Martin Grusenick | Extended Michelson-Morley Interferometer Experiment
  • #31
    "I thank you very much for sending me your careful study about the Miller experiments. Those experiments, conducted with so much care, merit, of course, a very careful statistical investigation. This is more so as the existence of a not trivial positive effect would affect very deeply the fundament of theoretical physics as it is presently accepted. You have shown convincingly that the observed effect is outside the range of accidental deviations and must, therefore, have a systematic cause [having] nothing to do with 'ether wind', but with differences of temperature of the air traversed by the two light bundles which produce the bands of interference." (Shankland, 1973a, p.2283) Albert Einstein.
    Hi guys. This is a quote from Tagor's link that shows the attitude that finally buried Miller's results. Thanks for the reference Tagor. Really interesting. It seems science is progressed by popular vote rather than experimental evidence. More's the pity. This could have resulted in a 'rethink' of light propogation - years back. Still. Hopefully aether is now on the rise.
    • #32
      Temperature stratification of the room that exactly matches the profile of 45 and 225 degrees (the angle of the actual device when the interferometers are reading 0 and 90 ? AMAZING.
      More amazing that the actual results would be lol
      • #33
        Hi Jibbguy. INDEED.
        • #34
          the vertical
          Originally posted by witsend View Post
          Hi morpher44. I checked out the link. All they've done is refined the apparatus and measurement on the horizontal plane. Nothing about the vertical. Why is this never considered? Seems strange.
          Yes. I think we should chase these guys down and get them to try it!!!
          • #35
            I think it has something to do with jumping out the box thingy.
            • #36
              Well said Quantum.
              • #37
                or falling out of the box
                Some other experiments to try for the Michelson-Morley thing are:
                * Performing it in the vacuum of space farther away from planetary or sun
                gravitational influences -- within the limits of man's ability to do that.
                * Performing it in free-fall from high altitude
                * Performing it as deep as you can go in the oceans or in caves
                * Performing it within yet another spinning frame of reference
                * Performing it in a Faraday cage
                * Performing it in some sort of MAGNET shield
                Due diligence?
                • #38
                  Was this instrument pointing true bob plumb of the Earth?
                  The Grusenick interferometer may detect the eletromagnetic bob plumb of Earth?
                  I discovered I can do something similar with a cheap equipment:
                  An AM receiver (MW or LW) has an internally ferrite antenna. This antenna has
                  directional properties and is used infinding for the guidance of boats and airplanes.
                  In the horizontal position and out of radio station, white noise (hiss) is caught up. Upright, white noise is minimum.
                  Using a acurate voltmeter, it is possible to measure the intensity white noise. Upon reaching the lowest noise value obtained, to measure the angle of the axis of the coil ferrite from the plane horizontal.
                  After several measurements, it is possible to reach to plummet by applying electromagnetic bisect of the angles obtained.
