Get Some?
The NEW Silver Solution has been tested in thousands of tests against some of the deadliest bacteria that exist on the planet and has been able to kill every single strain of bacteria tested so far. Even at dilutions of as much as 1 / 200 the original 10 ppm strength, it was still able to kill all the bacteria in raw river water in less than 20 minutes. Numerous tests at major US universities and commercial labs like UC Davis, Kansas State, Brigham Young University, IIT, and many other independent laboratories and universities, have proven the effectiveness of the product in killing thousands of strains of problematic bacteria like Staph, TB, Strep, E-coli, Salmonella, a number of yeasts, and even the anthrax bacteria, etc. We believe that The NEW Silver Solution product is the only non-toxic product that has been proven to kill the anthrax spore.
silver comparison
Bodkins,
Their info talks about their particle being 10nm.
10 nanometers = 0.01 microns
That is a monstrous size particle compared to:
Natural-Immunogenics
Average particle size 0.0008 microns (0.8 nm). Complete dispersion.
The "New" one is 12.5 times bigger than Natural Immunogenics Soverign Silver product.
Silver is the most powerful and potent the more smaller the particle size and There is no commercially available silver smaller than Natural Immunogenics. The smaller the particle size the more suface area available so a 10ppm or lesser dilution is more effective than larger particle sizes even up to 500ppm or more.
The only silver in history that was on part with theirs was Movidyn.
There is little defense against this kind of attack, and what few antidotes exist are withheld from the public as military secrets. One of the best examples of this is Movidyn, a substance the Soviets discovered in their satelite state of Czechoslovakia way back in the 1950's. Movidyn is a form of colloidal silver. One part per billion of powdered Movidyn in water has a germicidal effect. In a study of infected wells, it completely destroyed typhus, malaria, cholera, and amoebic dysentery. To the astonishment of the Soviet military, Movidyn also disinfected every germ warfar bacteria in the Soviet arsenal, even their newest designer poisons.'Sincerely,
I hear what your saying Aaron... but would such an extremely small particle size only be more effective if it was to be ingested? Of course the surface area needs to be taken into account but a higher concentration of larger particles could have an equal surface area.
I'm sure smaller is better
for cost if nothing else!
but I was just pondering the potential it has for killing off the bacteria in water. Would a particle size that small be necessary or would larger particles (assuming equal surface area) perform equally well?
What about Bob Beck?
Will somebody do some research on Bob Beck? The proper reseach will return the plans for building a colloidal silver maker with particle sizes a LOT smaller than 1 micron.
Better learn fast! The swine flu is coming.
Warren
..Men had been depending for too long on the authority of the great minds of the past and that they should rely more on their own resources in obtaining knowledge.
Francis Bacon
I think mesosilver performs even better at an average of 0.65 nm with 80% colloids and 20% ions;Originally posted by Aaron View PostBodkins,
Silver Colloids: Colloidal Silver Product Reports (scroll down)
So if you can't be bothered with making it yourself I recommend stocking up on this product with this swine flu crap.
1 micron = 1000 nmOriginally posted by mrbreau View PostWill somebody do some research on Bob Beck? The proper reseach will return the plans for building a colloidal silver maker with particle sizes a LOT smaller than 1 micron.
Warren
I would not recommend that solution. The best homemade solution I found was 10-15 nm, here's the link;
How to Make a Do It Yourself Colloidal Silver Generator that Creates Small Particles.
The secret is keeping the water moving. But as pointed out in the other thread it's best to not use a fish tank bubbler as this can put dirty air in the solution. Thus the best alternative is using a homemade magnetic stir like this;
StirPlate - Brewiki
I have been making my own for 10 years or more. Smaller is better, because if it is not small enough to enter your bloodstream, then it can't get into every organ to completely kill all bacteria. Another thing that's almost as good is oil of Oregano. It too kills almost all bacteria. If you want to make your own, go to Radio Shack and get a 25 volt AC transformer, build a box to house it, add a rectifier to convert to DC. Put a toggle switch on top.Run 2 leads from a multi tester(black and red), from the transformer. But 2 pieces of .999 silver(I use silver eagle coins). Use a glass canning jar. Use only distilled water.Turn on unit and verify with a meter that you are getiing 24-27 volts. Run for 10 minutes with low lighting. Observe that hydrogen bubbles are forming on the negeative side. Now switch the leads or reverse polarity.Run 10 more minutes. Water should be starting to turn a golden color. Use a laser light to detect concentration of silver particles.Strain through a coffee filter to remove any large particles. Store in a cabinet away from light, or put in a used,cleaned Hydrogen Peroxide bottle. Use only a plastic spoon to take,as Any metal will contaminate it. It will keep its strength for about 6 months. Good Luck. StealthLast edited by Stealth; 04-29-2009, 12:09 AM.
