Hi folks, this thread is based on a simple generator principle that im sure others have already discovered, however after tests with a simple design i built it seems to work rather well and has very little cogging drag. I originally built it to test flux gate generator principles where a piece of metal or bolt in this case passes between a stationary coil-core and a stationary permanent magnet to generate voltage/current, however what I have found is that if the magnet is placed at the back or other end of coil-core the generated voltage is almost the same and the cogging drops to a very low level. So whats happening I assume is that as the bolt or iron, etc. passes the stationary coil-core with permanent magnet placed at back side of core, the neutral or bloch wall of the permanent magnets field is shifted more towards the rotor gap which emulates the expanding and collapsing magnetic field required for induction and with very low drag and no lentz drag either because only steel is rotating. If anyone else has experimented with anything similar or has any thoughts please share them, thanks. Here is a cad pic of the simple layout.
peace love light
peace love light
