Bernoulli principal and the vortex
air speed over wing
Ted,
I always thought that the air was faster on top of the wing because the air hitting the front of the wing will get to the back of the wing at the same time whether it goes over the top of under the bottom. The air on tops goes faster because it is forced to travel a further distance (the hump or camber of the wing) until it gets to the end of the wing. The air on bottom goes a smaller distance...almost straight line.
Is that not accurate?Sincerely,
Hi Aaron,Originally posted by Aaron View PostTed,
I think it speeds up merely because it gets compressed. I think it does indeed have something to do with the Bernoulli principal. I took that passage from an another article which is why I put it in quotations. I should have thought it out some more.
Another interesting aspect of vorticle phenomenon, that is somewhat related to this, is gravity. If we look at atoms as a vortex within the aether, we see that pressure gets progressively lower towards the axis of rotation. Perhaps there is a corollary with planetary structure and gravity. Maybe there is a big vortex within the aether that is holding this planet together and creating gravity. Gravity may just be a pressure differential caused by variations of angular velocities within the aether.
The pulsed vortex has a lot of potential. It's a lot like a mechanical capacitor, where it can store up kinetic energy and then deliver it all at once. It has some other very intriguing possibilities too.
Ted
@Ted
Hm, I always thought that in a vortex there is a higher tangential speed at the outer shell of the vortex and lower tangential speed near the centre of vortex. If you apply Bernoulli's principle to that concept one would expect to see reduced static pressure at the outer shell of vortex and lower static pressure toward the centre of vortex. That would explain a portion of friction reduction between fluid forming the vortex and the tube. Apparently the increased pressure in the inner layers of vortex should cause the fluid flow centre of vortex to its edges which should destroy vortex centripetal motion of fluid and occurence of chaotic turbulences. Of course that doesn't happen in the real life systems. The Bernoulli's principle also includes dynamic pressure (and it's relationship to static pressure- net value is always the same) and account for density of fluid.
The way I see it higher tangential speed at the outer shell of vortex is causing the reduced static pressure and reduced tangential speed toward the centre of vortex is causing increased static pressure. Of course the geometry of vortex is not a simple linear movement like the model used for representing Bernoulli's principle so there must be a specific pressure distribution between layers of different speed which should support forming and keeping the state of vortex motion of fluid.
Any thoughts about this and do you have more links regarding inner structure of vortex? Now you got me interested.
Hi Lighty,Originally posted by lighty View Post@Ted
There is no question that angular velocity increases toward the axis of rotation in a vortex. I'm not quite sure if it's exponentially, but it's close.
In fact, in a Hilsch tube the air is rotating so fast that the inner core actually reverses and rotates in the opposite direction. This phenomenon is also seen in the eye of a hurricane where it is relatively calm.
Speed is key to getting a vortex to exhibit its properties. The faster it rotates, the better. This usually requires a mechanism that can convert a high pressure flow at 90 degrees to the axis of rotation, much like the Hilsch tube does.
I've designed a vortex generator using PVC pipe that develops exceptional velocity, which I'll be using in my turbine. I'll try and get a drawing together later today to clarify what I'm talking about.
Cheers,
Ted
OK, I'm not the best draftsman so I hope this drawing is clear. This is a simplified side view of the turbine in a 55 gallon drum. Rotation is initiated by a motor. As the turbine spins, water is drawn up and forced out to the nozzles through centrifugal force. The force of the water at the nozzles increases with angular velocity of the turbine.
This next drawing is a top view of the nozzle assembly. It shows the basic setup plus water flow.
This is a cutaway of the inside of the nozzle assembly.
As the water is forced into the tee, it is compressed and accelerated through the use of a ramp, and then the decreasing area in the tee. At the point of maximum velocity, the water enters the smaller pipe through a small slit in the bottom. This imparts maximum velocity to the outside diameter of the vortex. As the outside of a vortex spins the slowest, this further accelerates the inner layers. The high pressure, low velocity of the water in the 2" feeder pipe is converted into a high velocity vortex which acts as a compressor.
When the flow is cut off at the nozzle, the vortex continues to rotate at a high speed due to it's angular momentum. As this high speed flow passes by the virtually stationary water at the slit, it sucks water in due to the large pressure differential. As more volume gets added to a finite space in the vortex tube, some water gets "reduced in volume", but mostly the pressure starts to rise.