I think we went through this before...but let's do it again.
Gold, or any other colour, solution means that particle size is way too big for what we need it for. It might be good for oral application (burns, shingles, etc) though.
There's an old book on colloids from 1920 that talks about colour with relation to particle size. It has been linked in this forum before, and Peter Lindemann also spoke about particle size and solution colour as well.Are the ravings of a lunatic signs of a genius?
Does anyone else remember?
This was here only a few months ago. Link; http://www.energeticforum.com/health...inned-man.html
The thread died a sudden, mysterious death.
@ Bodkins
Sorry I didn't get this to you before but I've been spacey working on the Bessler Wheel for the last three months. Some days are diamonds and some days are stones. And since you were asking about he colloids I should have just posted this schematic and forgot about it.
This is the schematic to build the Basic Bob Beck device, blood zapper. With it is how to also the plugin for the colloid maker. Bob claims .0005 micron size but I have no way of checking the truth of that.
Since you work in the medical profession you might even TRY the zapper on yourself for a couple weeks and then get a blood smear. The real trick is to not let them throw the slide away for a week and then look at the smear again. (It is in one of Bob's videos.)
BTW; this was my very first electronic project and it took me over two months to complete. The reason for the delay is that one of the values in the schematic was wrong, wrong, wrong. It has been corrected, hence the name of the attachment.
I hope this helps someone.
Good luck to y'all.
Warren
Francis Bacon
size comparison
The larger cluster size doesn't have the same potential. The smaller particle size of what I mentioned is literally just a few atoms big per cluster. It is highly charged - very energetic...it really is energy medicine.Originally posted by Sephiroth View PostI hear what your saying Aaron... but would such an extremely small particle size only be more effective if it was to be ingested? Of course the surface area needs to be taken into account but a higher concentration of larger particles could have an equal surface area.
Also, virus can be very small compared to bacteria and if the particle size is too big, it won't work.
Also, the larger particle sizes of most companies usually have impurities or "silver salts" in the mix so their liquid is not clear...should be clear...otherwise, you could end up looking like a smurf. Not that it has shown to be dangerous, just not as effective.
So, no, larger size and higher concentration to equal surface area will not accomplish the same thing.
Also, the larger particles are not absorbed through the mucus membranes as easily as the sovereign silver for example and many people can have digestive problems as a result. The larger particles can wreak havok on the beneficial flora in the digestive tract.
The smaller particle size is usually completely absorbed into the blood before making it that far so therefore, no complication with digestion, where people do experience that with the larger particle size of usually higher ppm.Sincerely,
ac not dc
Contrary to what everyone claims about making silver - the smallest particle size has been made with a proprietary AC process and NOT DC.Sincerely,
I think anyone here believe that silver can kill bacteria effectively. But it seems there is a bit different opinion about which size is enough to kill them.
Is there any link that has a experiment result? the comparation of silver in different particle size in killing bactery.
Would swallowing silver ball would not be effective to kill the bactery? What cause silver to kill the bactery, it's surface or it's radiation or it's existence?
Do silver spoon, fork, knife, plate, or cup would have killed the bactery before entering our stomach? Wearing a silver ring or bracelet to reduce potential infection?
Do it have to be drinked? Would blood absorb the colloid? Would it be safe if we pour it to our injured knees?
About virus, I read in some book, virus can not be killed, it would only inactive in unfavored environment and it will active again someday. Is this wrong?
Purity and Topical applications
sucahyo, you can't use any silver to make Silver Colloids for drinking.
It must be very pure silver, somebody help me out here with references
and/or links about the purity of the silver requirements.
I researched it once but do not have that info at my fingers tips right now.
Topical applications, meaning externally applied on the skin can use less pure
silver, I believe . .. correct me someone if that is wrong.
Could less pure sliver can be used in emergency cases for insect bites, cuts or in wounds?
What about mucous membranes, nose, etc?
For just water to drink and really hard up,
2 drops of Regular Clorox Bleach per quart of water, Mix well. Wait 30 min.
Get a funnel and some coffee filters now, stock up, they are cheap now.. reuse them too.
Start saving charcoal for filtering to remove the chlorine, etc..Remember to be kind to your mind ...
Flu
"Each year, more than 100,000 people in the US are hospitalized and 36,000 die from the flu and its complications"
"About 36000 people die from flu in US each year. ... Common flu far more deadly than swine flu in U.S. ... U.S. seasonal flu kills 13000 since Jan"
and there were about 20 other similar corroborative statistics in no less than 0.28 seconds from our good friend Google.
Seems to me like some one is blowing something a bit out of proportion in order to get people to voluntarily inject themselves with who knows what.
Last outbreak of this very sickness led to mass vaccines and hundreds died, became terribly ill, and many became permanently crippled, because the company who created the vaccine accidentally screwed up.
