Not seeing the Negative energy
  • Not seeing the Negative energy
    Hi,
    I would like to know what i would need to do to get the negative energy out of my SSG. The motor seems to be running fine with 12 ceramic magnets on a 10 inch wheel. I m am posting the output of my oscilloscope:
    http://groups. yahoo.com/ group/Bedini_ Monopole3/ photos/album/ 1924464571/ pic/1989494224/ view?picmode= &mode=tn& order=ordinal& start=1&count= 20&dir=asc
    where are on the nergy from the vacuum DVD 7. I posted bedini output :
    http://groups. yahoo.com/ group/Bedini_ Monopole3/ photos/album/ 1924464571/ pic/334321589/ view?picmode= &mode=tn& order=ordinal& start=1&count= 20&dir=asc
    The two waves are very similar, but mine to not go below the reference voltage , 0 volt, while his goes 12v below.
    I build 2 motors and I get identical results, does anyone has an idea what is wrong?
    thanks
    K
    negative energy
    Lerameur,
    I don't know if this would help you at all but this is one of my old vids:
    YouTube - Bedini SG | Inverted circuit "E-AMP"
    Actually, I believe you're doing it already with the SG's.
    The inductive spike coming back when a coil collapses is a negative voltage. It is not simply a negative voltage. The properties of that voltage spike are different than positive voltages.
    Caps charged with it can jump a gap further than the normal dielectric breakdown voltages that are supposed to be associated with the positive voltage equivalents.
    There are other traits that are different too.
      HI, thanks for the reply,
      but if you look at the scope reading, the spike is at the beginning of the impulse, not at the end, therefore I believe the spike is not coming from the coil collapse, am I wrong here ???
      k
