Oke this is my latest design in the on going quest of either eliminating back emf in a motor or back torque in a generator. This design fits the latter. Also I am aware that the magnetic setup is similar to Marinov's Siberian Coliu, but that's also where the similarity stops. This design should NOT work as a motor. I you push current through the conductors nothing will happen.
For initial tests a brush and collector are not needed. One could wire a small light bulb on the rotor along the conductor to observe current flow. I the process is reverses i.e. having a battery, the rotor should not spin at all as all the forces cancel out according to newton's third law.
So where's the catch? It's in the permanent magnets. We all know the famous "magnets can't do work" argument. Well they sure can, you have almost an infinite amount of electrons spinning without any voltage source. The catch is if you start spinning this and current starts to flow in the conductor this same current will in response cause the electron spin to slow down. But since the speed of spin is nearly the speed of light it shouldn't matter much. So the only side effect I predict is that the magnets will decrease a nearly unmeasurable amount in field strength when it's spinning.
This is why you can't replace the magnets with an electromagnet. The electromagnet will drop in voltage as the main conductors rise in voltage so you end up with no gain.
