Hi Luc.
Thanks for the schematic you sent me. I could not get to energeticforum for couple of days for some reason. Anyway, today I replicated this effect using light bulbs. The coil had about 200 turns of AWG21 wire, air core. The timer was set to about 7% duty cycle and frequency of about 1.6kHz. The bulb on the negative terminal did not even light up, was just barely red glowing, but the bulb on the recirculating side was at about 40% brightness. I measured current flowing through both bulbs, on the negative side bulb it was about 130mA but on the recirculating side it was 620mA. That is about 4 times more. This was done with pulsing about 60 VDC through the coil using an array of batteries in series. Will try out more coil setups and voltages tomorrow. Great stuff!
an inductive load. Like a fan perhaps.
