Hello, All,
I may have found something... Please, try it, and leave a feedback.
All you need is common material among users around here.
Feed a Bedini like 2n3055 with a 555 to the base (put a diode in between, not shown on the diagram) and through a car coil to the collector (leave the coil's flyback unwired). After the collector, put 2 diodes in series (1N4007), then a regular 60w bulb (mine is 230V, cause I'm in Europe... Maybe users with 110v regular bulbs will get better results...). Plug the bulb's other leg to the earth. Just put a capacitor in parralel with the bulb. Then watch the filament glow strong yellow, almost lighting the bulb (like if it's fed with 20w...).
The psu gives out 12.25v @ 1.25A. The bulbs is @ 120v AC, amps to the earth reads 0,290A AC // freq= 476.2 Hz duty=71.5% ...
If I don't plug the bulb, but leave the capacitor attached, it goes up to 500v in 5 seconds (discharge it (400V 470uF) through the bulb : the bulb briefly lights about half).
Below is a diagram attached (pdf).
I'd like your feedbacks, since it seems amazing : 16w in, more than 30w out ... ?!!!! Wow...
. And there's not much light in my bedroom... I'll try maybe, if I can get better results...
