Other than mechanical, no transistor
@ teslaproject - I have considered ideas that aren't as 'mechanical', but haven't tried any out so far..
Short term, this may work for you;
Solid State Relay 3-32VDC Input 100A@30VDC Switching - Jaycar Electronics
The best idea I had for a non mechanical non transistor non reed switch non relay switch involves the coherer;
StateMaster - Encyclopedia: Coherer
A hv spark from a coil collapse causes the Filings to cohere, which begins conducting, charging up an electromagnet (to decohere the mixed magnetic & non-magnetic filings) which is also a transformer (which will later create a spark) then going off to run whatever you need running.
When the coherer stops conducting, the electromagnet's field collapses, creating the spark in the secondary's spark gap that starts the whole process again..
It allows the use of 12-36 volts to run things, while still creating the hv spark to manipulate the coherer.
I haven't tried it out. To tell you the truth, I'd forgotten about it until you asked, and was able to improve the design in my brain lab.. Thankyou for jogging my memory.
And for giving me food for thought.
Love and light
Love and light
Sometimes low tech is best.
