi,
    In http://www.hendershotgenerator.com/f..._and_tools.pdf / http://www.hendershotgenerator.com/f...schematics.pdf and http://www.hendershotgenerator.com/f...rshot_book.pdf there are unipolar capacitors mentioned:
    - 2 unpolarized capacitors, 500 micro Farads each
    - 4 unpolarized capacitors, 1000 micro Farads each
    Does anyone know what voltage rate and type of capacitors was there? Looks like big motor starter ones but not sure about it..
    Cheers!
    Hi T1000,
    I am not the only one opinionating that that is a HOAX.
    Read Morpher's own comments here -
    "Hendershot Fuelless Generator" - Relay Pulsing (Part 2) - YouTube
    Free energy ? YES !!!!!
    - to the person selling the plans !
    LOOK AT THE CIRCUIT.
    FACT - 1,000uF caps are like a short circuit at 50Hz and up.
    CH1+2 are pulse grounded via C4 - T2 not energised.
    *IF* 110Vac output to lamp, trace wires back from the lamp,
    they end up on the 20Vac winding of T1, and it would saturate.
    Only those investigating magnetic 'buzzer' action will gain knowledge to succeed with Hendershot designs !
    Cheers ........... Graham.
    • Originally posted by GSM View Post
      Hi T1000,
      Thanks for comment.
      That buzzer is same as pulsed coil with square wave. Obviously it wasn't in Hendershot's design to do that.
      I agree about capacitors. Unless you interrupt capacitor charge with magnetic field from coils around it it would be dead short circuit! But in this case the big caps in center of coil seems to have different function. The entire LC tank circuit has capacitor inside of coil and this is where it got my attention by means of electrostatic induction. I already pulsed capacitor with coil wound on it previously and seen what happens in it...
      Obviously In http://www.hendershotgenerator.com/f...schematics.pdf I do not see any dead short circuit..
      Also buzzer in original Hendershot's circuit looks like regulating and pulsing element by mechanical means from magnet magnetic field.
      Cheers!
      • A magnets magnetic field is static but its electric field is very kinetic
        JK Plasma Magnetics Experiment 1 - YouTube
        The fields move away from the bloch wall from the center out in both directions, you can prove this to yourself take a cw spring and turn it end to end and you can see you will always have a right hand turn but if you take two springs cw and ccw put them together end to end and turn the whole you will have the right and left hand spins at each end.
        The electric field is asymmetric.
        • The magnetic field works like the axle and the electric field works like the herringbone gear but the gear freely rotates around the axle, the axle is stationary(static)
            The following question arises - how you can influence capacitor with magnetic field?
            Then what is happening when that capacitor is energy source to coil giving the magnetic field back to capacitor..?
            This is Hendershot case and to get things ever more complicated, there are two systems like this interacting between.
            P.S> That is pretty close with E. Leedskalnin famous quote "Ring Bell Twice" - Coral Castle - Wikipedia, the free encyclopedia
            • Im not sure how the magnetic field effects the cap, whats interesting in Hendershot's original design the cap lined the inside of the basket coils.
              I was wondering about the voltage of the caps as well, I am gathering parts and if it works as he says I am definitely going to send this guy the money for the plans.
              It looks as though the transformer are used opposite one is stepping up and the other is stepping down, not sure Im still studying the schematic.
              What I like about the device is no battery and no drive circuit, the magnet is the source.
              • In this link the author says the caps are 450 volts, but at 40-80 mfd.
                A Story of Free Energy | Journal of Borderland Research
                • Here is circuit with my edition for easy reading and filled gaps as per original PDF:
                  We all together can ressurect it bit by bit. That means lots of attempts and experiments with how each component is supposed to work in this circuit...
                  • Good job on the sch.
                    I think the winding on the CH1 and CH2 coils need to be cw on one and ccw on the other.
                    • Morpher did some experiments with the buzzer coils and found he could spin a compass or actually two compasses both in the same direction, he was using factory solenoid coils that Im sure were wound in the same direction, if they were wound opposite I'll bet the compasses would rotate opposite.
                      • Has anyone found a source for the caps?
                        • Building
                          When you finally settle on the Caps used inside of the main coil they will have a tolerance that needs to be considered. The coil L1a and Cap C1 must be tuned to be the same as L1b and C2. You will have to adjust the turns ratio to get the resonance to match. Good luck on your building. I am investigating the Hendershot model 1 which has nothing to do with the version you are trying to build.
                          • caps source info - waiting on answer from supplier
                            Hello Dave45,
                            clarence here,
                            I have just e-mailed the spec requirements from a good source and am waiting for their answer back to me. The company I notified to was the NICHICON capicitor co. they have a new type of bipolar cap. it is their VP series bipolar screw terminal can type capacitor. I requested they send me the part numbers for their VP series bipolar screw terminal can 500uf 500v
                            and also their VP series bipolar screw terminal can 1000uf 500v capacitors which they supposedlly have and also to advise me of their closest distributor to me. they acknowledge having thanked me for requesting their components and acknowledged having receieved my transmision request!
                            so I will await their return message to me. LOL for us all - we'll see.
                            mike,onward!
                            • Complete Hen Der Shot Motor File got everything you need in http://www.rexresearch.com/hendersho...rchivesLJH.pdf ...
                                Interesting.....
