Hi there,
I'm new to the forum.
I've made a monopole, and a handful of operational SS Bendini type circuits, with some limited success in restoring a few sulphated batteries.
I have a question on the best way to condition a battery using this technology. Clearly many charge/discharge cycles are needed. Especially when conditioning a 'dead' battery. But what voltage should I charge to, to do this? 15v for first cycle?
And discharge to 12v (for 12v) batteries, at C20 rate.
What then?
15v again, or 14.4? or some other level?
And repeat.
Or is it something else entirely.
Any help would be appreciated. I have some circuits I've cobbled together for battery cutoff at high and low voltage, and would like to automate the cycling process.
tphiau
What then?
And repeat.
tphiau
So generally I use it for as long as I need it.
I started off using relatively brief load periods of just a few hours. I did this for a couple of cycles and then I started doing lower discharges, and the discharge curves are VERY interesting and I will share them when I have enough data to do a proper write up.
I am gathering the components to take it up to a 24 strand oscillator with 41 milliohms resistance!
Cheers,
