over 1.0 cop system
Just for a reference, anyone can follow up on the references:
Chemistry 1977
Ilya Prigogine - Nobel Lecture
Basically, in Chemistry and other systems, 1 + 1 can equal 3 instead of 2. Not just in concept but in actual results backed by experimentation. The word SYNERGY in the English language and I'm sure other languages have heir own word for it is a word that implies something, which violates thermodynamics. The combined results is more than the sum of each individual part. That means there is other input that didn't come from the apparent contributing sources.
I first learned of Prigogine's concept about 8 years ago in a health book that discussed open dissipative systems. I was shocked later on to learn of the implications of it as it relates to energy systems.
Here is a govt souce admitting more work done compared to fuel consumed - it is misleading as it doesn't use cop but EF as energy factor but this is an authentic example:
This defines energy factor:
Energy Savers: Determining Energy Efficiency of Storage, Demand, and Heat Pump Water Heaters
"The energy factor (EF) indicates a water heater's overall energy efficiency based on the amount of hot water produced per unit of fuel consumed over a typical day."
EF accounts for standing losses and cop doesn't.
This page:
Energy Savers: Estimating a Storage, Demand, or Heat Pump Water Heater's Costs
shows an example of a heat unit that has an EF of 2.0.
Please don't be mislead by their math of showing cost effectiveness because cost is irrelevant in the fact that 2 parts of water is heated for each 1 unit of fuel. That is 2 times the work done for 1 unit of work input.
So with EF and with losses, there is STILL 2 times more heat produced for each 1 unit of work input.
It is possible of course to have a over 1.0 cop unit that is less cost effective than a lower cop unit it if is expensive technology, etc... but nevertheless, it is producing more heat in the water than fuel consumed. But the point made is there are units producing more heat than fuel source consumed.
Here is one example of a hot water heater heat pump.
Household heat pump water heater KF80-A/150 Household heat pump water heater CN;
It has a COP of 4.5 or more. That means there is 450% more heat produced than joules of energy in electricity that it takes to run it.
A typical hot water heating element may need 3000 watts and with a heat pump, it can produce the same heat for around 600 watts. The heating element only uses the current to produce heat very efficiently almost or sometimes even considered 100% efficient - since dissipation in the form of heat is what is actually desired. A heat pump unit at 600 watts does the same heat for 4~5 less input because it uses free environmental work in the form of heat movement that we don't have to pay for but it does contribute to WORK being done in a measurable way.
No magic here and any true "free energy" machine operates the same way but in the case of electromagnetics, etc... it is environmental input like gravity (mechanical oscillator), time potential, quantum potential from vacuum space, etc...
Originally posted by Aaron
Chemistry 1977
This page:
