Volatge Generator - No current
  • #16
    Originally posted by baroutologos View Post
    Ok guys,
    Nothing special. We can have as much voltage as we want literally.
    The one millions dollars question/answer is:
    HOW WE TRASFORM VOLTAGE TO USABLE POWER.
    In conventional physics you need the electromotive force to start your electrons flowing i.e.the voltage.
    But, work is produced by the current or the "mechanical energy of moving electrons"
    So guys, I give you free voltage, you give me free power? :P
    Baroutologos
    Is it a one million dollars question? Can I give it a shot and and get a few hundred bucks if partially correct? lol j/k
    Well, if you have high voltage or static charge, you can make an electrostatic motor. Electromotive force is contain within the high voltage itself and constantly in oscillation. Current is always there. It is just in AC form of super high frequency that makes it useless. If you can rectify gigahertz to tetrahertz, you will have unlimited DC from any electromagnetic waves, higher than those frequency, maybe gravity wave . Current diode technology is too far behind. The magic thing about electrostatic motor is they can rectify through circulation.
    • #17
      So easy huh?
      @ Darkwizard
      Done that. The ac currentless electricity is converted to dc. SO what? Diodes work with potential only. Caps not. Caps in order to charge need voltage application AND a way to move the electrons around. (from one plate to another)
      Have you any solution for that?
      * By the way, Avramenko plug shows some promise if true, alsoi do not know the amounts of power involved there.
      Anyway,
      Then, i expect from someone gosu, to make the modeling of a machine, the testinga and if OU, video capturing, schematics etc
      For me, to convert voltage to power it's beyond my skills.
      Baroutologos
      • #18
        My circuit was actually a stun gun I was building, but half way through breadboarding it I remembered some of Frolov's stuff, so I decided to give it a try. No resonance or anything, just entirely improvised. Heres the schematic I was building, I stopped at the transformer part and used that.
        It was interesting to note that grounding the other secondary lead dramatically increased performance.
        High Voltage Dazer
        I will video the circuit's operation if there is sufficient interest.
        • #19
          What would happen if we'd put a coil in between charged capacitor plates?
          Something like this:
          Code:
                       \                              LOAD
                       /  L                             |
          The idea is that if you have a (HV) open air charged capacitor, you have a "static" electric field in between the plates. This should act on any electrons inside a wire or a coil, moving them along the field and thus creating a current, which can be used by a load at a certain distance from the plates.
          What do you guys think?
          Could this work, or did I overlook something?
          Add:
          Of course, one could also imagine a coil wound on a square, flat piece of plastic or something, that is put half into the capacitor, such that of every winding, there is one vertical wire inside the cap , and the other outside. This way, the effect could maybe be amplified.
          • #20
            Looks like a similar idea has been discussed here:
            Electrostatic induction in a conductor
            Interesting food for thought.
            I have attached the two word documents posted there, so you won't have to register in order to read them.
            • #21
              Tesla pancake coils have rather high capacitance.
              This is all worthy of experimenting with. Thanks barb.
              • #22
                Looks a little like this
                • #23
                  By the way, I did a little experimenting on this.
                  One strange i noticed more than once is that, if i connect the two wires of potential (and no current) to a capacitor terminals, voltage is vanished. ???
                  Baroutologos
                  • #24
                    What do you mean voltage is vanished?
                    Like you can't use it to charge a capacitor?
                    • #25
                      Like the DDM registers no more voltage
                      Baroutologos
