OU.com is broken.
  • #16
    Originally posted by wattsup View Post
    I am thinking this could have something to do with SM posting on the forum recently but this would be construed as totally pretentious on my part. Which it is. lol
    Oh? I managed to miss that. Was it surely him, and was he opening up at all, or the usual half-help of an inventor whose work has not been confirmed yet?
    • #17
      Who's SM?
      • #18
        SM = Steven Mark inventor of TPU (Torroidal Power Unit ?)
        • #19
          Steven Mark, wow, I didn't know he was still alive!
          • #20
            Hello all,
            @wattsup
            I have to agree with you.
            SM gave us in his last post the secret of his TPUs and now its really not a problem to build one.
            Otto
            • #21
              Originally posted by Otto- View Post
              Hello all,
              @wattsup
              Otto
              Did he gave on OU.com?
              Can you share that info?
              • #22
                Hi Otto
                Not a problem to build one now huh? Please enlighten me? What was his last post and where can I find infor to build one of his TPU's?
                • #23
                  @ Mark
                  SM (to my limited knowlege) is Steven Marks of TPU fame.
                  @ otto
                  If you would have a synopsis of SM's latest info I'm sure MANY here would greatly appreciate a posting of it here (since OU is unavailable) in the spirit of Open Source.
                  @ all
                  OU is definitely in the ditch.
                  I was curious as it's a much visited web site (along with EF here) so I did a little IT snooping.
                  Going to the website [www.overunity.com] loads up a blank page.
                  Going to the default start page for a php based website [www.overunity.com/index.php] asks if I'd like to open or save index.php (saving results in a 0KB sized file with no content).
                  An "nslookup" of OU reveals the DNS (Domain Name Server that translates a URL to an IP address) record as:
                  Non-authoritative answer:
                  Address: 77.232.83.101
                  ....but when the IP address is used in a web browser [Website not yet configured with and without /index.php] a reply from servage reveals:
                  I'm not sure that it's a malfunctioning module/script or webmaster error that is causing this. It would seem from this output that Servage may have lost the content.
                  I hope Stefan has a backup.
                  Last edited by exxcomm0n; 08-18-2009, 04:39 PM. Reason: address posts made while writing this
                  • #24
                    Hello all,
                    ha,ha,ha.
                    Guys, you could read that at OU com until yesterday.
                    OK, I will give a try:
                    SM mentioned that the TPU amplifies "something" from the outside and thats more then enough for me.
                    Why?
                    I already have a micro TPU and see this:
                    at 245kHz I see a little vibration on my scope. I see this vibrations at some other frequencies too but they are of no use for my TPU.
                    At 245kHz my TPU is charging up, the current dropps and I have some light.
                    This happens ONLY at 245kHz.
                    When I add another frequency the light is much better
                    but
                    it happens that this 2 frequencies are "fighting" each against the other, my micro TPU discharges and I see a dramatical rise of current.
                    My micro TPU gets sooooo hot that its impossible to touch it.
                    I already have blown with only 0,6A from my power supply 1 of my micro TPUs.
                    If this little TPU is not hot the beast doesnt work.
                    Of course, there is needed a vibration. This vibration we get with the frequency of 5kHz or 6kHz. This frequency is used to amplify the signal at 245kHz. It must be a physical vibration. This is very important.
                    This all I see and thanks God, this is NOT a speculation. I see it. I have only to build a TPU with a bigger diameter and use the knowledge from over 150 builded TPUs.
                    Otto
                    • #25
                      Hello all,
                      but
                      Hi Otto,
                      Do you think you could get your micro to work at 2.2 - 5 MHz with an underwave of 22Khz? or 172Khz?
                      I am repeatedly getting these frequencies on my earth battery and when that is augmented by 2 stubblefield batteries - one on each end- the voltage of the 2.2mhz peaks is about 40-67.5 mv.
                      I think. I am not completely sure if the scope is reading the peaks of the carrier wave or the little spikes, but I believe the little spikes.
                      When I look at the wave from a lower resolution I see waves of waves (in a fractal type form) and I wonder if you can use these for the pulses you are needing.
                      I am trying things in this direction but you and many others are way ahead of me on the tpu end, I thought I would mention this as perhaps you can use it.
                      jeanna
                      • #26
                        @otto
                        Can you post link to you micro-tpu schematic ?
                        Did you deciphered SM statement about two currents flowing across the same wire and that they are independent EXCEPT some case which Sm seems not evolved further ?
                        • #27
                          Hello all,
                          @jeanna
                          the main frequency is 245kHz and the 5 or 6kHz that amplifies the kicks - power with a vibration.
                          But I see something in the MHz range. It could be in the range you mentioned.
                          Mannix posted once a picture how to build the coils and we saw that F1 and F3 should be pulsed in the same wire. Now its clear why: F1 is 245kHz and F3 is 5 or 6kHz or something between this values.
                          F1, F3 = frequency 1 and frequency 3.
                          @boguslaw
                          I dont have a shematic until I have built a bigger TPU.
                          Yes, I see something weird when 2 currents are in the same wire but I didnt had much time to look deeper.
                          Otto
                          • #28
                            Freedom of Information
                            Originally posted by broli View Post
                            That explains a lot. It's funny he went on vacation with no one around fixing things up if it goes down, I guess he thought his forum isn't that worthy.
                            Hi broli,
                            I thought that adding some information you and other members may find interesting .... "PUBLIC INFORMATION" .....
                            WHO IS - Overunity.com - Over Unity - Free Energy Freie Energie Energia Libre Énergie libre Alternative ZeroPoint Green Tesla Power Open Source Research Forum
                            Domain name: overunity.com
                            [email protected] is associated with about 6 domains
                            Registrant Contact:
                            Hartmann Multimedia Service
                            Stefan Hartmann ( [email protected] )
                            Fax:
                            Keplerstr. 11 B
                            Berlin, Berlin 10589
                            DE
                            Administrative Contact:
                            +49.3034500497
                            Fax: 493034500498
                            Keplerstr. 11 B
                            DE
                            Technical Contact:
                            +49.3034500497
                            Fax: 493034500498
                            Keplerstr. 11 B
                            DE
                            Status: Locked
                            Name Servers:
                            ns1.servage.net
                            ns2.servage.net
                            ns3.servage.net
                            ns4.servage.net
                            Creation date: 19 Nov 1997 00:00:00
                            Expiration date: 18 Nov 2010 00:00:00
                            This is a "ONE" man Stefan show all registered to Hartmann Multimedia Service
                            [edit - Alexa Trend/Rank: #215,746: Down 35 ranks over the last three months. ]
                            There are other sites "Hartmann Multimedia Service" has that are up but Over Unity is "DOWN", and with all the upset people from all the past problems and using mass "internet" sales on every single page to supplement funds for other ventures and not the FE energy movement, it may have started the ultimate demise of OU ...... RIP
                            @ Aaron maybe you may make a exception to reinstate on a temporary bases some earlier members that have been banned ....
                            Best Regards,
                            Glen
                            Last edited by FuzzyTomCat; 08-18-2009, 09:13 PM. Reason: added Alexa "rank" information
                            Open Source Experimentalist
                            • #29
                              ITS BACK !!!
                              Glen
                              • #30
                                Not for me its not!
                                I'm having problems getting onto OU.com every week. At the moment i get the message
                                ''Database error''
                                The MIB must have realised the progress I've been making........
                                No OU yet....but i can smell it....its close
                                and i'll certainly be sharing (as i was when OU.com was working) with everybody!
