Glad to hear you bulilt one
Hello Rave154,
Glad to hear you built one!
I've done 1 replication of the GSA a little while back and also used JLN's schematic.
I do not have a scope. I reasoned that if the output voltage exceeds the input voltage like what Seike/Naudin reported then it will justify me buying a scope to further investigate this device.
My results:
At [email protected] input I got 20-21VDC output, however,
2 of my 3 voltage(one analog, one digital) meters reported the same while my RMS meter reported around 10-12VDC.
Which do I believe?
Another problem was that even though the GSA ouput is Fully-Bridge-Rectified and filtered by a capacitor I get AC readings on the digital and analog meters.
To me it looks as if the AC being generated in the transistorised coil cannot be properly rectified with standard 1n4007 diodes. I reasoned the AC in this circuit may be oscillating at the transistors (2n3055 npn) maximum of 2Million Hz which as I imagine regular diodes are not suited for.
I will at some stage look into fast switching diodes.
Perhaps someone can suggest a part number for a diode you think will work?
One last observation. The heatsinks I'm using are large (about 10x12cm).
Leaving the unit to run for 30 minutes causes much heat.
I understand that this specific GSA will use around 35-40watts, however I expected from what Seike wrote that it would run cold with negative energy moving through it.
I'm about to start with my second GSA. This time it will be based on Seike's NPN design using 3x2SC521A transistors.
I also noticed this design is not in the 8th Edition of The Principles of Ultra Relativity book.
Also there are numerous sections of the book that have been removed.
Chapter 14 - Solid State Battery (Revised) (Ceased)
Chapter 19/20 - Tachyon Oscillator (Revised) (Ceased)
The 7th Edition also contains 349 pages and the 8th Edition only contains 188 pages.
As seen here the next design I will build. I dont see this in the 1986 Edition of Seike's book, so I'm guessing its from the 7th Edition -->
cheers
Hello Rave154,
My results:
Which do I believe?
cheers