At this point I'm not sure exactly how high the pressure gets compared to the pressure in the feed pipe. I know it will get higher, but I think it depends on the speed and mass of the vortex at the time of closure. It also depends on the amount of time it has to build up pressure. It does need a certain interval of time to work.
Once the nozzle is opened, water is accelerated out of the vortex tube in the direction of rotation. It then hits a 180 degree deflection pipe or trough in order to convert the kinetic energy of the water into work. This deflection pipe is connected to the nozzle assembly.
The water is projected out, in the direction of rotation because this adds velocity to it. Since kinetic energy goes up as the square of the velocity, we need all the speed we can get.
There also needs to be a point of resonance for this mechanism to really work. This will be the challenge and I may have to try a variety of modulators to get the pulse frequency to correlate to the turbine's natural resonant frequency. Schauberger did it using lots of small ridges around the perimeter of his container. I'm going to start by using a rotating orifice on the nozzle.
Victor Schauberger used this general theory and configuration to construct a successful power generator so I know it can be done. I don't pretend to know a fraction of what VS did, but I'm starting to get a feeling for this mechanism.
I realize this is probably fairly unclear, so I'll be happy to answer any questions you guys have.
Cheers,
Ted
I realized where I got it wrong. I considered fluid in rotational motion (like in vortex) to follow the same rules as a solid object. If that was the case my thinking would of course be correct (there would be some torsion present and material strain) but the fluid can of course exhibit layers separation due to torsion force present. So, there is indeed increase in angular velocity toward the centre of vortex.
However I found out interesting assertion
Of course Wikipedia is not most reliable source but here is link.What is usually agreed upon is that the air in the tube experiences mostly "solid body rotation", which simply means the rotation rate (angular velocity) of the inner gas is the same as that of the outer gas. This is different from what most consider standard vortexfluidturbulence is kept to a minimum.
One simple explanation is that the outer air is under higher pressure than the inner air (because of centrifugal force). Therefore the temperature of the outer air is higher than that of the inner air.
Another explanation is that as both vortices rotate at the same angular velocity and direction, the inner vortex has lost angular momentum. The decrease of angular momentum is transferred as kinetic energy to the outer vortex, resulting in separated flows of hot and cold gas.
Hi Lighty,Originally posted by lighty View PostI realized where I got it wrong. I considered fluid in rotational motion (like in vortex) to follow the same rules as a solid object. If that was the case my thinking would of course be correct (there would be some torsion present and material strain) but the fluid can of course exhibit layers separation due to torsion force present. So, there is indeed increase in angular velocity toward the centre of vortex.
The vortex tube drives classical physicists crazy. They try and reconcile this phenomenon using Newtonian laws, and the vortex does not operate according to their theorems. The vortex is a primary form of motion, yet it is largely misunderstood or completely ignored. Why is this not surprising?
A vortex never acts like a solid mass except when a body of air or liquid is rotating very slowly. A Hilsch tube certainly doesn't rotate as a solid mass.
Most guys get stuck on heat distribution. They wrongly assume that heat is being redistributed, or generated by friction instead of by compression. The vortex needs to be viewed as a series of coaxial pressure gradients radiating outwards from the axis of rotation. The center is centripetal, which is compressive and reduced in volume. The outside is centrifugal, which is expansive and occupies the majority of the volume. Two forces doing two different things. This is why heat is distributed the way it is.
An interesting side note; my motorcycle (with the vortex generator installed) gains noticeable power the hotter the engine gets. Just like a hurricane gains intensity while traveling over warm water, the vortex gains angular velocity when it gets heated by my engine. External heat adds pressure to the vortex. The increased pressure differential causes an increase in angular velocity, as also seen in a hurricane. This subsequently increases compression, which forces more air into the engine, producing more power.
This is not insignificant, as this is also a mechanism for directly converting heat into mechanical motion.
Cheers,
Ted
Vortex/centrifugal engine
Hi Ted
This is like my idea of vortex/centrifugal engine, of which at the moment I do not have time for, but may be in the future. Look at the thread I started some time ago. If I can be of help I will post some ideas, this I believe has a great future, but is more complicated to construct. I believe that a self running motor is very possible.
Mike
Looks good
I'm curious as to how prime or self-prime your device.
As Mike shows a screw in his image which would self-prime.
A Archimedes Screw or spiral pump would self-prime.
It would require a higher rotation speed to void the air via
self-priming.. The air might not be voided and will be very
hard to determine if it is or isn't voided. I guess it matters
not to know this.. you just run it faster?
