Secrets of Stan Meyer's Steam Resonator...
  • Secrets of Stan Meyer's Steam Resonator...
    We know from Stans work and others that the water molecule is a polar molecule.
    That being so, the water molecule can be put in motion using positive and negative electrostatic forces. In a microwave these forces are used to cause the water molecules to move back and forth at microwave frequencies, creating kinetic energy (HEAT).
    We know the Steam Resonator is made from two tubes, one inside the other (Coaxial)
    Tech Brief page 11-4
    "Constructed in such a way as to allow a smaller tube to be placed inside a much larger tube having space relationship to allow water to pass there between"
    Stan Meyers definition of the Steam Resonator
    "Defined as heating water by alternate pulsation of opposite voltage fields at different pulse time-on periods"
    In an experiment I was easily able to charge water with a high electrostatic charge using an ignition coil. The water was not grounded, nor was the plastic container that held it. After removing the coil the water retained it's charge, and the plastic container also had a charge. The static electricity shocked you as soon as you touched either the water or the plastic container.
    "Water bath takes on an electrical charge when the rotational spin of the water molecule occurs..."
    In the Tech Brief Stan mentions many times that the water molecule uses either a positive or negative charge to cause the water molecule to move. This causes a pulling effect on the water molecule. He later discovered that by applying the same polarity to both voltage zones at the same time he could also have a pushing effect on the water molecule, therby increasing efficiency.
    Tech Brief page 11-5
    "Singularly places either a positive voltage potential across both voltage zones and/or a negative voltage potential across both voltage zones....In doing so, electrical repelling forces now exerts a "Pushing Effect" onto the allready deflecting water molecule"
    Basically, the steam resonator is made from coaxial tubes in which a positive high voltage or a negative high voltage is applied to both tubes at the same time, and in which the polarity is switched at high speed.
    The Pulse Width, Voltage Amplitude, & Switchover pulse rate determines the rate at which the water is heated. (Stated in the Tech Brief page 11-5)
    Then we read about the VIC switchover circuit which is what was used to switch the polarity applied to the coaxial steam resonator tubes.
    Last edited by HMS-776; 01-22-2012, 05:07 PM. Reason: Schematics and info delected, not correct
    No offense...but, that is not what the Tech Brief shows at all...
    In fact it shows TWO identical transformers, with the electrodes overlapping...
      Yes it does. If you read the section on the steam resonator you'll find there is more than one way of doing it. The one I talk about most is shown on page 11-13, figure 11-7.
      That one also shows two resonators but 1 will do the same thing. It works basically the same way a microwave does (except without the use of radiation) by using opposite pulsed voltage fields to cause the water molecules to move in a physical manner, therby creating kinetic (Heat) energy.
        Well, if it works as shown please show us.
          What you say about applying the same polarity to both zones (inner and outer tube) is interesting and I will definitely try it. But, how can the molecules orientat ine one direction if ther is no difference in potential? What I can imagine is that the field lines gets coarser at larger diameter, but if that has an effect it would only be a very small effect. If you pulse (-/+) -> (+/+) -> (+/-) -> (-/-) it would make more sense to me. Or is it anything I have missed?
          By the way, may I ask what tube sizes you have used? I assume a tube spacing much larger than in the HHO case would be fine, but haven't tested yet.
            hi hms-776 i once had the effect of the steam resonator i was using two tubes but the inside tube had mylar foil rolled around it and when the water started to get between the mylar laminations it instantly became like a geiser steam and steam. i was using a flyback transformer an voltage was about 2000 volts when it started to steam fail hehe
            hope that helps
            if you want read my posts
            peace and look at vic voltage sync pulse circuit this realy works but the coils must be thick wire
            tip use multisim 10 to make simulation
            you just need to recirculate the current as you said in another post voltage is = to amps x resistance
