Do I Belive Perrigo Was A Fraud? No. Every Demonstration He Showed Included An Electric Motor And I Think A Battery Hidden.His Inability To Come Clean Even Unto Death Was His Only Downfall. Now The Year Is 2009 And I Took A 12V Battery, A small .190amp PM motor, and hooked them up. Then with a handheld AM transistor radio, I moved the radio around the circuit,I was amased at what I heard. No longer do I have straight DC but fluctuating energy I can work with,to step up and collect or use somehow. So I took a microwave oven transformer apart and put the primary in series with the motor, and laid the secondary directly on top of primary. I got 2volts and lit an led quite easily. Now if these primary coils are in paralell, they will all fluctuate reguardless of how many are used. Dosent seem to matter weather they are on the negitive side or positive or both. Even the battery itself fluctuates . Try it for yourself and move the radio around and listen. Now bigger motor,more amps,means stronger field around primary coil to be induced in secondary. This is nothing new, its been right in front of our nose all this time.At Least I never realised it.Perrigo worked on motors and generators just found a way to keep the battery charged by the fluctuating coils as the motor turned and was able to run an extra load as well. Reguardless if this was his technique or not, this is a possible new avenue that is simple and actually works, and needs to be explored by all.One battery ,one motor , and coils in paralell with secondary pickup coils attached to each one.I am currently at a standstill as to what would be the most efficent coil arrangment to use ( air core , iron core ) , and feel one on positive and negitive both faceing each other in generator fashion might work too. Not tried it yet.I did leave it running from 10:00PM till 8:00AM while lighting an led and still used less than one volt. I need help with this and comments are appreaciated, serious ones only . Thanks. Gday and Peace
Could This Be Perrigos Generator Principles ?