Capping the bottom inlet and the nozzles, the device could be primed.
The bottom inlet cap could then be removed and the device would
remain primed. Almost no changes to your current design..
trouble is how to uncapped the nozzles after the device has be
brought up to a speed that would prevent air from entering the nozzles.
I learned the hard way that an expandable rubber plug does not work
for priming a 2 inch x 4 1/2 foot tall pvc siphon.
You have to use pvc screw on caps.
A thought, a 2" 90 degree elbow upon the end will create the housing for the
high vel. vortex with an output at 90 degree to the rotor without a 180 degree elbow.
RandyRemember to be kind to your mind ...
Hi Randy,Originally posted by Vortex View PostLooks good
Randy
Priming has been a serious pain with my past turbines. I did manage to rig up an external pump that injected water up the center pipe in order to prime it. Although this works, it's a complicated joint which isn't very strong. With this new design, the nozzles will be capped, so a priming port on top of the middle tee might work. I would be using one way input ports at the bottom of the siphon pipe to prevent back flow.
I designed a bunch of "pump" adapters that fit on the bottom of the siphon, none of which worked worth a damn. I couldn't get a 2" column of water up even 6 inches!
A tee on the end of the arm is exactly what I have planned for the vortex generator. I'll use Bondo for the ramp.
I'm thinking about using a rotary modulator to pulse the flow out the vortex tube. This would consist of a self driven disc of copper which rotates on an offset axle. The disc would have a hole in it (1/2"?) with a 180 degree curved pipe attached. The pipe would be at such an angle as to provide rotational thrust to both the disc and to the turbine.
Ideally the modulator would rotate at such a rate that a resonance was established (what are the chances!). The reality will be a lot of trial and error. Just getting it to somewhat seal, as well as being able to freely rotate will be a major accomplishment.
Have you ever read any of Allan Cresswell's stuff? He's a character and has some very interesting theories. He's the one who originally got me going on these turbines.
Compelling Questions About The Grand Unified Theory
Cheers,
Ted
Thanks Mike, I'll check it out.Originally posted by Michael John Nunnerley View PostHi Ted
Mike
Ted
Thank you! These vortex machines has kept me fascinated for such a long time, but that simple sketch you made of the side view, its genius!
Water will be sucked up as a results of the centrifugally forced air, and sent out of those high speed nozzles. You are feeding energy to keep the motor in a high angular speed, but you are using the centrifugal force to do work (pumping up the water). This is not the same as accelerating a flywheel, and then collect that energy again. I believe those nozzles could have aided in accelerating the wheel further, and it might even be able to keep the wheel turning without any motor (this makes me think of Schauberger motors, where they only needed a start motor, which could then be disconnected when the water a reached a critical point in its rotation).
My belief is, that once you have something oscillating, be it water, weights, current in a LC tank or whatever, you can add energy in resonance to amplify its power.
But if you tap the energy released from other side of the oscillation, than you can get much more without draining the oscillation its self to any considerable degree.
Examples of the two sides of an oscillator:
Spring with weight: the weight itself and the base it is connected to. (Milkovic...)
LC tank and an electric motor: The electricity and the magnetic force in the coils (Rotoverter)
LC tank and a transformer: The electricity and the magnetic current inside the transformer.
(my idea for a solid state infinite power supply
Rotation wheel and centrifugal power. Your invention up here (my view anyways) and the upgraded milkovic pendulum, something I haven't built yet!
I think all the ways we can use and tap resonance in an oscillation is close to infinite.
Life exists as a constantly variating relationship of contrasts (oscillation), both on the Earth and in the Universe. We can tap it just as Nature does.
Also, thank you all who made this forum possible, I have learned so much while reading your posts here
Hi Ted Ewert,
What you describe with the vortex induced is similar to a turbo compressor that gives higher compression to the engine by using the expansion of heated air on the blades of the impeller.An interesting side note; my motorcycle (with the vortex generator installed) gains noticeable power the hotter the engine gets. Just like a hurricane gains intensity while traveling over warm water, the vortex gains angular velocity when it gets heated by my engine. External heat adds pressure to the vortex. The increased pressure differential causes an increase in angular velocity, as also seen in a hurricane. This subsequently increases compression, which forces more air into the engine, producing more power.
This can be use for generating electricity using the vortex induced spin on an impeller connected to a alternator. If I recall well, it was first promoted by a Russian physicist.
Take care,
Michel
