Think i found some missing info from Tesla's radiant energy patent
  • #91
    Hi nat. I just want to say how I see this patent.
    The plate should be insulated from ground that is the plate itself should not be isolated so the radiation can throw out the electric charges. This way the plate becomes positively charged relative to the ground.
    • #92
      Yeah i think you are right..I think i am confused on how to maintain a negatively charged plate and splitting the positive at the same time.
      i will change the circuit slightly.
      • #93
        Trying to understand Tesla's writing and what he meant.
        Tesla's quote :
        preferably highly polished
        What do you think that T means by "polished"?
        Just to keep the plate protected by corrosion and rust?
        What ways are for polishing a metal plate? Especially at 1901 ?
        Michael
        • #94
          it would appear that there is strict criteria to get this system to work.
          1. proximity of plate to the HV spark (edwin grays system is very close to the spark) It would appear that on low power systems that the plate needs to be very close to the hv spark. On extreme systems like Tesla's then it appears it doesnt matter so much
          2. The HV spark is presumably emitting UV light to the plate (as descibed by Tesla's patent)
          3. The plate needs to be negatively charged (as described by Teslas patent)
          4. type of metal used for the plate (as determined elsewhere)
          5. Polished plate
          6. Of large surface area.
          5 & 6 are probably not as important as items 1 to 4
          • #95
            Today i got around 800-1000volts sparks from the plate i installed.I couldn't believe my own eyes so i call a friend to witness this.
            The plate i used is a copper 2mx1m on 12 meter height and the ground is a copper plate 1mx1m 1 meter deep.
            • #96
              Cool. Are you able to post a video?
              • #97
                Now the energy is not pulsing but is more like flowing.
                Check my channel hfaistio energy from air
                • #98
                  Wow!! I watched you videos...
                  Now can you add equal and opposite pancake coils either Side of the neon bulb
                  • #99
                    @tomata
                    Please advise the following:-
                    1. is your plate negatively charged prior. e.g by connecting the plate to a battery (or other source) either temporarily or permanently
                    2. The approximate elevation of your plate
                    3. The value of the resistor
                    4 Are you near HV power lines?
                    Nat
                    • Please advise the following:-
                      1. No.As i understand the plate is positive charged.When the energy flows the environment is negatively charged by nature without me doing anything.
                      2. 12meter
                      3. Which resistor?
                      4. No
                      • Exactly. The cosmic radiation is nocking off the electrons in the elevated plate and making it positive in relation to the ground.
                        Which metal has the largest no. of free electrons?
                        • update
                          The environment/the air when is charged negative then the earth/the ground is charged positive.When this situation appears i have a flow of energy.
                          When the earth is negative charged and the air is positive charged i don't have any flow or sparks.Only 3 to 4 volts a/c showing on the scope which is barely light a led once every few seconds.
                          • This is amazing...Your experiment is the best one i have seen yet to duplicate Tesla's patent.
                            Does it work with other metals?
                            • @ Tomata:
                              You were able to get 800 volts? Is there a link to a video of your set up?
                              Do you think that it could be done using metal zinc coated roofing sheets that are about 3" by 8" feet, and a solid copper 6 foot grounding rod.
                              NickZ
                              • Originally posted by nat1971a View Post
                                Dont know,i only try copper.
